Old 08-10-2012, 01:08 PM   #43
phanguy
phanguy's Avatar
Drives: Scion FR-S Ultramarine
Originally Posted by jjdrivesajazz View Post
the DRL and high beam bulb shares the same bulb, so when you replace the bulb with a LED bulb, you will lose the high beam function. The LED simply won't be bright enough.
If you're okay with losing the high beams, then you can consider putting in an LED bulb for the DRL. If you're not comfortable with them, the other alternative would be to replace the bulb with an aftermarket "pure white" halogen bulb.
damn i just ordered some LED replacements from someone else... :/ can you suggest a pure white halogen bulb please?
phanguy is offline   Reply With Quote
Old 08-10-2012, 07:33 PM   #44
jjdrivesajazz
Drives:
I like to purchase quality brands like PIAA or Raybrig from a trusted vendor, there are too many fake bulbs out there that are just stock bulb with a blue coating to make them appear white (these will burn out prematurely from excessive heat).
Real PIAA and Raybrig bulbs usually range from $40-70/pair depending on the model
jjdrivesajazz is offline   Reply With Quote
Old 08-10-2012, 08:21 PM   #45
phanguy
phanguy's Avatar
thanks! too late to cancel my order from that other thread but ah well. guess it won't hurt to give them a shot anyway. looked up a set of PIAA's on amazon and think i found a good pair for a decent price! thanks again!
Old 08-12-2012, 07:59 PM   #46
jjdrivesajazz
Drives:
no problem! glad i could help
Old 08-14-2012, 04:29 PM   #47
jjdrivesajazz
Drives:
turn signal bulbs are arriving by the end of this month so i should have pics and diy soon
Old 08-16-2012, 09:51 PM   #48
computertech01
Drives: Jetta MK1V
Just a heads up all brzs don't have the door lights my premium doesn't.....
computertech01 is offline   Reply With Quote
Old 08-20-2012, 05:00 PM   #49
Yuck
Yuck's Avatar
Drives: Scion FRS 2013
Just ordered package 2 with the license plate lights! Looking forward to installing it!
Yuck is offline   Reply With Quote
Old 08-20-2012, 10:35 PM   #50
boarder1995
Drives: 2013 Subie BRZ Limited, black, 6MT
Assistance please...I've got all my LEDs working except the passenger door light. I swapped it with the driver's door and it's not the light, it's the socket. So, when I removed the light originally I didn't disconnect the wires and think I shorted it out as I popped the bulb out with a driver. I know, bad move. Is there a dedicated fuse for this socket? the other door still lights along with the overhead light. I've unplugged and re-plugged the regular bulbs and they don't work either. Anyone know what I'm missing, or what I've messed up? When it gets daylight again, I'll take a volt meter to it.
On another note, the lights look great! My wife's really impressed with the look on "her" car.
boarder1995 is offline   Reply With Quote
Old 08-25-2012, 10:29 PM   #51
jjdrivesajazz
Drives:
the first thing i would do is double check with a volt meter to make sure you're getting power to that wire harness, if not, then i would check the underdash fuse
Old 08-29-2012, 12:04 PM   #52
Yuck
Yuck's Avatar
installed my dome light and license plate lights, they are awesome, thank you so much guys!!
one other question by the way, for the trunk light, which bulb should I use if I want it to be an white led also?
Old 09-02-2012, 03:10 AM   #53
jjdrivesajazz
Drives:
T10 5smd 5050 is a perfect fit, some people decide to leave the housing cover off for more brightness.
Old 09-17-2012, 01:52 AM   #54
Obja
Obja's Avatar
Drives: Raven FRS/c5 Corvette
has anyone thought of making the rear license playe lights dimmer?!
is there a light you can buy that's dimmer than stock?
Obja is offline   Reply With Quote
Old 09-19-2012, 01:49 AM   #55
jjdrivesajazz
Drives:
i'm excited to let you guys know that we're going to have a new website, it's not done yet, but it will be easier to navigate and offer more options for products
Old 09-24-2012, 02:12 PM   #56
ProjectD
ProjectD's Avatar
Drives: '04 350Z/ 2013 LR BRZ (LM)
Can't wait to see end results. Do keep us informed --- btw --- order placed for BRZ (godzilla) kit + Tail/ Reverse lights. Thanks in advanced!
ProjectD is offline   Reply With Quote
License plate ideas Laika Off-Topic Lounge [WARNING: NO POLITICS] 142 06-13-2015 09:17 PM
SG886 license plate ToxicSneakers Off-Topic Lounge [WARNING: NO POLITICS] 0 06-18-2012 06:35 PM
Another license plate idea.... michaelahess Cosmetic Modification (Interior/Exterior/Lighting) 4 06-07-2012 09:24 PM
Front License Plate Replacements Bonburner Cosmetic Modification (Interior/Exterior/Lighting) 14 05-14-2012 07:25 PM
Front License Plate Location Polish Person Scion FR-S / Toyota 86 GT86 General Forum 44 12-16-2011 12:04 PM
