Old 08-08-2012, 11:17 PM   #29
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
Roughed her up pretty good. She's in the shop now. Scraped a pole while backing in, was malnourished hence the lack of concentration.
Staying positive though...the body shop will professionally debadge my car for me. The postal service with the Toyota badges needs to hurry up!
201208Accident by VictorN07, on Flickr
F1point4 is offline   Reply With Quote
Old 08-09-2012, 03:47 AM   #30
nujee86
Dark Prince
nujee86's Avatar
Drives: Kluger/Highlander
awwww dam that sux
Toyota 86- The revolution begins with a turn of the ignition
nujee86 is offline   Reply With Quote
Old 08-09-2012, 05:57 AM   #31
Justin91M
Justin91M's Avatar
Drives: Bagged RB8Six
Damn that sucks! I feel like when i get mine, im bound to hit something in a short time...its the curse man!
Justin91M is offline   Reply With Quote
Old 08-09-2012, 07:54 AM   #32
F1point4
Photo Specialist
F1point4's Avatar
Another positive note. I was chatting with @DarrenDriven about wheel flushness. In this case I'm glad Subaru didn't set up the wheels flushed or I'd have one messed up wheel.
The shop told me to fix this was about a 3 out of 10 so I'm fairly optimistic everything will be fine. I've used them before on a different car my family still has and they do good work.
Old 08-11-2012, 07:07 PM   #33
F1point4
Photo Specialist
F1point4's Avatar
Car is still in the shop. The techs told me they had to order a bracket that held the bumper to the car and called around to get paint codes since the car is so new. I took this as a positive sign that they are not half-assing the repair.
In the meanwhile these came in the mail. (Toyota emblems not pictured. Gave them to the body shop)
Thanks Luis at Carson Toyota for the side markers and emblems
201208UpcomingMods by VictorN07, on Flickr
Thanks Grimmspeed for the wonderful oil filler cap.
GrimmCapCloseup by VictorN07, on Flickr
GrimmCapLimitedEdition by VictorN07, on Flickr
Old 08-15-2012, 02:16 PM   #34
F1point4
Photo Specialist
F1point4's Avatar
Got my car back from the body shop. For those in the Houston Area, I recommend Tennison Automotive to get your car fixed. Here is a pic of the before and after. I'm so glad to have the car back.
TennisonRepair by VictorN07, on Flickr
The shop even re-badged the car for me. I used Toyota emblems purchased from Carson Toyota. For those who want to know Here are the emblems.
ReBadge - Family by VictorN07, on Flickr
My favorite picture
ReBadge - FRdashS by VictorN07, on Flickr
Front emblem is slightly larger than the rear emblem. The badge is not filled in.
ReBadge - Front by VictorN07, on Flickr
ReBadge - Front Back by VictorN07, on Flickr
The rear emblem
ReBadge - Rear by VictorN07, on Flickr
ReBadge - Rear Back by VictorN07, on Flickr
I drive a Toyota now.
20120814-PostCollisionRepairDamage-11 by VictorN07, on Flickr
20120814-PostCollisionRepairDamage-2 by VictorN07, on Flickr
Old 08-15-2012, 03:21 PM   #35
jarviz
jarviz's Avatar
Drives: Raven FRS MT
how much for the repair? was it just a paint job?
jarviz is offline   Reply With Quote
Old 08-15-2012, 03:37 PM   #36
tnt
Drives: argento frs at
very nice !
tnt is offline   Reply With Quote
Old 08-15-2012, 03:41 PM   #37
F1point4
Photo Specialist
F1point4's Avatar
I was quoted 1200 out of pocket. Lots of R&I (remove and install), materials, reshaping, labor.
Ended up filing a claim.
F1point4
Old 08-15-2012, 11:56 PM   #38
F1point4
Photo Specialist
F1point4's Avatar
1702 miles and did my first oil change. My items used were
Subaru 130 OEM Oil Filter
Filtermag SS 300
Fumoto F-108 Oil Drain Valve and Spring Clip
Amsoil 0W-20 Signature Oil
ESCO Curved Saddle Jack stand
Harbor Freight Floor Jack and Wheel Chocks
Block of wood
Grimmspeed Oil Filler Cap
Tools, gloves, funnels, etc to do the job.
Observations and Notes
+ Following Grimm's DIY (link) I used the block of wood with the jack to lift the front end of the car. At the highest point the Jackstands at the lowest height would not slide under the pinch welds. I had to remove the pin and just let the saddle rest in the stand. Fortunately the post was long enough that in this setting it was touching on the ground for somewhat added support
+ 30 minutes for cooldown after some distance driving, the oil drain bolt is still super hot
+ The Subaru OEM filter came pregreased. I did not add apply oil to the ring seal. Hopefully i can remove it
+ Hand tightened the filter only
+ The Filtermag SS300 fits on the #130 Subaru filter well.
+ Took a few tries but Grimm's oil filler cap screwed in. Looks beautiful. Since it is made of Aluminium it does get hot during engine operation.
+ The Fumoto Drain Valve fits on like a champ. I torqued it down using a 19mm open ended wrench. Tightened to my satisfaction.
+ The drain valve is inset the skid pan. Its fairly close to flush though. I would say 1/4" to 1/2" just by looking at it.
+ I had to use big pliers to open the spring clip to get it on. My bare hands would not do it.
+ I initially put in 5.1 quarts of oil. Let the engine run for a few minutes, then added 0.4 more quarts. My dipstick read 2/3 up between the two dots. I'll check again in a few days.
+ The disposed oil filled up a 5 quart jug good. I didn't think to get a precise measurement.
Here is a photo of the valve with the clip in place
20120815-FirstOilChange-3 by VictorN07, on Flickr
Direction the Oil will drain from the car.
20120815-FirstOilChange-1 by VictorN07, on Flickr
From far away the end of the spring clip barely sticks out. I think I can rotate it so nothing sticks out.
20120815-FirstOilChange-6 by VictorN07, on Flickr
Filtermag Fitment on the #130 Filter (rare bad photo)
Filtermag by VictorN07, on Flickr
The Following User Says Thank You to F1point4 For This Useful Post:
Bristecom (09-23-2012)
Old 08-16-2012, 02:51 AM   #39
Phaedrus29
Phaedrus29's Avatar
Drives: 2013 Subaru BRZ
Thanks for the info. Would you recommend that jack? Or maybe there's one that would let you jack the car up a bit higher? I tried my small craftsman jack today but I can't reach the jackpoint in the middle of the car...can you with that harbor freight jack?
Phaedrus29 is offline   Reply With Quote
Old 08-16-2012, 08:39 AM   #40
F1point4
Photo Specialist
F1point4's Avatar
Several things I could do to correct the situation
- get a floor jack that could lift higher
- get stands that are smaller (I have tall stands)
- find a thicker block of wood to place between the jack and frame (could be unsafe)
I think I'd try a thicker block of wood next time.
As for sliding the jack under the center jack points, mine doesn't fit either in its resting position. I had to pump and hold the handle all the way down for the jack to clear the front lip. Even in this position I probably had like 1/2" to 1" of space between the jack and the front lip. This is probably why I wont buy a larger floor jack.
If my car was lowered I'm afraid I'd have to buy one of those long flat jacks to lift it.
F1point4
Old 08-16-2012, 10:02 AM   #41
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
I like those jack stands.
F1point4
Why not a couple boards and a set of ramps?
Old 08-16-2012, 10:12 AM   #42
F1point4
Photo Specialist
F1point4's Avatar
Haha. I don't have my own garage so I have to carry my gear to one of my work sites. Need to keep it minimum. In the end, jacks and stands allow me to do more than ramps do, that's all.
Asphalt Scion FR-S aznsensazian FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 21 03-17-2014 01:13 PM
Asphalt FR-S pics Rob_g CANADA 24 09-03-2012 05:01 AM
Asphalt in the snow Double4Free Scion FR-S / Toyota 86 GT86 General Forum 5 06-10-2012 01:56 PM
Asphalt 6MT FR-S Symbiont Southern California 22 06-06-2012 07:47 AM
ant08 Asphalt MT ant08 Member's Car Journals 3 06-04-2012 04:16 PM
