Old 08-08-2012, 01:55 AM   #1877
clayrush
Drives: FRS,09 370z, 00 CelicaGT-S, 85 300Z
I wish i was not in the middle of tuning my celica's new supercharger, otherwise my money would be on the table.
clayrush is offline   Reply With Quote
Old 08-08-2012, 02:09 AM   #1878
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
I am VERY impressed with those figures. Amazing work guys!
Silverdub is offline   Reply With Quote
Old 08-08-2012, 02:14 AM   #1879
nix
nix's Avatar
Drives: AVO BRZ
Originally Posted by sybe View Post
is there a calculation to figure out hp from whp?
rated hp / baseline whp * new whp = 345.25 hp
nix is offline   Reply With Quote
Old 08-08-2012, 02:23 AM   #1880
sybe
Drives: None yet
My numbers were way off...thanks for that
sybe is offline   Reply With Quote
Old 08-08-2012, 03:20 AM   #1881
cruzinbill
Drives: Argento 6spd FR-S
Originally Posted by Don@Accelerated View Post
Final Numbers to which we are going to test the car at. Not the highest hp and tq figures we have done, but we feel this is a nice spot to stop to test. I feel this is a good area for pumpgas users.
Don
Great work! Now this is what I envisioned from your kit from the begining. A very repectable number.
cruzinbill is offline   Reply With Quote
Old 08-08-2012, 03:48 AM   #1882
epson1
Drives: 2013 BRZ Limited
shit my brain tells me to pay down my loan, but my heart says turbo kit.
epson1 is offline   Reply With Quote
Old 08-08-2012, 03:50 AM   #1883
Visconti
Drives: 05 STi
Follow your heart !
Visconti is offline   Reply With Quote
The Following 2 Users Say Thank You to Visconti For This Useful Post:
blackfireball5 (08-08-2012), civicdrivr (08-08-2012)
Old 08-08-2012, 03:53 AM   #1884
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
It's just crazy how smooth that dyno graph is. Looks like someone dropped a V6 from a 370Z in this thing. There is no surge of boost onset. This progressive output should do wonders on the track.
Coheed is offline   Reply With Quote
Old 08-08-2012, 04:02 AM   #1885
Coheed
Coheed's Avatar
You guys running into knock issues @ 10psi? Or is the lack of injector cc the reason you're backing off a bit. I know its a fresh motor and you don't wanna blow it up.
Old 08-08-2012, 04:20 AM   #1886
KamalT
Drives: Pearl 86 GT
Now all we need is one for the RHD drive market. Not buying coilovers and mags and going to use that money to boost this. Also bought a GT instead of GTS, for the same reason
KamalT is offline   Reply With Quote
Old 08-08-2012, 04:27 AM   #1887
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
That is beautiful work there guys.
Considering how this is for the simple turbo setup do you expect to see a big shift in gas mileage?
Old 08-08-2012, 05:15 AM   #1888
serialk11r
Drives: '06 AM V8V Coupe
A good clue would be how much boost there is at highway cruising engine speeds. Now since their dyno run starts at ~2500rpm it's a little hard to tell, since the transient response of the turbo is an issue, but it looks like the turbo doesn't really "spool up" until you hit well over 3500rpm.
Any fuel economy loss at steady low load cruising conditions will be due to the turbine adding restriction to the exhaust, which doesn't seem like it's going to be a big deal. Most turbo engines "spool" well before this one does.
Under normal acceleration, engine efficiency will drop a little bit when you use boost, but again it appears there is very little boost below 3000rpm so probably not going to impact fuel economy much.
Best if they can tell you how much boost it builds in the lower engine speed ranges, and if they have any exhaust pressure readings (probably not going to be a significant increase).
Old 08-08-2012, 06:37 AM   #1889
czar07
czar07's Avatar
Drives: '97 RSP JZZ30 GT-T
god I LOVE that power and torque curve. looks amazing for the kind of car this is!
Germans>Japanese>Italians>Americans. Unless its a Corvette.
czar07 is offline   Reply With Quote
Old 08-08-2012, 08:14 AM   #1890
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Just because you have more who doesn't mean the driveline takes more hp to move. So rated-base+new.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
accelerated performance, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
Accelerated Performance 2013 BRZ Intake Dyno Testing Video Don@Accelerated Engine, Exhaust, Transmission 109 05-17-2013 12:24 PM
Accelerated Performance 2013 BRZ Exhaust Systems Don@Accelerated Engine, Exhaust, Bolt-Ons 135 09-04-2012 12:24 AM
Accelerated Performance 2013 BRZ/FRS Exhaust Systems Don@Accelerated Engine, Exhaust, Bolt-Ons 24 07-07-2012 08:05 AM
Hello from Accelerated Performance! Don@Accelerated Announcements, Contests, Giveaways 5 07-04-2012 09:14 PM
