Old 08-06-2012, 12:11 PM   #15
BRAWL
Drives: Toyota 86 GTS Velocity Orange
Originally Posted by tjoy View Post
http://www.sprintex.com.au/sprintex/superchargers/
can't tell what model they used from cross-referencing the pic w/ the product pages
Sprintex S5-210 is what they are using. Sounds awesome!
BRAWL is offline
The Following User Says Thank You to BRAWL For This Useful Post:
ill86 (08-07-2012)
Old 08-06-2012, 12:16 PM   #16
WTF
WTF's Avatar
Drives: FT86, BMW 5, JZA80, Porsche 986S
Car is presently at mercury motorsport, supercharger kit was made by Bullet (using a Sprintex SC). Car has a ECUTEK flash tune, which is yet to be tuned. The guys at Mercury will be tuning it prior to the car's departure for WTAC.
I will see if I can get some more pics tomorrow, however it was generally 'requested' that the official unveiling be at WTAC this coming week, so to respect their wishes, I was asked to hold onto the majority of the pics until later..
600hp Built FA20 Widebody Toyota 86/FRS.. build thread
WTF is offline
The Following 7 Users Say Thank You to WTF For This Useful Post:
Guff (08-06-2012), MannyO (08-12-2012), MarkRacerX (08-14-2012), rusty959 (08-06-2012), scottman (08-08-2012), sirus (08-08-2012), ultra (08-07-2012)
Old 08-06-2012, 01:55 PM   #17
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Nice! Can't wait to see results.
I noticed that the hood is missing the insulation. Does it no longer fit?
Parting out HERE
civicdrivr is offline
Old 08-06-2012, 02:24 PM   #18
mechaghost
mechaghost's Avatar
Drives: Silver AT Limited
Can't wait to see the dyno results
mechaghost is offline
Old 08-06-2012, 03:23 PM   #19
serialk11r
Drives: '06 AM V8V Coupe
mmm not liking the twin screw compressor, the parasitic power loss is going to be quite high but props to them for getting it working!
serialk11r is offline
Old 08-06-2012, 03:43 PM   #20
rusty959
Drives: DGM BRZ limited
rusty959 is offline
Old 08-06-2012, 05:12 PM   #21
Flat Black VW
Flat Black VW's Avatar
Drives: 2013 Subaru BRZ
looking forward to this one....
Flat Black VW is offline
Old 08-06-2012, 06:02 PM   #22
serialk11r
Originally Posted by rusty959 View Post
:P Eaton TVS is superior IMO, higher efficiency, volumetric efficiency, low parasitic power consumption. Admittedly they're hard to find.
Just look at the Sprintex page, at 1.4 bar discharge pressure (close to max efficiency point) the power consumption is something like 7-8kW at 7000rpm. At 0.94L displacement, and 0.4 bar boost pressure, that corresponds to about 5000rpm engine speed. Recall that at 60mph the engine is already turning 2600rpm. The supercharger is turning about 3700rpm. Admittedly the manifold pressure will be very low at cruise, but the majority of the power consumed by the rotary twin screw compressor is through internal compression, and so the power consumption you'll see at cruising speeds is not going to be that far below the 1.4 bar discharge power consumption.
It's a bit hard to see since the resolution of those charts sucks, but you can see that the power consumption at 3-4k rpm supercharger speed is in the neighborhood of ~2-3kW or about 4hp going down the drain. When the supercharger is not working against positive manifold pressure this is admittedly lower, but it will be on the same order of magnitude. It only takes something on the order of 15hp average to roll down the highway at 60mph, and you can definitely expect the supercharger to be consuming at least 2hp extra.
Eaton TVS superchargers will drain perhaps half a horsepower or less by comparison, under the same conditions, and give you boost at similar levels of efficiency, probably better in fact.
The Following 2 Users Say Thank You to serialk11r For This Useful Post:
Godzilla35 (08-08-2012), Tomzilla (08-06-2012)
Old 08-06-2012, 06:39 PM   #23
Tomzilla
Tomzilla's Avatar
Drives: '13 Premium MT BRZ
TL;DR
Go with Eaton if they produce and release an SC for our cars.
Tomzilla is offline
Old 08-06-2012, 06:44 PM   #24
Dimman
Kuruma Otaku
Dimman's Avatar
Didn't we figure out that Lysholm maps are complete and include hp to spin and Eaton maps need more math and stuff?
Because titanium.
Dimman is offline
Old 08-06-2012, 06:56 PM   #25
serialk11r
Yea, but Eaton's powerpoint presentation on downsizing and downspeeding has a map that describes the no load power requirements. It takes nothing to spin a bypassed Eaton compared to your typical twin screw, the lowest marked line was 0.5kW and the cruising load point fell far below that line, so much that they didn't even bother to figure out how much power it was consuming, they just said "below 500W". Just eyeballing it, it looks to be probably 200W or less. Lemme dig up the chart.
Anyhow, I doubt mechanical efficiency is that big of a deal. The centrifugal supercharger folk claim well over 90% mechanical drive efficiency.
EDIT: Okay nevermind maybe not 200, this looks kinda like 300W to me, but still, the twin screw rotary compressor is consuming probably 5-10 times that.
http://www.engine-expo.com/forum_200...rt_walling.pdf
page 19
The example used is a 2.0L engine with 0.9L compressor, so very comparable.
Old 08-06-2012, 07:04 PM   #26
GirlyScions
Drives: Mazda3
Maybe we will see better displacement charges someday but if its only 4 hp loss im still excited to see it finished.
GirlyScions is offline
Old 08-06-2012, 07:06 PM   #27
serialk11r
4hp loss at cruising is like losing 20% fuel economy
Like I said in reality it might be more like 2 or 3hp, but again that's losing 10-20% fuel economy.
Old 08-06-2012, 07:52 PM   #28
rusty959
Even with a 20% fuel economy drop the car will still get good mileage by my standards.
No matter what, I am excited to see what they can do because every new piece like this is just further driving the aftermarket. Plus a roots type just looks/sounds sexy.
Ill probably still go turblo though.
rusty959 is offline
Our Silver Bullet - FT-86 SpeedFactory FT-86 SpeedFactory Member's Car Journals 151 10-06-2016 11:57 PM
