Old 01-17-2026, 06:37 PM   #4579
BishamontenZC6
Drives: '14 BRZ Limited
Question about the infamous conical washer on KW based coils. Why exactly and technically some people recommend it and what problems could occur if it’s not installed between spring perch and Group N top hats ?
Also, why KW and ST installation manuals don’t mention it, only RCE does ?
BishamontenZC6 is offline   Reply With Quote
Old 01-19-2026, 12:51 AM   #4580
fminicooper
Drives: FRS Hot Lava
Bilstein B6 failure
Hi,
I’ve had a failure on the shock absorber rod.
Setup: FRs 2016, NA engine, Bilstein B6 dampers, Pedders top hats, Eibach springs, –3° camber. About 30,000 miles total, including several aggressive track days.
Has anyone experienced a similar issue?
fminicooper is offline   Reply With Quote
Old 01-19-2026, 01:52 PM   #4581
Scargod
Track Day Junkie
Scargod's Avatar
Drives: 2022 BRZ Limited
Breaking at that spot is common, if it's going to break. Were you banging curbs?
I don't know Pedders top hats, or the Bilstein's, but if that's a 12mm shaft then that may be your answer. Most front, high-end racing dampers are a minimum of 14mm diameter.
Scargod is offline   Reply With Quote
Old 01-19-2026, 04:39 PM   #4582
Racecomp Engineering
That's not the damper shaft since it's an inverted strut. The damper shaft is inside the body and at the bottom.
The breakage could be from a variety of things, most commonly in my experience from from a bit too much torque on the top nut. It happens. I'd just have Bilstein rebuild the dampers.
- Andrew
Old 01-19-2026, 06:14 PM   #4583
Scargod
Track Day Junkie
Scargod's Avatar
You got me there. I wasn't paying attention. Still, couldn't it be small for hard racing?
You rightly corrected me, yet I've had no response for the question I asked...
Old 01-26-2026, 09:41 AM   #4584
It's just hard to tell the cause in this case. There are tons of 12mm top nut struts out there doing just fine. An improperly torqued top nut could certainly push it over the edge. Or a materials defect, or a massive impact that also would wreck a 14mm top nut, etc...
- Andrew
Old 01-30-2026, 09:40 AM   #4585
J95
J95's Avatar
So, the alignment people are not moving the collards (sic) at all? No corner balancing? In your case, you are expressing ride height in distances from the fender to hub. This is not helpful to a lot of people who cannot go with dimensions off their modified fenders. Measuring off the pinch welded sheet metal seam on each underside of the car is more universally accepted, even though tire diameters comes into play and tire pressure to a small degree. This is how 949 Racing suggests we measure ride height...
If you notice, the seam of metal that forms a rib is quite straight till you get to about a foot from the front, where (on my car) there is a slight upward taper of perhaps 1.5 to two mm's. So I suggest that everyone measure well back from the front jacking point on the pinch weld area.
I'm at around 5" in the front and 5-1/4" in the rear with 24.5" diameter tires.
For the 2022+ Subaru BRZ and Toyota GR86 (Premium/Limited trims) equipped with factory 18-inch wheels, and tires that are 24.8" in diameter, the standard pinch-weld height is approximately:155.6mm or 6.125” front and 158.8mm or 6.25 rear.
As to your camber, I believe we need to know all of what you've done to the car's suspension. You mention rear LCA's. And, if you go over an inch lower you really need to correct the geometry with aftermarket parts.
Somewhere in this discussion I read an opinion that a lot of camber doesn't have a lot of affect on tire wear while driving on the street. It does if you go straight a lot. It does when you brake. It does adversely affect handling in the wet. It reduces traction when driving slowly on the street.
On the track, which is all I do now with my BRZ, I run -4° or more camber and over -3° in the rear. A one degree difference from front to rear is very common.
Note that I'm all in on mods to my suspension and I have significant aero. I have custom, lowering subframes (as noted in my post above). I have gutted my car to where, with a roll cage my car is 2,600 pounds. I run sub 200 TW tires in 255 X 17. I sometimes run Hoosier 245 R7's (24.3" tall). I'm waiting on a set of 245/40R17x 24.7" diameter, Vitour Tempesta Sonic tires to try.
If we don't speak a common language, with full disclosure, it's difficult to have a meaningful discussion where we can help each other.
Not moving the collars, no corner balancing
Next time I will measure the metal sheet as well. What I can tell you is how much was the drop (from OEM), approx.: 1.7'' front / 1.8'' rear. My target is ~1.1-1.2'' drop, no more than that
About the suspension changes to the car, not that much:
- Front whiteline KCA416 camber bolts (they are maxed out, the shop did not touch them)
- KW w3 with front KW Clubsport top mounts, they touched
- rear adjustable Whiteline LCA, they touched
- Wheels 17x9, 235/40
With this set up, adding -1° camber has lowered ride height by 10-15mm
J95 is offline   Reply With Quote
Old 10-15-2026, 07:01 AM   #4586
MrSkubi
MrSkubi's Avatar
Drives: 24 GR Yaris, 23 GR86
Is this thread still alive ? I'm wondering if I can get swaybar recommendation (I've had KW V3 CS and Ohlins before, moved to damper+spring combo for ease of living and DD comfort) for Bilstein B6 with Eibach Pro Kit (EU one - small lowering as in B12 kit) for use with Nangang CR-S in 235/40 size ? Camber should be around -3,1°F -2,7°R with zero toe in F and 0,1 toe in R.
MrSkubi is offline   Reply With Quote
Old 10-19-2026, 08:07 PM   #4587
The usual way to go is a 20mm front and 16mm rear, both adjustable. A bigger 22mm front is sometimes used for autocrossers. Some also go with a stock 14mm or 15mm rear, depends on what you're looking for with your car.
- Andrew
Old 10-20-2026, 11:18 AM   #4588
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
I ended up going with the Perrin 19mm bar set on soft. I originally had it set to stiff (2 position), but felt the car "turned better" on soft - like it set and hooked in the front better. Less initial understeer. The rear I've left stock. This is for heavy autocross use with the RCE SS-1 coilovers, 6k front and rear. The car is balanced and have had some national champs and trophy winners drive it at schools and they said the balance and feel is good, so I haven't touched it.
Generally speaking, you'll likely want something around the 18-20 range up front and either stock or just a hair over stock in the rear. A lot comes down to your spring rates, dampers, and what you want the car to do at the limit.
Note: This is all autocross related. No track experience.
cmiovino is offline   Reply With Quote
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 03:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 05:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 06:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
