Old 01-20-2026, 07:02 PM   #1
Wu86
Drives: 86 GTS AT
Help with understanding numbers
Name:  Screenshot 2026-01-21 095140.png
Hey all
I recently installed the Tomei EL headers, then had it custom tuned with Revzone in Melbourne, Aus, who are quite reputable with tuning 86s.
I definitely have noticed a decent power increase when I'm driving, and the car feels heaps better with acceleration as well compared to before the tune.
I've attached a screenshot of the graph
The graph only shows axle power in KW. I'm not quite used to reading that (and I'm still learning). For the stock run, 92KW at the wheels seems quite low as a number? I'm not sure how to convert that to engine KW which by the books is I believe 147KW. And given that after the tune of 110kW at the wheels feels so much better, how much would that be roughly in engine KW?
It was tuned with 98 RON, other parts that I have are Perrin 2.5 inch catback, K&N Filter, Mishimoto Silicon induction Hose
Wu86 is offline   Reply With Quote
Old 01-21-2026, 12:05 PM   #2
bababooey
Drives: BRZ SWP Limited -6MT
if i math correctly, 92/147 & 110/X = 176 kw, roughly 236 hp, but that seems kind of high for tune & headers
bababooey is offline   Reply With Quote
Old 01-23-2026, 08:19 AM   #3
Eaton PSI
Drives: 2013 86
The claimed stock 147kw at the crank is probably optimistic and is distorting your maths. That said, you've got nearly 20% more power which is pretty impressive for exhaust and tune.
2014 GT86, 2.2L big bore, harrop supercharged
Eaton PSI is offline   Reply With Quote
Old 01-23-2026, 08:31 AM   #4
Eaton PSI
Drives: 2013 86
At 4250 rpm its nearly 50% more power. That will make it feel faster!
Old 01-24-2026, 02:45 AM   #5
tomm.brz
Drives: brz 2017 hksv2
it looks good and wuite obviously they are values at the wheels and not at the crank
New short block help, understanding service manual FullArtLegend Engine, Exhaust, Transmission 1 04-23-2021 07:18 PM
Help With Understanding Forum Post Rules Darth Khan Off-Topic Lounge [WARNING: NO POLITICS] 5 11-13-2017 05:43 PM
18x8 vs 18x8.5? Need Help Understanding Ammunition Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 07-02-2015 02:36 AM
HELP with understanding Brakes upgrade path bear89103 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 07-17-2013 08:08 PM
Understanding the BRZ/FR-S/86 Occupant Detection Sensor Turbowned Issues | Warranty | Recalls / TSB 13 08-27-2012 11:58 PM
