Old 11-18-2025, 12:35 AM   #4565
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Originally Posted by RotARy15 View Post
I've been needing to re-toe the front end so this would be a good time to install an anti-dive kit, if they are worth anything.
I've installed the rear Traction Mod and been very happy with it. However, I am less convinced about anti-dive. I've had my eyes on the Jackson kit but don't really understand what it will actually do for me.
There is very little in the way of reviews online. I've found a single youtube video where there was no discernable change to physical dive/compression under braking, but the review mentioned the front end was "more gooder on corner entry, fr fr no cap" or something to that effect. I'll take anything that makes the car pointier but if I don't fully understand it, then I'm worried about making some other aspect worse.
Traction mod: Recommend checking this thread out soon. https://www.ft86club.com/forums/showthread.php?t=155702
I'll give it a shot from a theoretical perspective...
Easy description of antidive is to imagine your suspension is on a very long longitudinal swing arm. The distance between the pivot point of that swing arm and axis of braking force (front contact patch to center of gravity) determines how much torque about the pivot point the spring has to counteract. More torque, more dive.
By changing the angle of the front LCA, you change where that swing arm pivot point is. The Cusco kit moves the front attachment point lower, moving the longitudinal swing arm pivot higher, increasing the "antidive geometry". This means the nose of the car will dive less under braking.
Why is this good?
-If you have aero this can be helpful to keep the wings and things at the appropriate angles.
-It lets you run lower ride heights with softer springs before you start bottoming out and hitting bump stops.
-Less camber gain under braking, which is good for straight line braking.
-Generally smaller body motions result in more consistent grip profiles for the tires, for better or for worse.
Great, what's the catch?
-The suspension with more antidive/antilift is not as compliant with mixed inputs, meaning any bumps or hills during trail braking are going to result in a greater understeer tendency.
-The driver has a smaller window of sensory input regarding how much braking is being applied.
-Less camber gain under braking, which is generally worse for mixed inputs.
Also: "Build Thread"
The Following User Says Thank You to Spuds For This Useful Post:
T-Steve (11-18-2025)
Old 11-19-2025, 12:09 PM   #4566
RotARy15
Drives: 1993 Mazda RX-7 R1, 2025 BRZ tS
Not so sure they fit my purpose then. Seems like something I would need to actually try, but for the price, probably not worth it on an OEM+ build.
RotARy15 is online now   Reply With Quote
Old 01-01-2026, 05:42 PM   #4567
Scargod
Track Day Junkie
Scargod's Avatar
Drives: 2022 BRZ Limited
What is ideal damper travel for a lowered race car? RUCA hitting body!
My second ZD8 BRZ has fully adjustable suspension components on TSS Fab subframes. I'm the Guinea Pig for his new subframes. In the fall I was running the front subframe with no issues. Car handled fine. While the rear was being finished I ran the stock subframe with GKTech solid subframe and diff bushings.
I typically run at 4-1/2" inches front and 5" rear (at the pinch welds).
Part of 2025 I ran Ohlins Road & Track SUS MP21S2. Front Stroke: 120 mm/4.72” / Rear Stroke looks to be about 75mm or 3".
My JRZ RS Pro3 Motorsport shocks date back to 2017-2018 and came from CSG! I'm their second owner. The JRZ's are around 5-1/2 to 6" stroke in the front, depending on the bump-stops. Rear stroke is 4"+.
I've been setting the car up so that I have a 60/40 shock travel in the front. This required me having to turn special spacers on my lathe and move my caster/camber plates to the top of the shock towers, where alone I recouped about an inch of compression travel. I gained another 3/8" by using all of the threaded portion of the shaft that I could. I made special nuts for this so that threads extended down into the spherical bearing. I'm very happy with the front geometry and its very nearly a 60/40 stroke though not a 75/25 I've read about. BTW I have full aero.
It's the rear of the car that's killing me and what I don't understand.
The new subframe is supposed to yield a 5/8" drop. When I try to go to full compression (with the springs and bump-stop removed) I can only get to 1-1/2" of travel before the upper control arm hits the monocoque metal frame. I tried a Cusco UCA and it was negligibly better. Best looking of all (for the most travel) was the stock arm... I did not bother fitting it on the subframe.
I can't get full travel from the JRZ's. Droop yields no positive camber. At the interference point I'm at -3° which is okay. At issue is that I'm an inch or so away from contacting the bump-stop. I'm hitting the body frame before I've used half of my shock's travel.
I don't know what to do but to move the structural sheet metal in at the interference point or grind on the side of the arm. Before I do that I thought I'd check my sanity and see if anyone else has had a similar experience and/or what a different solution would be. The last thing I want to do is move the subframe down to gain UCA clearance. I like where the diff sits and all the rest of the geometry, as is.
BTW, I really like the toe links and the long trailing arms that came with the TSS Fab subframe. Great welding and construction. William has been great to work with.
Last edited by Scargod; 01-15-2026 at 05:52 PM. Reason: Making it clear that this is my second, second gen (ZD8) car.
Scargod is offline   Reply With Quote
Old 01-05-2026, 12:09 PM   #4568
J95
J95's Avatar
Question here, I did adjust my ride height (KW v3) to:
335 mm F/ 340 mm R (fender to hub center)
Which is a drop of ~31 mm
I take my car to the shop for a new alignment, camber values are:
before: -2.8 F / -2.0 R
after: -3.5 / -3.2
Then I measure ride height after shop alignment:
323 mm / 325 mm
Which is a drop of ~45 mm
This is a huge change in ride height, isn't?
I understand that I have to redo my ride height, which means changes in static toe/camber again, which means I will need another alignment. Looks like an endless loop, what's the best way to proceed here?
Btw I tracked my car with this setup, it did not feel right, probably the car is sitting on bumpstops way too much
My goal now is 340 mm / 340 mm and -4° / -2.8°.
J95 is offline   Reply With Quote
Old 01-05-2026, 02:43 PM   #4569
Ohio Enthusiast
Drives: 2018 BRZ
323 mm / 325 mm
Did you ask them to change the ride height? If you only asked for alignment (i.e. camber and toe adjustment) the ride height shouldn't have been changed at all.
Personally I would either find a good race shop that you can work with to set your suspension and will respect your exact specifications for ride height, camber and toe, and can do corner balance as well. Or do the alignment myself - camber is quite easy to do with a digital angle gauge; toe is harder, but toe plates will get you close if you only need to correct toe from camber change and most alignment shops could manage to correct toe if needed.
Ohio Enthusiast is online now   Reply With Quote
The Following 3 Users Say Thank You to Ohio Enthusiast For This Useful Post:
autoracer86 (01-05-2026), J95 (01-05-2026), Scargod (01-15-2026)
Old 01-05-2026, 07:40 PM   #4570
J95
J95's Avatar
Nope, they only changed camber and toe. But ride height is a side effect of chamber change. At least the fender to hub distance
At least I experimented it myself when I adjusted my camber bolts. The ride height decreased a bit when I maxed out the camber bolts. Now the shop adjusted my camber plates, and decreased ride height again...
Old 01-05-2026, 07:47 PM   #4571
Ohio Enthusiast
Drives: 2018 BRZ
Yes, it would change a bit, but I really doubt adding around 1 degree of negative camber will shift the ride height by 15mm, especially in the rear.
What's your rear camber adjustment? LCA or UCA (although neither should affect height much when adjusted)?
The Following 2 Users Say Thank You to Ohio Enthusiast For This Useful Post:
J95 (01-06-2026), Scargod (01-15-2026)
Old 01-06-2026, 12:34 PM   #4572
J95
J95's Avatar
I have rear LCA. I don't know why the height shifts so much... but it does, checked with LCA, camber bolts and top mounts
So I will raise the coilovers until 340 mm, and will get a camber tool because you are right, it looks easy to DIY. Then the shop just need to zero out the toe
Does -4° F / -2.8° R look ok for very little street use? I read that camber does not affect wear that much
The Following User Says Thank You to J95 For This Useful Post:
Ohio Enthusiast (01-06-2026)
Old 01-06-2026, 12:45 PM   #4573
Ohio Enthusiast
Drives: 2018 BRZ
I'd be interested to see if this turns out to actually be the case. I don't suppose you have the coilover height measurement from before the shop's alignment?
I'd probably aim for more negative camber in the rear, as much as -3.5. There're no good references for heavily tracked cars (every thread devolves into "it depends" without people actually sharing hard numbers). 949 racing's specs are probably the most easily accessible, and they recommend -3.5 to -5 in the front and -3.5 in the rear.
I have even wear with -3 front camber on a mostly street car. I bumped it to -3.5 now and will see how evenly it wears.
The Following User Says Thank You to Ohio Enthusiast For This Useful Post:
J95 (01-06-2026)
Old 01-06-2026, 02:24 PM   #4574
J95
J95's Avatar
Yes I do, it was something like:
PRE alignment:
fender to hub (mm):
334 | 337 Front
342 | 340 Rear
distance (mm) from coilover collard to last thread (the more, the higher ride height)
14.5 | 11
78 | 89
POST alignment (added ~1° negative camber):
324 | 322 Front
324 | 326 Rear
Old 01-06-2026, 02:40 PM   #4575
Ohio Enthusiast
Drives: 2018 BRZ
14.5 | 11
78 | 89
Nice. Compare these measurements to what's on the car now. If they haven't moved, then the camber is the only thing that changed. Fascinating stuff.
J95 (01-06-2026)
Old 01-06-2026, 10:50 PM   #4576
Racecomp Engineering
What I do:
1. get ride heights close
2. roughly align camber settings
3. reset ride height and/or corner balance
4. final alignment
Sounds like a lot, but 1 and 2 are basically a standard coilover installation plus a little extra thought.
- Andrew
The Following 4 Users Say Thank You to Racecomp Engineering For This Useful Post:
churchx (01-11-2026), J95 (01-07-2026), Ohio Enthusiast (01-07-2026), Scargod (01-15-2026)
Old 01-15-2026, 01:36 PM   #4577
ruturaj001
Drives: BRZ 2023
Originally Posted by 2.2Lude View Post
This is pretty cool.
ruturaj001 is offline   Reply With Quote
The Following User Says Thank You to ruturaj001 For This Useful Post:
2.2Lude (01-16-2026)
Old 01-15-2026, 08:43 PM   #4578
Scargod
Track Day Junkie
Scargod's Avatar
RE J95's questions
PRE alignment:
fender to hub (mm):
334 | 337 Front
342 | 340 Rear
14.5 | 11
78 | 89
324 | 322 Front
324 | 326 Rear
So, the alignment people are not moving the collards (sic) at all? No corner balancing? In your case, you are expressing ride height in distances from the fender to hub. This is not helpful to a lot of people who cannot go with dimensions off their modified fenders. Measuring off the pinch welded sheet metal seam on each underside of the car is more universally accepted, even though tire diameters comes into play and tire pressure to a small degree. This is how 949 Racing suggests we measure ride height...
If you notice, the seam of metal that forms a rib is quite straight till you get to about a foot from the front, where (on my car) there is a slight upward taper of perhaps 1.5 to two mm's. So I suggest that everyone measure well back from the front jacking point on the pinch weld area.
I'm at around 5" in the front and 5-1/4" in the rear with 24.5" diameter tires.
For the 2022+ Subaru BRZ and Toyota GR86 (Premium/Limited trims) equipped with factory 18-inch wheels, and tires that are 24.8" in diameter, the standard pinch-weld height is approximately:155.6mm or 6.125” front and 158.8mm or 6.25 rear.
As to your camber, I believe we need to know all of what you've done to the car's suspension. You mention rear LCA's. And, if you go over an inch lower you really need to correct the geometry with aftermarket parts.
Somewhere in this discussion I read an opinion that a lot of camber doesn't have a lot of affect on tire wear while driving on the street. It does if you go straight a lot. It does when you brake. It does adversely affect handling in the wet. It reduces traction when driving slowly on the street.
On the track, which is all I do now with my BRZ, I run -4° or more camber and over -3° in the rear. A one degree difference from front to rear is very common.
Note that I'm all in on mods to my suspension and I have significant aero. I have custom, lowering subframes (as noted in my post above). I have gutted my car to where, with a roll cage my car is 2,600 pounds. I run sub 200 TW tires in 255 X 17. I sometimes run Hoosier 245 R7's (24.3" tall). I'm waiting on a set of 245/40R17x 24.7" diameter, Vitour Tempesta Sonic tires to try.
If we don't speak a common language, with full disclosure, it's difficult to have a meaningful discussion where we can help each other.
The Following User Says Thank You to Scargod For This Useful Post:
J95 (01-30-2026)
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 03:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 05:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 06:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
