Old 11-16-2025, 01:34 PM   #1
Code Monkey
Drives: Subaru BRZ
PSA: MCA traction mod failure
Installed 9/18/2018 on my 2017 BRZ at 12,290 miles.
Taken off May 2022 at 27,570 miles.
Installed 5/15/2022 on my 2022 BRZ at 825 miles.
Taken off 11/16/2025 at 16,030 miles.
Both cars heavily tracked.
Left side cracked, right side broken apart.
If you have this mod on your car, my advice is to inspect/remove immediately.
Code Monkey is offline   Reply With Quote
The Following 9 Users Say Thank You to Code Monkey For This Useful Post:
autoracer86 (11-16-2025), bcj (11-16-2025), bmacfrs (11-16-2025), Compelica (11-17-2025), DarkPira7e (11-16-2025), pope (11-16-2025), Racecomp Engineering (11-17-2025), Spuds (11-16-2025), Tatsu333 (11-18-2025)
Old 11-17-2025, 10:01 AM   #2
bmacfrs
bmacfrs's Avatar
Drives: 2013 FRS
Maybe that make the product from GKTech more attractive. https://us.gktech.com/products/86-gr...-mod-arm-combo
WIFE: "How can there be anything left to buy?"
bmacfrs is offline   Reply With Quote
Old 11-17-2025, 10:12 AM   #3
redlined600
redlined600's Avatar
Drives: Fr-s
What do you have for subframe bushings?
To me it looks like the base mounts to the arm/inner sleeve/bolt which are fixed and the flanges mount to the subframe which are moving (due to bushing deflection). If that's the case, the failure makes sense.
Thanks for pointing this out.
redlined600 is offline   Reply With Quote
Old 11-17-2025, 05:06 PM   #4
Code Monkey
Drives: Subaru BRZ
Whiteline subframe bushings on the '17, OEM subframe bushings on the '22.
Old 11-17-2025, 09:02 PM   #5
I'll have a look at mine tomorrow morning.
- Andrew
Old 11-18-2025, 10:55 AM   #6
Tatsu333
Drives: 2020 BRZ Sport Tech RS
Between this reported failure and my experience with corrosion of the brackets despite very low mileage, I've gotten really nervous about the durability of my MCA Traction Mod V1. So, I've decided to replace it with something else.
In searching around this morning, I came across this option that I had never seen before:
https://www.justengineering.ca/shop/subaru/frs-brz-gt86-gr86-adjustable-traction-arms/
With it using a similar configuration to the MCA's but with what looks to be MUCH more robust materials and finish (and it being a Canadian shop in Quebec producing it ), I decided to pull the trigger. It's a bit pricey, but both relocates the pickup point and replaces the trailing links, so it saves the cost of the STI trailing links as well.
Of note is that it moves the pickup point both down by 50mm AND forward slightly, and the new trailing link is longer as a result. They say the forward position and longer arm are "to reduce the toe gain curve as much as possible to so it became more linear."
Anyway - there's a little over $600 CAD I didn't really have available now gone, but it will give me a bit more peace of mind...LOL.
Tatsu333 is offline   Reply With Quote
The Following 2 Users Say Thank You to Tatsu333 For This Useful Post:
Ohio Enthusiast (11-18-2025), StraightOuttaCanadaEh (11-18-2025)
Old 11-18-2025, 11:23 AM   #7
Ohio Enthusiast
Drives: 2018 BRZ
This looks like a combination of the MCA mod (attaching to the original mounting point on the subframe) and the GP Sport mod (attaching to the frame). I wonder what side-effects this will have - it seems to be tying the subframe very rigidly to the frame.
As the price also includes arms with spherical bearings it's actually quite good. Some folks reported that trailing arms with stiffer bushings make the pickup point relocation mods shine, so this should be a nice mod.
The Following User Says Thank You to Ohio Enthusiast For This Useful Post:
Old 11-18-2025, 03:24 PM   #8
Tatsu333
I've never quite understood the argument against / around the GP Sports ones (and now these) in that regard, because there already is a stamped metal bracket / brace tying in that subframe mounting bolt to the same point that these traction mod variants do. They both just replace that piece, where it's left in place with the MCA Traction Mod.
I do like that with these vs. the GP Sports ones, there is the extra structure tying to the original trailing link mounting bolt. My worry with the GP Sports design when I was comparing them back in the day was that the relocated mounting point was just kind of floating off the end of the flat bracket, and this addresses that. Not that there is a ton of load going through that pivot, but it just made me a little nervous...
Anyway - we'll see how it goes once I receive the new setup!
Last edited by Tatsu333; 11-18-2025 at 03:28 PM. Reason: Added note about floating appearance of GP Sports vs. new brackets
Old 11-18-2025, 03:46 PM   #9
Ohio Enthusiast
Drives: 2018 BRZ
The OEM bracket only supports the bolt, not the subframe itself. The GP Sport piece has a shape that goes into the subframe bushing void and acts like a stiffer insert (compared to Whiteline KDT922, for example).
As far as I understand the concern is because all the suspension arms in the rear are mounted to the subframe, not the chassis. The GP Sport mod moves the trailing arm pickup point to the chassis, which could mess with the suspension as the subframe shifts but the trailing arm doesn't.
With that being said, I have the GP Sport mod on my car and I don't notice any issues, but I don't track a lot and only had for a year and a half and 10,000 miles.
Tatsu333 (11-19-2025)
Old 11-18-2025, 07:26 PM   #10
redlined600
Drives: Fr-s
TBH, I don't think any of the relocation brackets are optimal because they all fight the OEM design philosophy in some way or another.
I guess if you have rigid subframe mount bushings it's a moot point.
Old 11-20-2025, 07:34 PM   #11
Wes
Have you informed them of this? Perhaps they can change the type of steel being used or welding method or some other facet of the design. I would like to get one in the future
Instagram: @gt86ws
Old 11-20-2025, 09:42 PM   #12
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I’ve personally not a big fan of the way the trailing arm mounts on the GK kit to the chassis. It seems like it is putting a lot of sheer load on the mounting point even with the brace on it. Of course we haven’t see one fail so I am probably over thinking it.
Old 11-21-2025, 09:21 AM   #13
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
I would recommend some fluid film or rust protection spray, I did mine spring 24 and soaked it the day I installed it. Cleaned it up this spring to install subframe inserts and did not see corrosion.
Old 11-21-2025, 10:23 AM   #14
norcalpb
norcalpb's Avatar
The V1 MCA traction mods were poorly designed IMO. The V2 fixed this from happening though.
MCA Suspension "Traction Mod" 86•BRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 358 08-21-2025 05:10 PM
SOLD FS MCA traction mod e30cabrio Brakes, Suspension, Chassis 3 04-14-2021 12:57 PM
MCA Traction mod new in box ILLSMOQ Brakes, Suspension, Chassis 1 02-21-2021 09:27 AM
MCA Traction Mod ka-t_240 Tracking / Autocross / HPDE / Drifting 14 02-28-2019 11:56 AM
