#4551 | |
Weight Weenie
Drives: 15 FR-S
#4552 |
#4553 |
Drives: 1993 Mazda RX-7 R1, 2025 BRZ tS
I can't keep R10s quiet on the street. First bedding lasted 300 miles of mostly highway before grinding and squealing returned. Re-bedded them and the noise returned today after about 150 miles (traffic got worse).
#4554 |
For what it's worth...I'm running Endless MX72 Plus and they're quiet on the street and feel awesome. We'll see how they do over the winter but so far so good on the couple of cold mornings we've had. I'm not running brembos though.
- Andrew |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | Ruben_86_ (10-23-2025) |
#4555 |
I wonder where I can get those. Not planning an immediate switch but I am intrigued by the lower friction vs R10s. I prefer standing on the pedal more than the R10s allow.
#4556 |
#4557 |
And the Brembo cuts are cheaper? I feel so appreciated. These are certainly next on my list. Would you agree that they have less friction than R10s? Looking for something closer to stock friction with high heat tolerance. R10s are roughly .6 and the MX72 Plus are around .47. No clue what stock is.
#4558 | |
- Andrew |
#4559 |
The Dictater
Drives: '13 Red Scion FRS
Looking at the whiteline "antidive" front LCA bushings but I can't figure out how they work. As far as I can see, they rotate the LCA about the vertical axis, moving the wheel slightly forward. The effect is giving up a miniscule amount of camber for half a degree of caster. I would think increasing caster decreases the antidive geometry as opposed to increasing it from what I read. Any thoughts from the gurus?
Also general opinions on replacement front LCA bushings that are not pillowballs are welcome.
Also: "Build Thread" |
#4560 |
Track Day Junkie
Drives: 2022 BRZ Limited
My Guru, unbounded by uncertainty, wants me to ask you what you are doing. I'm not inclined to sift through 5K posts to know where you're headed with your car... or give advice when I know so little... but.
I'm curious because of the questions you ask. I'm late to this game. You seem to know a good bit already so I might learn something. I think you have it backwards about caster decreasing anti-dive geometry as opposed to increasing it. Perhaps focus on basic geometry for performance. Anti-dive is relevant for softly sprung suspensions.
Try this Jalapeno son! It ain't hot...
BLUE 2022 BRZ, Scargod's Mod's and Track Upgrades Scargo on IWSTI (Journal of STI track car-for sale) Track Day Videos on YouTube |
| The Following User Says Thank You to Scargod For This Useful Post: | Spuds (11-03-2025) |
#4561 | |
The Dictater
For reference I have an autocross DST build. RCE T2s with the standard 400/400 springs. I already have an extra degree of caster from camber plates. Rules seem to let me use offset bushings of the same type (material compliance). Do I need more caster, probably not. I could use a bit more antidive geometry since occasionally I hit the bumpstops up front on a bumpy/undulating course. I could also fix that with springs, but I'm pretty comfortable with the 400s, plus that doesn't get me a fancy new bushing lol. There are obviously other options, I'm just wondering if anyone understood why it's marketed as "antidive".
#4562 | |
Okay the bushing has 3...let's call them "features." 1. The polyurethane bushing itself. Stiffer. Tends to be a good thing, however I personally really dislike poly for bushings that pivot on more than 1 axis or twist against the axis. That bushing in particular isn't suited to poly in my opinon. Whiteline designs in some deflection which is good. Still don't like it. That said, it is likely an overall performance improvement. 2. The caster. This is done with the lateral relocation of the bolt/axis. It's no longer right through the center and it moves the wheel forward as you said. It's nice to have a little more caster. 3. The anti-dive feature. This is done with the vertical relocation of the control arm point. That might be helpful for you...I'm not sure exactly how much it changes the anti geometry though and Whiteline is not clear about that at least for this chassis. If I recall, Jackson Racing also makes a part that adds anti-dive that can be used with an OEM bushing. - Andrew |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | Spuds (11-03-2025) |
#4563 | |
The Dictater
Not sure if that vertical change is DST legal. Seems like a grey area but I'll have to read the rules again. I am pretty sure the JR solution isn't DST legal because it relocates a mount point. Edit: Looks like the ST rules specifically allow for this part in 14.8 (B and K). Might try it...
Also: "Build Thread" Last edited by Spuds; 11-06-2025 at 09:02 PM. |
| The Following User Says Thank You to Spuds For This Useful Post: | Racecomp Engineering (11-05-2025) |
#4564 |
I've been needing to re-toe the front end so this would be a good time to install an anti-dive kit, if they are worth anything.
I've installed the rear Traction Mod and been very happy with it. However, I am less convinced about anti-dive. I've had my eyes on the Jackson kit but don't really understand what it will actually do for me. There is very little in the way of reviews online. I've found a single youtube video where there was no discernable change to physical dive/compression under braking, but the review mentioned the front end was "more gooder on corner entry, fr fr no cap" or something to that effect. I'll take anything that makes the car pointier but if I don't fully understand it, then I'm worried about making some other aspect worse. |
| Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 04:17 PM |
| RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 06:31 PM |
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 09:15 AM |
| 2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 07:19 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 11:13 AM |
