go_a_way1, MisterSheep
Old 07-31-2025, 09:13 PM   #24795
Teseo
Drives: frs
Originally Posted by whataboutbob View Post
Pics. Plastic engine cowl is showing its age, lol.
You could try Griots Garage cremic trim wipes. It will revitalize the color and protect it. Use in ventilated area
The Following 2 Users Say Thank You to Teseo For This Useful Post:
Wally86 (08-05-2025), whataboutbob (07-31-2025)
Old 08-04-2025, 10:43 PM   #24796
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
I've been street driving my FA20 swapped FRS for a couple of months now and everything seems good. I reinstalled my Accusump and Verus AOS for some track days when the weather cools off. New Champiro SX tires got here today.
The Following 2 Users Say Thank You to blsfrs For This Useful Post:
KMA KiCKz (10-24-2025), Wally86 (08-05-2025)
Old 08-17-2025, 05:48 PM   #24797
StraightOuttaCanadaEh
Wes
PST Carbon Driveshaft
Instagram: @gt86ws
The Following 3 Users Say Thank You to StraightOuttaCanadaEh For This Useful Post:
2.2Lude (08-17-2025), DarkPira7e (10-18-2025), KMA KiCKz (10-24-2025)
Old 08-18-2025, 01:22 AM   #24798
HotlavaFRSGT86
Keep ICE alive+manuals
HotlavaFRSGT86's Avatar
Drives: 2015 Hot Lava 6 spd
How does it feel so far with the new driveshaft? Anything negative?
If your not first your last - Ricky Bobby
HotlavaFRSGT86 is offline   Reply With Quote
Old 08-18-2025, 11:24 AM   #24799
Wes
Nothing at all! I don't know how you look at extra noise but there is a bit of whine, which I used to have before with an aluminum driveshaft from DSS so I actually kinda missed that. Rev matching seems a bit easier for some reason (I have a lightweight flywheel) and flywheel chatter when decelerating in 5th seems to be lessened also.
Instagram: @gt86ws
The Following 4 Users Say Thank You to StraightOuttaCanadaEh For This Useful Post:
blsfrs (08-18-2025), HotlavaFRSGT86 (08-18-2025), orz (08-19-2025), Wally86 (08-18-2025)
Old 08-18-2025, 07:54 PM   #24800
HotlavaFRSGT86
Sounds great man, i've thought about doing a lw driveshaft, but don't know if i will ever do so. I've done enough over the last 10 yrs i suppose. The last thing i really wanted to do was drop the 4.10s and put in 4.56s but ultimately abandoned that idea. I'm working on going back to my roots and getting another 60s/70s car, i will keep my FRS though.
The Following User Says Thank You to HotlavaFRSGT86 For This Useful Post:
StraightOuttaCanadaEh (08-19-2025)
Old 08-29-2025, 07:11 PM   #24801
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Swapped front and rear sway bar bushings. Fronts were pretty toast after 180k km.
The Following 5 Users Say Thank You to RToyo86 For This Useful Post:
Dadhawk (08-30-2025), HotlavaFRSGT86 (09-18-2025), KMA KiCKz (10-24-2025), norcalpb (09-06-2025), Wally86 (09-05-2025)
Old 09-18-2025, 12:41 AM   #24802
HotlavaFRSGT86
Wow what a curve!!
Did a tint/sun strip this afternoon. Really can't tell what a curve our windshields have until you do a strip. Measures 6" in the center to the spot just below the black ceramic dots all the way to 8-1/8" at the far right or left. Messed up the first try cause a gust of wind had to blow just as i was lifting it off to apply inside and got crinkled. I think it turned out great, i should've had the tint shop do a strip for me yrs ago when i had all the others done, but the satisfaction of doing it yourself is wonderful. My Rav4 was much easier, not nearly as curved.
The Following 2 Users Say Thank You to HotlavaFRSGT86 For This Useful Post:
blsfrs (09-18-2025), KMA KiCKz (10-24-2025)
Old 09-18-2025, 10:36 AM   #24803
smackrel
Full Throttle!
Drives: 17 CBSP Limited PP
Were there any symptoms that lead to you replacing this? I have noises from my front end and wondering if this is the cause.
smackrel is offline   Reply With Quote
Old 09-18-2025, 01:02 PM   #24804
Compelica
Compelica's Avatar
Drives: 86 GT
You'd hear and feel some clunks when darting left and right. Bushings aren't expensive, and would be considered a wear item.
I changed mine after 130k kms and the expansion didn't look as bad as @RToyo86 but the clunks were getting to me.
DIY stuff at Compelica Works
Compelica is offline   Reply With Quote
The Following User Says Thank You to Compelica For This Useful Post:
smackrel (09-18-2025)
Old 09-18-2025, 04:27 PM   #24805
RToyo86
RToyo86's Avatar
In my case there was no obvious symptoms. I knew they would be tired given the mileage, and track days I've done. Trying to dial in cars handling, and refresh the rubber bits to get a proper baseline.
Next part will probably be front control arms, hardrace arms or OEM.
The Following 2 Users Say Thank You to RToyo86 For This Useful Post:
Dadhawk (09-18-2025), smackrel (10-20-2025)
Old 10-18-2025, 01:39 PM   #24806
RToyo86
RToyo86's Avatar
New wheels installed. Nice to be on "comfy" street tires again.
The Following 10 Users Say Thank You to RToyo86 For This Useful Post:
blsfrs (10-18-2025), cmiovino (10-21-2025), Dadhawk (10-18-2025), DarkPira7e (10-18-2025), KMA KiCKz (10-24-2025), RickyBobby (10-25-2025), Stephen W. (10-18-2025), StraightOuttaCanadaEh (10-21-2025), SuperTom (10-18-2025), Teseo (10-19-2025)
Old 10-25-2025, 11:24 AM   #24807
RickyBobby
Drives: 2013 Firestorm FR-S AT
New wheels installed. Nice to be on "comfy" street tires again. /
I have these https://www.bfgoodrichtires.com/auto...omp-2-a-s-plus Only 20K miles on them and almost down to the wear bars, 45K mile warranty but out since just over 6 years old.
My next tires will be "comfy" ones too.
RickyBobby is offline   Reply With Quote
The Following User Says Thank You to RickyBobby For This Useful Post:
Dadhawk (10-25-2025)
Old 10-25-2025, 04:51 PM   #24808
TStafford
TStafford's Avatar
Drives: 2015 FR-S Ultramarine Metallic
Removed rear glass tint. Got 95% of the glue removed but I will need to go over it again. At 6' 4" the back seat is kinda tight. Old tint was starting to bubble and I never liked it anyway.
TStafford is offline   Reply With Quote
The Following 4 Users Say Thank You to TStafford For This Useful Post:
blsfrs (10-30-2025), Dadhawk (10-25-2025), pope (10-29-2025), Stephen W. (10-26-2025)
