#57 |
I needed SPL short endlinks with Tarmac 2s and TRD bar. Links JUST kiss the back of the strut at full lock.
#58 |
Drives: Toyota GT86
#59 |
Drives: GR86 2022
I used a endlink made for Kia (215mm ish). Length and shaft thickness clears shock body (kw 1 way), control arm and all chassis common contact spots...up to about -4.2 camber before endlink cap starts making contact with wall. (max on crash bolt and top hat) on trd 21mm and perrin 22mm (forgot position used).
#60 |
Definitely recommend adjustable endlinks with adjustable swaybars or if you're corner balancing the car.
- Andrew |
#61 | |
Drives: 20’ GT86
As you may remember from the other thread, I will be running corner balanced V3s with a 20mm drop on stock sway bar and end links. Is that an order for me to spend more money? (I don't take those lightly [have already ordered the 60-170 at your indirect direction ])
| The Following User Says Thank You to KiK For This Useful Post: | J95 (01-23-2024) |
#62 | |
Drives: None
Make sure you also index your end link rod ends / ball joints so that they don't bind. It seems like it is extremely easy to get into end link issues with these cars in a way that causes binding or contact, a lot of manufs on both sides (coilovers and endlinks) seem to get it wrong. Length is important too. I've seen contact in the following ways, I'm sure there are more: 1. Sway bar to LCA 2. Endlink to chassis behind coilover 3. Endlink to bottom of strut when turning the steering wheel This can cause weird stuff like power steering cut out, sudden understeer under certain situations, broken endlinks, etc.
| The Following 3 Users Say Thank You to RedReplicant For This Useful Post: |
#63 | |
With adjustable swaybars which have different mounting holes, it helps to have adjustable endlinks to make sure you don't have rubbing issues. And to do a perfect corner balance, you need adjustable swaybars to make sure there's no preload on the swaybar. - Andrew |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | J95 (01-23-2024) |
#64 | |
#66 |
haha I have to wait 1 month or so to install it
but FYI some guys from Germany told me that it should work with OEM links with a drop of up to ~40mm. More than that you would need longer links in the front, not shorter |
#67 |
Drives: 2017 BRZ PP, 2004 WRX
Reviving this thread for 2025... in frustration.
I have RCE SS-1's and a Perrin 19mm front bar. The Perrin bar works great at stock height, but in the recommended range for the SS-1's, the Perrin bar just contacts the control arm slightly with the OEM endlinks. I actually had the Perrin endlinks with the stock struts, but with 4 degrees of camber, they didn't fit between the strut and chassis because the bushing are too fat and they marred the chassis up. I bought some adjustable endlinks and set them up about 1.0-1.5" shorter than stock. Installed them and had a hell of a time due to various reasons. Lower the car and now there's tons of clearance between there and the control arm, but between the bar and the chassis at the top like some pictured there's likely less than 1" from what I can feel with my finger. I'm betting the first time I pull it out of the garage or do any hard cornering with it it's going to bend the shit out of the chassis there now too... probably worse contact than the slight dings I hear with the control arm. I really think it's the design of the Perrin at the curve and with the way the positioning holes are as I'm seeing a lot of people have issues here. I also found at full lock in the soft position hole the end link gets twisted and contacts the strut body... so you can't run it on soft at all apparently with coilovers. So again, frustrations with the Perrin design all together.
#68 |
Update on this.
Watched a bunch of Youtube videos and this one guy that tracks his black gen 2 was installing a Karcepts bar and basically tried getting the endlink as long as possible, BUT keeping it above the control arm at full droop (aka, wheel off, in the air when installing). Basically if yours is below or parallel with the control arm, which it moves, it can likely still contact the control arm slightly. On the flip side, if you put it way above the control arm to get around that issue, you'll likely end up contacting the chassis where the bar curves like someone pictured in this thread. They key is keeping it right above the control arm at full droop by about 1/2", but also keeping it low enough to give you room at the top. This should fix any contact issues when working with any coilovers and ride heights if you follow that general advice. I was sort of thinking shorter is better, right? Well when you put the car on the ground, you gain a ton of space between the control arm and control arm, so you really don't need loads of space there. Just "enough". Mine has about 1/2" at the control arm at full droop and about 1" at the top between the bar and chassis with the wheel on and at rest. Driving around and hitting some bumps and dips, it's not contacting at the top and I don't appear to be hitting at the bottom anymore. The endlink was set 1" shorter than stock to achieve this with a KW based coilover (again, just general advice). Also, don't work on your car at 10pm at night after a work day. You'll just get frustrated at stupid stuff. Hope it helps!
| The Following User Says Thank You to cmiovino For This Useful Post: | Tatsu333 (04-18-2025) |
#69 |
@cmiovino For an additional data point, my findings were the same on my set up when troubleshooting the OEM endlinks contacting the FLCA's. Apologies for the out of focus pictures.
Not a KW based coil over but still relevant IMO. |
#70 |
I can't speak to the Perrin swaybar in particular, but "as long as possible without hitting the LCA" is my general recommendation.
We actually now have our own RCE endlinks available. I've been working on these for a looooong time lol. Trying different components and rod ends and lengths etc. https://www.racecompengineering.com/...-brz-fr-s-gr86 ![]() - Andrew |
| The Following 7 Users Say Thank You to Racecomp Engineering For This Useful Post: | 2.2Lude (04-17-2025), autoracer86 (04-17-2025), NoHaveMSG (04-17-2025), Ohio Enthusiast (04-19-2025), Ruben_86_ (04-22-2025), Tatsu333 (04-18-2025), Tokay444 (04-18-2025) |
| ISO Front sway bar and end links | vladniko86 | Want-To-Buy Requests | 0 | 05-30-2019 03:59 PM |
| Front Sway bar end links | rick s | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 08-10-2015 12:33 AM |
| Need help! coilovers/sway links issue | P_say86 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 03-19-2015 09:35 PM |
| WTB: Whiteline Front sway bar Links. | Filipino Royale | Brakes, Suspension, Chassis | 0 | 08-06-2014 03:46 AM |
| Stance super sport coilovers with front sway bar end links 900.00 | kimchangil424 | Brakes, Suspension, Chassis | 4 | 02-06-2013 03:25 AM |
