Old 12-11-2024, 07:36 PM   #1
vindiesel
vindiesel's Avatar
Drives: 2023 brz limited 6mt red
Noobed Jack lift point
3rd oil change first one done by me due to dealers either leaving globs of oil on my paint and the last dealership lifted my car wrong and the lift fingers gouged my side skirts.
I saw the jack point online and I’m mentally burnout from work and In a hurry. I lifted the car with my jack with rubber guard on just behind the oil pan on that subframe. (I know you’re supposed to use the very front location after inspection) 🤦🏻*♂️. That’s not an issue right? Thanks for your time
2023 brz red limited 6mt 10k miles ish
2009 Chrysler 5.7l hemi eagle 300c heritage edition 205k miles
vindiesel is offline   Reply With Quote
Old 12-11-2024, 10:08 PM   #2
Ohio Enthusiast
Drives: 2018 BRZ
You did that through the aluminum skid plate? I'm not sure what's the gap between the skid plate and the subframe rail there. There's also the steering rack slightly more to the back. If it didn't feel like you buckled anything and there were no noises when lifting, I'm guessing you're okay. Perhaps the skid plate helped distribute the load.
You can remove the skid plate (and potentially the transmission cover as well) to inspect and take photos of the rail.
Old 12-12-2024, 03:46 AM   #3
vindiesel
vindiesel's Avatar
Yeah it lifted fine and I won’t ever do that again. Thank you!
GF ran over median. Smooshed front jack point. Devante Scion FR-S / Toyota 86 GT86 General Forum 4 05-06-2024 12:32 AM
Engine lift point redlined600 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 03-08-2023 03:38 PM
Pinch weld jack point protector Pat BRZ Second-Gen (2022+) — General Topics 14 01-05-2023 02:14 AM
How to safely lift engine using hydraulic jack? Plumbus Engine, Exhaust, Transmission 7 12-07-2020 01:57 AM
DIY Oil Change: Brand of oil you use and method you use to jack/lift PPX Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 24 08-22-2014 12:09 PM
