#15 |
Drives: 2013 frs base
I have the 2.5" catted Nameless OP/FP with the resonator. I ground off a piece of the engine block for better clearance. I can see where the 3' version would be a real PITA to get in.
#16 |
Drives: Crapcan
Yeah, I have the 3”. I find the easiest way to get it in is to jack the passenger side of the car pretty high up so you have room to twist it around to work it into place.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | blsfrs (12-01-2024) |
#17 |
Drives: 17 Asphalt 86
I have that exhaust setup you are considering. I kept OP and front pipe as modular pieces. I figured if I need to switch FP out I can leave the aftermarket OP in which makes life easier.
JDL 4-2-1 Locally built 2.5" OP and 2.5" ultra quiet spec FP CSG touring CSG just did a revision to their touring exhaust. I'll be getting once shortly actually to replace the current one. Setup overall is perfect IMO, seats down you get enough exhaust noise. |
#18 |
The Dictater
Drives: '13 Red Scion FRS
Thanks all for the input. I wound up ordering the front pipe separately and am planning to pick up a used OP for the same reason RToyo86 mentioned, plus it's easier to sell down the line if I need to.
Also: "Build Thread" |
| The Following 3 Users Say Thank You to Spuds For This Useful Post: |
#19 | |
The Dictater
| The Following User Says Thank You to Spuds For This Useful Post: | blsfrs (12-01-2024) |
#20 |
Not entirely sure on the specifics but they worked with MXP to fix the baffle failures that can occure. I have a mild baffle failure that I can hear when the muffler gets hot. A bit of buzzing around 2-3k rpm.
| The Following User Says Thank You to RToyo86 For This Useful Post: | Spuds (12-01-2024) |
| Individual Racing Parts (IRP) V3 Short Shifter Rattle Thread | Shadow_ | Tracking / Autocross / HPDE / Drifting | 50 | 08-15-2023 10:56 AM |
| WTB: Exhaust Parts 3" Catback & Overpipe / Frontpipe combo | Dillydallen | Want-To-Buy Requests | 1 | 04-12-2018 10:28 AM |
| New RACING short shifter from Individual Racing Parts | Tor | Engine, Exhaust, Transmission | 161 | 12-20-2017 08:07 AM |
| Individual 3M Clear Bra parts | DoomsdayJesus | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 8 | 08-09-2013 11:34 AM |
| The individual age poll | tranzformer | Scion FR-S / Toyota 86 GT86 General Forum | 41 | 01-05-2012 03:01 AM |
