Old 09-17-2024, 10:26 PM   #1
Spocknasty
Spocknasty's Avatar
Drives: '13 BRZ Limited / 76' 914 1.8T
1st Gen FR-S / BRZ Sprintex 210 Supercharger Kit (Intercooled)
For sale is this Sprintex SC kit with Intercooler with the factory pulley size. This kit has less than 2,000 miles on it. It felt and sounded great. Alas, my high mile car developed rod knock and the supercharger was pulled when the motor came out. Sucks for me, but this is great for you. The kit is in practically new condition. A factory throttle body and MAP sensor are installed on the supercharger. The weak plastic 90 degree elbows that came on the kit have been replaced with brass fittings to prevent you from ever worrying about those failing. Some of the kit is already installed as you can see which should make your install quicker and easier. You are spared spending an hour removing the sealing tape on the manifold outlets and throttle body that was a nightmare to get off.
NOTES: New pieces being provided and on the way from Sprintex and not pictured:
  • BRAKE BOOSTER HOSE ASSEMBLY
  • QUICK FIT 4mm x M5 MALE - ELBOW 90 DEG (actuator rubber connect for boost line)
  • SHCS M6x0.8x12-ZP x 2 (water pump to engine block - clean / chase those threads on the engine before install) 300mm Long X 8mm
  • Wide Heavy Duty Cable Tie (for water pump to water pump bracket)
Included but not pictured:
  • EVAP solenoid relocation bracket
  • Fuel line relocation bracket
An ECU Tune is NOT provided - I recommend using Mike at https://xero-limit.com/ and an EcuTek cable he can provide.
I'd prefer not to ship but will at cost to the buyer. I can foam pack the unit but shipping will be at least $100. All that said, this is a great discount at $,3400 for a like new kit as MSRP was $4,695.00 USD.
Automotive photo and video
www.mikespock.com
Spocknasty is offline   Reply With Quote
Old 09-17-2024, 10:30 PM   #2
Red_Tannins
Drives: 2013 FR-S Ultramarine
Location?
Sent from my Pixel 8 Pro using Tapatalk
Red_Tannins is offline   Reply With Quote
Old 09-18-2024, 07:59 PM   #3
Spocknasty
Spocknasty's Avatar
Originally Posted by Red_Tannins View Post
Location?
Philadelphia area.
www.mikespock.com
Old 09-25-2024, 12:17 AM   #4
jflogerzi
jflogerzi's Avatar
Will vouch for this kit. On e85 is great on Street and Canyon drives. The Bell Curve Dyno Graph will back up this claim. Do not run this kit on the track. With IC will still heat-soak. GLWS!!
2013 Series 10 FRS #553
Old 10-21-2024, 10:43 PM   #5
Red_Tannins
I'm still interested, check your PMs
Old 10-29-2024, 07:42 PM   #6
Spocknasty
Spocknasty's Avatar
SOLD
www.mikespock.com
Old 10-30-2024, 10:08 AM   #7
my10x
Drives: 20 Brz
Thanks to whomever saved me trouble with my better half...
my10x is offline   Reply With Quote
Sprintex S5-210 intercooled supercharger kit + other goodies!!! Stranger5150 Engine, Exhaust, Bolt-Ons 16 06-23-2021 01:55 AM
FS: Sprintex (Innovate) supercharger (non-intercooled) dpgfunk Engine, Exhaust, Bolt-Ons 10 05-02-2015 06:01 AM
