Old 10-07-2024, 09:20 AM   #169
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Organized our local FT86 club Fall cruise. Worked with a local garage/race shop bad habit garage that is Active calabogie motorsports park who arranged a parade lap for everyone attending.
27 cars total showed up which is always fantastic to see. Took scenic backroads up to the track, parade lap, then bad habit and CMP offered passenger rides to people to experience the track at pace.
LS swapped race car
The Following 3 Users Say Thank You to RToyo86 For This Useful Post:
JD001 (01-01-2025), Racecomp Engineering (10-07-2024), villainous_frx (10-13-2024)
Old 10-27-2024, 10:39 AM   #170
RToyo86
RToyo86's Avatar
Last organized track event of the year at calabogie motorsports park. I was finally able to make time to get my solo sign off. Should give me more opportunities to track next year
Car performed pretty well, wasn't a fan of 225/45 RS4 on stock wheels. Ordered a set of circuit csf1 17x9 +35s and will swap the tires over for next season.
Ended up doing three 30 minute sessions with half hour between each. skipped the last two sessions to persevere the car and let it cool down.
Nice shot from local photographer corner2collective
KMA KiCKz (10-28-2024), Racecomp Engineering (10-28-2024), villainous_frx (10-28-2024)
Old 11-04-2024, 09:11 PM   #171
RToyo86
RToyo86's Avatar
Picked up CSF1s from the border, then immediately ceramic coated them in the garage. Now to decide whether to run these or RPF1 for track duty. SBC coating is a bit rough.
The Following 2 Users Say Thank You to RToyo86 For This Useful Post:
spcmafia (01-24-2025), villainous_frx (11-05-2024)
Old 12-31-2024, 05:22 PM   #172
RToyo86
RToyo86's Avatar
Couldn't resist a sale, RCE SS1s ready to install. Thanks Andrew for coilover covers!
Also bought a gently used mishimoto thermostatic oil cooler, and have a 200F thermostat to swap in. Probably won't be til March once snow goes away and temps come up
The Following 4 Users Say Thank You to RToyo86 For This Useful Post:
Racecomp Engineering (01-03-2025), spcmafia (01-24-2025), Stonehorsw (04-19-2025), villainous_frx (12-31-2024)
Old 01-03-2025, 10:43 AM   #173
RToyo86
RToyo86's Avatar
Swapped in oem pads a while back and sold both sets of hawk 5.0 and HP+ pads.
Ordered endless MX72 plus to try out. Not sure if I'll run them year round, may just swap them in when I want to do some light lapping sessions. Want a pad that won't eat rotors daily driving, doubt I'll find anything as good as OEM for the job.
The Following User Says Thank You to RToyo86 For This Useful Post:
villainous_frx (01-04-2025)
Old 01-03-2025, 01:37 PM   #174
Yayyyyy!
Old 01-03-2025, 02:21 PM   #175
Teseo
Drives: frs
You could try TRD pads
The Following User Says Thank You to Teseo For This Useful Post:
RToyo86 (01-23-2025)
Old 01-23-2025, 04:16 PM   #176
RToyo86
RToyo86's Avatar
Installed fresh OEM rear mounts and adjusted collars to base spec as per @Racecomp Engineering recommendation.
I've contemplated tossing them on despite Ottawa winter but thinking I'll wait a bit longer.
Not a bad idea. Curious if the GR spec pads fit the bill as well.
spcmafia (01-24-2025), Stonehorsw (04-10-2025), villainous_frx (01-24-2025)
Old 03-13-2025, 08:53 PM   #177
RToyo86
RToyo86's Avatar
Out with the old.. Need to find tune ride height once it settles. Currently 1.5" drop, aiming for 1.25".
JD001 (04-19-2025), KMA KiCKz (03-14-2025), villainous_frx (03-16-2025)
Old 03-21-2025, 12:42 PM   #178
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
How are you liking the new shocks ?
autoracer86 is offline   Reply With Quote
Old 03-21-2025, 08:12 PM   #179
RToyo86
RToyo86's Avatar
I'm happy with the upgrade, the car is slightly less comfortable on typical less than ideal road surfaces vs yellow/B6 which doesnt surprise me. More spring rate+ camber plates will be a trade off.
Yesterday it was corner balanced and aligned. Still have winter tires on so I can only get an idea of how the car behaves with low grip threshold but chassis is very predictable when I've had a chance to load up suspension on some favorite corners near my place. Went two clicks softer than rce base street settings to deal with our destroyed roads from a cold winter. Will revisit once I get my RPF1s back on in a few weeks.
autoracer86 (03-22-2025)
Old 03-22-2025, 03:55 AM   #180
autoracer86
Drives: Toyota GT86
Thanks for the detailed reply. Sounds good so far then
The Following User Says Thank You to autoracer86 For This Useful Post:
RToyo86 (04-03-2025)
Old 04-05-2025, 01:04 AM   #181
RToyo86
RToyo86's Avatar
Booked track day on the 12th at Shannonville. In preparation did pads, rotors, fluid and OEM lines. Went with endless MX72+.
Swapped my enkeis back on as weather is decent for next week or so. Roads are still cold but got a feel for suspension setup. Car is feeling hooked up.
The Following 5 Users Say Thank You to RToyo86 For This Useful Post:
autoracer86 (04-06-2025), KMA KiCKz (04-15-2025), new2subaru (04-08-2025), Stonehorsw (04-10-2025), villainous_frx (04-11-2025)
Old 04-15-2025, 04:17 PM   #182
RToyo86
RToyo86's Avatar
Track day on Saturday was a success. We were the first event of the year, track was very green and the day starting off cold(3c) and wet. Drifted corner 2 doing 55kmh on my outing lap .
The track was mostly dry by the afternoon sessions and speeds and grip were much better to test out new setup. Car was extremely predictable and managed a 2:05 which I'm told is decent, considering felt mostly like a shakedown day learning track and the car.
Hired a on track photographer at the event who took some fantastic shots. Links below for more pics
https://imgur.com/a/a98YUok
https://imgur.com/gallery/eQWBaa8
KMA KiCKz (04-15-2025), Racecomp Engineering (04-17-2025), villainous_frx (04-18-2025)
Drift shoot with Ryan's 2jz FRS Amillionoh7 Scion FR-S / Toyota 86 GT86 General Forum 0 07-28-2016 11:11 AM
Ryan Tuerck shift knob ChrisP Cosmetic Modification (Interior/Exterior/Lighting) 12 01-22-2016 09:38 PM
Ryan Tuerck’s Street FRS Sideways&Smiling Scion FR-S / Toyota 86 GT86 General Forum 1 10-01-2014 12:07 PM
Ryan Higa owns an FRS? tekkenman Off-Topic Lounge [WARNING: NO POLITICS] 13 06-21-2013 07:48 PM
FAO Ryan GeeTee86 AFRICA 4 05-31-2013 11:46 AM
