| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Drives: Subaru BRZ pearl White
Act pressure plate wear (hard/hot spots
I'm currently doing some clutch work due to deciding to swap out a act light weight flywheel. Unfortunately I found these hot spots on the pressure plate and was concerned. The clutch pressure and friction plate is only about 3 months old. The pressure plate is smooth, so I was thinking it is fine, but I'm seeing and herd hotspots like this has ruined the clutch. What do you guys think?
#2 |
Drives: 2013 frs base
What kind of disc are you running and what does the flywheel look like? Looks like a lot of heat. Was it slipping?
| FS - Stock Clutch Flywheel/Friction Plate/Pressure Plate and Clutch Release Arm | jnorloff21 | Transmission and Driveline | 0 | 04-28-2022 11:43 PM |
| Taillights with hard water spots inside | Jajanken86 | Cosmetic Modification (Interior/Exterior/Lighting) | 9 | 03-31-2017 02:35 AM |
| how to remove hard water spots | DarkestBuddha | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 16 | 08-10-2014 07:53 PM |
| Stock clutch+flywheel+pressure plate+ ACT lightweight flywheel & pressure plate | PineappleFriedRice | Transmission and Driveline | 0 | 11-08-2013 05:54 PM |
| Hard water spots | Double4Free | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 2 | 07-01-2012 11:14 AM |
