Old 06-05-2024, 09:35 PM   #309
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
So, I've been still hearing a hissing sound on throttle. Went looking for leaks. I found one (I think ?) at the donut gasket, probably because I just reused the original. Maybe it's time for a catback since I gotta get a gasket anyway
Also, the fix for the undertray didn't hold. Thinking of trying out JB Weld fiberglass wrap to hold it. Or maybe I should just give in and get another one.
Also: "Build Thread"
villainous_frx (06-07-2024), Wally86 (06-07-2024)
Old 06-09-2024, 09:36 PM   #310
Spuds
The Dictater
Spuds's Avatar
So it turns out the front pipe flange is very pitted where the donut gasket seals, or doesn't seal in this case. Cleaned it up as best I could with a file, but getting it actually flat is going to take precision grinding/machining. I of course did the logical thing and tried some high temperature rtv. Waiting for that to cure, hopefully it works.
spcmafia (09-10-2024), Ultramaroon (06-10-2024)
Old 06-09-2024, 10:02 PM   #311
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
It should. Mine wasn't that bad, but my Borla catback wasn't sealing with the stock donut gasket. Tried a replacement, new Felpro one. Same issue. Tried adjusting the spring bolts around, etc. Nothing worked.
I used Permatex red gasket maker. Slathered the donut gasket in it, tossed it, clamped it down, and waited 24 hours. Perfect seal.
I was actually under my WRX today and the previous owner installed a Cobb turboback over 10 years ago. Glanced to see if there was any gasket maker. Sure enough, there were traces of it.
If I ever do any exhaust installs in the future, I'll be using some sort of gasket sealer. I've sort of always been against it because the gasket should seal itself, right? But it just works. At least a little pinch doesn't hurt.
cmiovino is offline   Reply With Quote
The Following User Says Thank You to cmiovino For This Useful Post:
Spuds (06-09-2024)
Old 06-09-2024, 11:56 PM   #312
Spuds
The Dictater
Spuds's Avatar
Well that worked for about 2 minutes. Or there's another leak. It's really not that bad I tell myself. I'll figure it out eventually.
The other thing I did was make another attempt at repairing the transmission cover undertray. Used some jbweld fiberweld in segments /layers. It was about as frustrating as I remember composite layups being from 15 years ago but it seems like it will work. Hardens well with a strong bond, drillable, cutable, sandable which is good cause I had to do all that to make stuff fit. Rated for 400°F, should be fine on the left center hole, a bit away from the exhaust. Stuck some gorilla tape around it because it seemed like the thing wmto do. Next time I just try to order a replacement...
The Following User Says Thank You to Spuds For This Useful Post:
villainous_frx (06-10-2024)
Old 09-05-2024, 06:50 PM   #313
Spuds
The Dictater
Spuds's Avatar
Long time no update.
Last time I adjusted height was way back here:
https://www.ft86club.com/forums/show...&postcount=128
That's roughly 352mm. Now my ride heights are 336F/342R (ignore any other measurements I posted, these are actually correct)
Looks like the car settled 16mm (over 0.5"!) for one reason or another. Very good to know for future reference. Was wondering why I was plagued by inconsistent understeer this year. Not sure if this is normal...
villainous_frx (09-07-2024)
Old 09-08-2024, 11:03 PM   #314
Spuds
The Dictater
Spuds's Avatar
Ok learned some hard lessons about roll center. At the lower-than-expected ride height, the car would be really lazy up front and not really fun to drive at all, then understeer as it leaned over and lost camber.
Raised to a new empty ride height to 341mm front and 345 rear, offset a bit side to side to account for my fat arse. With my weight in the driver's seat it's at 339mm front and 341mm rear.
Also installed a Perrin 16mm rear bar at medium setting, replacing my 14mm stock bar. Geometry on the medium setting looks identical to stock btw.
Went for a drive and the car drives completely differently now. Much more neutral at street levels of speed at least, and the front end is now quite quick. It even solved some of my low speed turning inconsistencies. Might have not needed the rear bar even. I'll see how it goes at the next event, but may dial it back to the soft setting assuming the endlink geometry will accommodate it. I might also lower the front 1mm at the same time just for visual flatness when I have a passenger lol.
Still needs an alignment but the car is fun to drive again!
The Following 6 Users Say Thank You to Spuds For This Useful Post:
autoracer86 (09-09-2024), cmiovino (09-11-2024), JD001 (09-17-2024), NoHaveMSG (09-08-2024), spcmafia (09-10-2024), villainous_frx (09-11-2024)
Old 09-16-2024, 10:07 PM   #315
Spuds
The Dictater
Spuds's Avatar
Ok so new ride height and alignment numbers, millimeters from center of wheel to arch, and degrees:
Empty, no trunk junk, 1/4 tank of gas:
FL: 341.5 FR: 339.5
RL: 347 RR: 345
F Toe: 0
R Toe: -.01 (out)
F Camber: -4/-3.8
R Camber: -2.2/-2.1
Plus 200lb driver weight:
FL: 338 FR: 338.5
RL: 341 RR: 342
F Toe: 0
R Toe: +0.01 (in)
F Camber: -3.9
R Camber: -2.3
Interesting notes:
-Looks like with standard 7k/7k rates on the T2s, the front lowers at ~50% the amount of the rear when front seat(s) is occupied.
-Not entirely sure how I gained camber going higher in the front, but maybe something else was going on with ride height last I did an alignment.
-Goes around corners way better this way.
Also ran the Perrin 16mm rear bar on medium.
Overall this setup felt really good at my last AX. Might drop the rear bar down to soft though, as I got just a bit more oversteer tendency than I wanted. It was fast enough for a top 10 raw time though so I'm pretty happy.
autoracer86 (09-17-2024)
Old 11-19-2024, 08:11 PM   #316
Spuds
The Dictater
Spuds's Avatar
Haven't updated in a while...
Yes, soft on the rear bar was even more excellent. Brought the oversteer under control just a bit. Result is my first top 5 raw time finish at a PCA AX. 2nd if you count PAX-adjusted time. Having a co-driver on a cold day helps lol.
Winter upgrades!
-new tires. Really liked the RE71RS, considering another set if a sale/rebate shows up. But I could try RT660s $200 less and see how they act.
-exhaust. need to either fix the donut gasket flange on the stock frontpipe, or possibly get the fancy overpipe/fp combo JDL makes (please someone talk me out of it). Also looking at catbacks finally.
-actually get off my arse and dial in the tune...
-I DO NOT need a BBK. I do not need a BBK. I...
bcj (11-20-2024), Racecomp Engineering (11-20-2024)
Old 11-20-2024, 11:38 AM   #317
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
Haha same
autoracer86 is offline   Reply With Quote
The Following User Says Thank You to autoracer86 For This Useful Post:
Spuds (11-20-2024)
Old 11-21-2024, 11:28 PM   #318
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
For the gasket issue try adding copper RTV first. I use it on every flange and never have leaks even when I've reused old gaskets I should have tossed.
The Following User Says Thank You to RToyo86 For This Useful Post:
Spuds (11-22-2024)
Old 11-22-2024, 12:20 AM   #319
Spuds
The Dictater
Spuds's Avatar
Yeah did that over the summer hoping to fix it. Still getting some hissing while on throttle. It COULD be somewhere else, but the soapy water test says everywhere else I can see is good.
RToyo86 (11-22-2024)
Old 11-22-2024, 05:45 PM   #320
cmiovino
cmiovino's Avatar
Funny enough on the BBK, I have the performance pack because Brembos are better, right? Well, basic rotors are larger and heavier, which is rotating mass. So unless you're going with lightweight, two piece ones, the whole setup is likely hurting acceleration. Just my 2 cents.
Interesting on the RE-71RS comment. I drove a gen 2 (DS) on them and placed 3rd in PAX at a local in one run. They were good. Easy to drive. I run the Yoks on my STX setup and although they're faster on paper at Nats and whatnot, they're always kinda 'meh'. They're peaky and not consistent I feel. Beside what I just stated, why aren't Yoks in the mix for you?
No-go on the 660's. They're a noticeable step under REs or Yoks. I absolute hated them and had one of my worst seasons on them. They also heat cycled really quick.
Spuds (11-22-2024)
Old 11-22-2024, 11:06 PM   #321
Spuds
The Dictater
Spuds's Avatar
Yeah my friend runs yoks and he does quite well on them, but he definitely gets overheating problems towards the later runs in the summer. We usually get 5-7 runs and you gotta get the amount of spray just right or they are too cold or too hot.
Plus the re71rs is less expensive and often has a rebate on TR too.
Would only ever get a 2-piece BBK that saves weight, really the main reason I (definitely don't) want one for my uses. If I decide to start tracking the car I will probably get an AP kit because then I have 2 reasons to get one.
Old 11-30-2024, 05:11 PM   #322
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Winter upgrades!
Are you allowed to run roll center correction? Makes a big difference.
Unless you are going through pads at an alarming rate, I wouldn’t worry about BBK. You can buy a lot of tires and entries for what one costs.
Spuds (11-30-2024)
2018 Camaro SS 1LE vs Spuds' FRS Spuds FR-S / BRZ vs.... 13 06-16-2019 11:11 PM
FRS from Vroom - RISKY? Cosa Scion FR-S / Toyota 86 GT86 General Forum 14 10-21-2018 10:27 PM
So my key FOB was put in the washing machine.... Kayzer Soze BRZ First-Gen (2012+) — General Topics 11 06-07-2013 12:43 PM
Vroom! - This week's blipshift shirt blipshift Miscellaneous 1 11-13-2012 11:29 PM
