| GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86 |
Drives: White FR-S kosei k4r 17x8
Drove over 3k miles with only 4 quart of oil how bad is it
Normally I'm pretty good with topping up oil between oil changes, but got busy with work, didn't change oil for about 8 months with about 8k miles since last change.
Today when I changed the oil and dip stick didn't even get any oil. only got 4 quarts of oil out of it. Though the oil looked light brown and not black at all. I estimate I probably drove about 3-4k miles with oil well below the dipstick low level. I drive the car pretty hard. How bad is it? It's a 2013 frs with about 50k miles |
#2 | |
Sarcastic SOB
We cant tell you if you damaged your motor by neglecting to maintain a minimal oil level, but Im pretty sure that if you caused any problem, your engine will tell you. Or more likely, accelerated wear and living on the edge will b to the detriment of the next owner who will have no clue until the engine starts making noises or other issues. The car is your property and you can do that if you want to, but I doubt you would tell this to the next owner, would you? THAT, I have issues with. TL;DR. Good work! Extreme neglect with anything can only lead to bad things, but don't worry.
#3 |
22R
Drives: 2012 Camry SE 2017 Toyota 86
With 4 quarts in it I doubt you hurt anything.....just don't keep doing it.
22R |
#4 |
Drives: 2020 BRZ tS
I assume these have a low-oil warning light.
At what level does that come on? |
#5 |
Rust bucket enthusiast
Only when pressure is far too low. If you're driving and it comes on, you're probably already past the point of no return
#6 |
Famous Potatoes
Drives: '15 ultramarine
I would be more worried about why you're burning/losing so much oil in 8k miles.
#8 |
Drives: 2020 BRZ tS
Intriguing. What's the point of even having a warning light then?
#9 |
These things should come with instructions for their owners. They could be called Owner's Manuals.
| The Following 3 Users Say Thank You to Ultramaroon For This Useful Post: |
#10 |
Sarcastic SOB
Considering these cars take 5.4 L of oil, only draining 4 L means you're 25% low. Again, if you don't give a shit that's great, but would you have the ethics to not resell the car without disclosure of such things? Likely not. So, your carelessness might be to the detriment of the next owner.. People do dumb careless shit.
I'm especially dumbfounded when it's an enthusiast that visits this site, who usually would care more not less.
#11 |
#12 | |
She had been driving her Tercel like that for at least a year before it died. She also made a little shrine for her crankshaft. Called it Ode To Oil.
#13 |
#14 |
Machines don't care about excuses. Live & learn.
| The 6 Quart Oil Pan Spacer - Gen 2 | KillerBMotorsport | Engine, Exhaust, Transmission | 33 | 11-07-2022 07:09 PM |
| Down 1/3 quart on new car | TheRealBFKR | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 10 | 09-12-2018 02:49 AM |
| Driving with 1 quart of oil? | TM | Other Vehicles & General Automotive Discussions | 9 | 07-31-2014 10:16 AM |
| Change oil even if I drove under 3k miles in 5 months? | slowbrz | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 02-10-2014 07:00 PM |
| Just drove my brz MT limited 1400 miles in 2 days (mpg results) | sieeegel | BRZ First-Gen (2012+) — General Topics | 30 | 06-07-2012 02:43 PM |
