Old 04-08-2024, 11:00 AM   #155
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Originally Posted by autoracer86 View Post
oh man that stinks to hear. I run Amsoil myself and it's been great off and on the track. Can I ask which one you used MTL or severe gear.
RedLine is good stuff not sure about mixing it with motylgear though kinda defeats the purpose of switching to a GL4 trans oil
MTL was used. Had similar issues last time I ran it, sticky engagement from synchros, especially bad when cold.
Read a while back CSG had a special sauce mix with redline and motul gear 300. I had a bottle of the motyl gear so figured I'd run that. I will say so far shifts much smoother than they have been in a while.
The sticky downshift from 6-5 is gone and high rpm uoshifts from 3-4 are gone. I'll take it!
I parallel park on the street in Baltimore City so it's a whole other level of paranoia. My street is pretty quiet for the area but my car still looks like I rallycross it a LOT.
I'm just committed to a wrap if/when I get off-street parking someday.
- Andrew
I would lose my mind parking on street all the time . I'm paranoid enough at work with people who can't park properly.
Snapped a photo of it this morning sitting pretty. I'm so OCD it needs a minor paint correction to fix body shop woes and scratching from PDR work. Quarter panel and door were re cleared and look good minus way to much texture/orange peel on lower door.
Sidenote.. should I postpone alignment with new trailing arm and MCA coming soonish? MCA says it shouldn't effect alignment but if ride height changes then it in theory will?
The Following User Says Thank You to RToyo86 For This Useful Post:
Racecomp Engineering (04-08-2024)
Old 04-08-2024, 11:10 AM   #156
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
Ah that's very interesting. Not sure why we would have such different experiences but good to hear so thanks for updating.
You would have a heart attack owning my car lol. I once scratched the fender tqing my wheels and couldn't care less and the car is covered in paint issues and scratches lol. Yet for some reason I get mad when kids play near it LOL
I won't be getting an alignment done for the same mods but if you have one scheduled and you can wait then might as well. Also the mod is not supposed to change ride height I think only 1 maybe 2 people said it did
autoracer86 is offline   Reply With Quote
The Following User Says Thank You to autoracer86 For This Useful Post:
RToyo86 (04-08-2024)
Old 04-08-2024, 11:57 AM   #157
I would wait if you can...unless your current alignment is no good since you've got your fresh new tires on.
- Andrew
Old 04-08-2024, 02:27 PM   #158
RToyo86
RToyo86's Avatar
Tried full motyl last fill before I dropped the transmission. I must have temperamental synchros.
Part of the curse being a detailer is that I see everything lol..
- Andrew
I can wait, alignment was done in the fall and no weird Pulling and the wheel is centered.
The Following 2 Users Say Thank You to RToyo86 For This Useful Post:
autoracer86 (04-08-2024), Racecomp Engineering (04-08-2024)
Old 04-26-2024, 10:02 AM   #159
RToyo86
RToyo86's Avatar
Got the toe arms, STi trailing arm, and MCA mod installed yesterday, then went to get a string alignment from shop close by that does race car stuff.
Zero'd toe all around, evened front camber at -1.8°, reduced rear camber to -1.5°.
Rear tire just barely poking now which tickled my OCD.
Only drove the car to work so far for impressions but I did notice immediately over familiar bumps that rear suspension is more compliant. There is less jarring rebound and compression on impact that could make the rear end feel like it's skipping over bumps on throttle.
Hit same bumps on throttle and the rear end mostly absorbed. Will need to live with it a bit but immediate impressions are good.
The Following 3 Users Say Thank You to RToyo86 For This Useful Post:
autoracer86 (04-26-2024), KMA KiCKz (04-27-2024), villainous_frx (04-30-2024)
Old 04-26-2024, 10:57 AM   #160
autoracer86
Drives: Toyota GT86
That's great to hear ! I need to hurry up and order these
RToyo86 (04-28-2024)
Old 05-31-2024, 12:39 AM   #161
RToyo86
RToyo86's Avatar
Spring update, just ticked over 152,000km. Car runs strong, minus the clutch which giving me trouble again. Will have time in June to pull trans and inspect. Cold no noise, once it gets hot it the noise happens.
https://youtube.com/shorts/5_uK5OA5u...y1OrR4a-PmdT52
Installed whiteline diff bushing inserts, quite an easy process. Only 15 minute drive so far but noticed less slop from the driveline. One of the vertical bushings(right) was starting to crack a little, figured this will buy some time before I chisel old one out.
villainous_frx (05-31-2024)
Old 06-01-2024, 10:02 AM   #162
RToyo86
RToyo86's Avatar
My brother picked up a automatic 2014 BRZ in red with 60,000 km.
Previous owner went with the iron man theme.. few corny bits in the interior, lowered on springs and a eBay N1 knockoff.
He hates the ride quality, I'll be installing a set of used 13 suspension with 30k I snagged locally.
Went to car meet and snagged a couple quick photos. Got distracted but some cool twins were there, one with a 1Jz swap.
grippgoat (06-01-2024), Teseo (06-01-2024)
Old 06-06-2024, 02:28 AM   #163
RToyo86
RToyo86's Avatar
Swapped back to stock wheels and installed 215/45 RS4s for track. That meat difference tho...
Racecomp Engineering (06-06-2024), villainous_frx (06-06-2024)
Old 06-10-2024, 01:48 AM   #164
RToyo86
RToyo86's Avatar
Had the car at calabogie motorsport park yesterday for light lapping. It was good fun to shake the rust off. New management running things tighter for solo driving sign off(not a bad thing). Hoping to get a sign off on my next outing in July.
Clutch noise was driving me nuts so I dropped the transmission at 10am yesterday to inspect, and re-greased the TOB, Fork and front bearing cover. Removed the Cusco shifter front carrier bushing and had it back together 30 minutes before I had to leave for the track. Car shifts better and no more noise.
Glad I went with 215/45 RS4s on stock wheels, looks like my springs are working hard with that much grip!
The Following 5 Users Say Thank You to RToyo86 For This Useful Post:
autoracer86 (06-10-2024), blsfrs (06-10-2024), grippgoat (06-11-2024), Racecomp Engineering (06-11-2024), villainous_frx (06-11-2024)
Old 06-27-2024, 08:32 PM   #165
RToyo86
RToyo86's Avatar
Did some wet sanding to quarter panel and door to fix excess orange peel from a body shops reclearing most of that side, then polished and ceramic coated. Not bad for a car about to cross 100k miles!
Also managed to revive the tires PPF on the front bumper for one more year.
villainous_frx (06-29-2024)
Old 07-18-2024, 02:28 PM   #166
RToyo86
RToyo86's Avatar
First wash since all the paint work. C6 hydro ceramic coating lives up to the hype. Will.see how it wears.
Removed the TRD intake and went back to OEM with Perrin inlet tube. Reflashed prior tune.
autoracer86 (07-18-2024)
Old 07-18-2024, 07:56 PM   #167
autoracer86
Drives: Toyota GT86
Oh why did you remove the intake ?
Old 07-18-2024, 11:17 PM   #168
RToyo86
RToyo86's Avatar
Intake needed more MAF rescaling to get it dialed, drivability wasn't quite as good as tune with stock airbox.
Wanted to revert back to see if there was a difference. On/off throttle so far smoother on original CSG tune with OEM airbox.
Edit: after going over stuff I reinserted the front lower diff bushing and fixed driveability issues I was having. car was difficult to downshift smoothly and letting off the throttle caused bucking.
autoracer86 (07-19-2024)
Drift shoot with Ryan's 2jz FRS Amillionoh7 Scion FR-S / Toyota 86 GT86 General Forum 0 07-28-2016 11:11 AM
Ryan Tuerck shift knob ChrisP Cosmetic Modification (Interior/Exterior/Lighting) 12 01-22-2016 09:38 PM
Ryan Tuerck’s Street FRS Sideways&Smiling Scion FR-S / Toyota 86 GT86 General Forum 1 10-01-2014 12:07 PM
Ryan Higa owns an FRS? tekkenman Off-Topic Lounge [WARNING: NO POLITICS] 13 06-21-2013 07:48 PM
FAO Ryan GeeTee86 AFRICA 4 05-31-2013 11:46 AM
