Drives: 2013 Subaru brz limited
Quarter panel replacement procedure
Im replacing my quarter panel and wheel housing i got everything i need but would like to do it correctly. Anyone know where i can get the 2013 manual for bodywork? Theres one on this forum but doesn’t work anymore.
![]() ![]() Sent from my iPhone using Tapatalk |
#2 |
Works fine. Look in my sig line.
#3 |
#4 |
Do what? Not sure what you're asking. Do you not see my signature line? I don't use tapatalk.
#5 |
#6 | |
Yah i was using the tapatalk app didnt let me see it but i got it through the web search part your a life saver i appreciate that!! Sent from my iPhone using Tapatalk |
#7 | |
#8 |
Been busy with work so far heres my progress. Im not a structural expert so i decided its best i take it to a shop have them measure the frame points im sure the wheel slamming against the body of the car tweaked it slightly because my trunk has slight resistance when opening but at the same time when installing my new subframe all bolts went in seamlessly. So a little frame pull should get it right. The only thing im concerned with is inside the wheel housing the wheel chewed up the metal filler tube area. I know replacing the tube requires removing the subframe but imma try without doing so. Lastly i feel they’ll probably charge more having to remove parts from the donor section versus me buying new parts from the dealer. Costed me $1100 but we’ll see ![]() ![]() ![]() ![]() ![]() ![]() Sent from my iPhone using Tapatalk |
#9 |
Huge project will be worth the effort.
#11 | |
Appreciate that just what i needed!! Sent from my iPhone using Tapatalk |
| Replacing quarter panel | allowe | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 48 | 04-20-2017 11:16 PM |
| WTB Quarter Panel/ Rocker Panel/ Fender | mistergrafik | Want-To-Buy Requests | 3 | 11-15-2016 05:34 PM |
| Rear quarter panel replacement | sero901 | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 5 | 09-25-2015 12:41 PM |
| Can someone ID this quarter panel? | JordanWho | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 01-14-2014 06:09 AM |
| WTB FR-S RIGHT REAR QUARTER PANEL | Billylammerkins | Exterior Parts (Aero, Lighting, Etc.) | 7 | 01-01-2014 10:21 PM |
