Old 04-05-2024, 02:35 PM   #1
IsaiahW
IsaiahW's Avatar
Drives: 2013 Subaru brz limited
Quarter panel replacement procedure
Im replacing my quarter panel and wheel housing i got everything i need but would like to do it correctly. Anyone know where i can get the 2013 manual for bodywork? Theres one on this forum but doesn’t work anymore.
IsaiahW is offline   Reply With Quote
Old 04-05-2024, 03:04 PM   #2
Works fine. Look in my sig line.
Old 04-05-2024, 03:08 PM   #3
IsaiahW
IsaiahW's Avatar
Gotcha!! how do you do that?
Old 04-05-2024, 03:15 PM   #4
Do what? Not sure what you're asking. Do you not see my signature line? I don't use tapatalk.
Old 04-05-2024, 03:16 PM   #5
https://gt86stuff.onrender.com/t3Portal/index.html
IsaiahW (04-05-2024)
Old 04-05-2024, 03:17 PM   #6
IsaiahW
IsaiahW's Avatar
Yah i was using the tapatalk app didnt let me see it but i got it through the web search part your a life saver i appreciate that!!
Old 04-05-2024, 05:00 PM   #7
Good luck with the job! Pics or it didn't happen.
Old 04-11-2024, 10:33 PM   #8
IsaiahW
IsaiahW's Avatar
Been busy with work so far heres my progress. Im not a structural expert so i decided its best i take it to a shop have them measure the frame points im sure the wheel slamming against the body of the car tweaked it slightly because my trunk has slight resistance when opening but at the same time when installing my new subframe all bolts went in seamlessly. So a little frame pull should get it right. The only thing im concerned with is inside the wheel housing the wheel chewed up the metal filler tube area. I know replacing the tube requires removing the subframe but imma try without doing so. Lastly i feel they’ll probably charge more having to remove parts from the donor section versus me buying new parts from the dealer. Costed me $1100 but we’ll see
The Following 2 Users Say Thank You to IsaiahW For This Useful Post:
bcj (04-17-2024), Ultramaroon (04-12-2024)
Old 04-12-2024, 01:01 PM   #9
Huge project will be worth the effort.
Opie (04-19-2024)
Old 04-16-2024, 02:24 PM   #10
Opie shared the BRZ body repair manual in this post. Snag it while it's still up.
bcj (04-17-2024), IsaiahW (04-16-2024), Opie (04-19-2024)
Old 04-16-2024, 02:36 PM   #11
IsaiahW
IsaiahW's Avatar
Appreciate that just what i needed!!
Replacing quarter panel allowe Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 48 04-21-2017 12:16 AM
WTB Quarter Panel/ Rocker Panel/ Fender mistergrafik Want-To-Buy Requests 3 11-15-2016 06:34 PM
Rear quarter panel replacement sero901 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 5 09-25-2015 01:41 PM
Can someone ID this quarter panel? JordanWho Cosmetic Modification (Interior/Exterior/Lighting) 7 01-14-2014 07:09 AM
WTB FR-S RIGHT REAR QUARTER PANEL Billylammerkins Exterior Parts (Aero, Lighting, Etc.) 7 01-01-2014 11:21 PM
