Old 03-04-2024, 08:30 AM   #211
whataboutbob
AutoX-10/10ths every run
Originally Posted by norcalpb View Post
Oh right, the gentle massaging haha. Is there any reason why the brace doesn't bolt up to the original trailing arm pickup point? Is the goal simply to keep the brace connected to where the trailing arm currently mounts with the traction mod?
With the traction mod in place, the distance between two mounting points is slightly different. The brace seemed to be designed to have a bit of room available _below_ where the normal trailing arm mount is located, but with the traction mod in place that area was occupied. I'll have to take a photo to illustrate, but I haven't gotten to do doing that yet.
Build thread:Here
The Following User Says Thank You to whataboutbob For This Useful Post:
norcalpb (03-04-2024)
Old 03-04-2024, 11:22 AM   #212
Ohio Enthusiast
Drives: 2018 BRZ
Well, my impatience got to me, I ordered the GP Sports mod from RHDJapan. I figured even if the new MCA mod is excellent, it'll probably be quite a bit more expensive (judging by the cost of the V1) and potentially difficult to source.
The Following User Says Thank You to Ohio Enthusiast For This Useful Post:
Old 03-04-2024, 02:41 PM   #213
norcalpb
norcalpb's Avatar
Your description makes things a lot more clear! Sound like the BFH was the proper remedy.
Very nice. You should consider getting the longer STi crossmember bolts as you’ll be removing the (most likely corroded) stock front subframe bolts to get the new piece in.
The Following 2 Users Say Thank You to norcalpb For This Useful Post:
Racecomp Engineering (03-04-2024), whataboutbob (03-04-2024)
Old 04-03-2024, 03:52 AM   #214
Subababarururu
Drives: 2022 BRZ MT Ignition Red
Just ordered today; its back in stock
Now to figure out what I’m gonna do about ride height droop on stock 22 brz suspension (if it turns out as bad as some of y’all had noticed in your cars).
Subababarururu is offline   Reply With Quote
The Following 3 Users Say Thank You to Subababarururu For This Useful Post:
autoracer86 (04-03-2024), Ohio Enthusiast (04-03-2024), Racecomp Engineering (04-03-2024)
Old 04-03-2024, 04:31 AM   #215
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
Thanks for the heads up. I wonder what’s different about the new version
autoracer86 is offline   Reply With Quote
Old 04-03-2024, 09:09 AM   #216
Please take a pic so we can see if it's updated or different at all!
- Andrew
Old 04-03-2024, 09:14 AM   #217
whataboutbob
https://mcasuspension.com/gt86-and-brz-traction-mod/
Build thread:Here
Old 04-03-2024, 10:39 AM   #218
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Looks like they include a different subframe bolt and some bushings.
The Following User Says Thank You to dragoontwo For This Useful Post:
Old 04-03-2024, 12:42 PM   #219
autoracer86
Drives: Toyota GT86
I think I am going to order one. Install seems easier than when I did the subframe bushings lol.
Old 04-03-2024, 02:26 PM   #220
M0nk3y
I ordered last night, will be sure to take photos but like others said looks like they revised the bushing slightly
Kyle H. - #89 STX
Old 04-03-2024, 02:29 PM   #221
StraightOuttaCanadaEh
Wes
Anyone running this mod with Racecomp T2 coilovers?
Instagram: @gt86ws
Old 04-03-2024, 02:46 PM   #222
I have the MCA traction mod on my personal car, with a sort of custom 5k/6k KW/ST 3 way coilovers. I think it would be great with our RCE T2s. It's a good mod.
- Andrew
StraightOuttaCanadaEh (04-03-2024)
Old 04-03-2024, 03:21 PM   #223
Wes
- Andrew
Okay, I'm getting mine installed at the end of this month, maybe I should get this mod thing as well and do it at the same time.
Instagram: @gt86ws
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post:
Old 04-04-2024, 11:50 AM   #224
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Been eye balling these forever and might pull the trigger now. Is there need for an alignment installing these? Having one done soon
Is there notable improvement to ride quality? primarily street driven in my yellow/B6 setup.
Needed opinions: Does debadging "Subaru" and "BRZ" cheapen the car? davidchoi Cosmetic Modification (Interior/Exterior/Lighting) 49 11-22-2014 10:17 PM
"Clicking" or "knocking" caused by rear seat pull down lever. husker741 Issues | Warranty | Recalls / TSB 6 11-27-2013 02:30 PM
"My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") levifig BRZ First-Gen (2012+) — General Topics 48 08-09-2013 06:34 PM
Factory suspension "sticktion" andrew20195 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 04-02-2013 02:49 PM
"Official" Suspension/Brake Thread NYC BRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 06-27-2012 09:14 PM
