Old 01-22-2024, 04:47 PM   #4929
Brewster
Brewster's Avatar
Drives: 13 FRS AT, Edelbrock SC, Tomei EL
Originally Posted by snowtaipan View Post
Hey all, I've got the old white coolant tank and it's leaking. I think the cap isn't sealing properly, and when I tighten it down fully it pops off. Anyone run into this, or swapped it?
I was looking at the tank from the CTSV, it's 250ml and has a similar plumbing setup, but they're discontinued.
Just curious if anyone had similar issues or found a solution.
https://www.good-win-racing.com/Mazd...t/61-2618.html
The best thing about the future is that it comes one day (and curve) at a time.
Brewster is offline   Reply With Quote
Old 01-23-2024, 06:39 PM   #4930
snowtaipan
snowtaipan's Avatar
Drives: '17 BRZ Series Yellow Edelbrock SC
Originally Posted by Brewster View Post
Isn't that the same one?
snowtaipan is offline   Reply With Quote
Old 01-23-2024, 11:46 PM   #4931
Brewster
Brewster's Avatar
That's the newer model.
You mentioned "old" so I assumed you had the first smaller model, my apologies.
I believe some members have replaced the cap, but I'm old with a bad memory... a Thread search might provide more useful info.
Old 01-24-2024, 11:07 AM   #4932
B T
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
I switched from the original tank to the upgraded V2 tank a couple years ago, it has a little more volume and the part number is available online.
B T is offline   Reply With Quote
Old 03-11-2024, 05:58 PM   #4933
B T
Finally did a Dyno check since I wasn't comfortable doing a 140mph run on the street for tuning purposes. Here's what we have for now.
Old 03-11-2024, 09:54 PM   #4934
Uplink
Uplink's Avatar
Drives: anything you let me
Nice run! What did you have to do to get that pull? Are you still running on 93?
Uplink is offline   Reply With Quote
Old 03-12-2024, 03:11 PM   #4935
tomm.brz
Drives: brz 2017 hksv2
that can t be 93..
Old 03-13-2024, 08:07 AM   #4936
B T
nah, it's E85. Both Zach and I were surprised it wasn't more power. IAG closed deck block, 12.2:1 static compression, 2.70 pulley.
Old 03-14-2024, 01:19 AM   #4937
FrickingReallySlow
Drives: 2015 FR-S
Thanks for the dyno curves, what's the rationale for closed deck for below 400whp? or are you planning for much in the future
FrickingReallySlow is offline   Reply With Quote
Old 03-14-2024, 02:18 PM   #4938
B T
It was just a future proof investment made when purchasing the block. Less cylinder wobble is always a good thing. It hasn't had any significant effect on coolant temperatures.
Old 03-14-2024, 03:44 PM   #4939
Blanco#17
Blanco#17's Avatar
Drives: GT86 Blanco Ed #17
Hi all,
Finally getting a business trip over to the states.
I have already had to buy one actuator which was blown on arrival and then also got the upgraded #15001 bypass actuator. Import tax and p&p pretty much put an extra 200% on the cost of it. So will be getting another just to sit on the shelf just in case while I am over.
Any one got any recommendations for other parts that would fit in a suitcase that would be worth holding on the shelf?
Blanco#17 is offline   Reply With Quote
Old 03-15-2024, 01:22 AM   #4940
dpfarr
Drives: BRZ ts
Bought a South Bend stg 2 clutch, oe flywheel, and a versus fork and pivot. Missing anything?
I wouldn’t want to change the clutch in the first place. Having to pull the blower sucks even more. Does anyone have advice on this? Can I just unbolt it to get access to the slave cylinder or do I just pull it?
dpfarr is offline   Reply With Quote
Old 03-15-2024, 10:46 AM   #4941
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
I was able to unbolt and raise the rear of the blower sufficently (about 1 1/2”) to comfortably service the slave. This without disconnecting the fuel lines or anything else. It might be tough to access the top mounting bolts of the tranny. Good luck!
I also choose a South Bent clutch. The Stage Two Daily. Pedal feel is just like stock. Very satisfied.
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS-V/EvoX Brembos
Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms
235F/245R Conti ECS on TRD/Enkei wheels (street),
245/40 sq. ECF on 17x8 720Form GTF2 wheels (track)
Muskoka800 is offline   Reply With Quote
Old 03-15-2024, 12:06 PM   #4942
FrickingReallySlow
Drives: 2015 FR-S
Are you guys using stock pressure plate or something that came from SB
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 04:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 02:48 PM
