| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
#29 | ||
Drives: Subaru BRZ 2017
One more important thing I forgot to mention is that the car will ONLY start in Park or Neutral gear when sending the remote command. This also provides less code for me to in terms of the checklist compensation before starting. Quote:
Disabling the immobilizer would be godsend though if I can find the key/seed and the algorithm performed between the immobilizer and the bus system. Quite difficult I must say. So best way is basically going straight at the ecu and find a way to send a command that would trick the ecu that the key is detected nearby and it's a valid one. I haven't gotten to that yet. If you know your way around here is the canbus id for the smark key system: CanID: 0x750 (Main Body) PID: (0xB5) I don't understands what you mean by the "follow-me-home" phrase. That's interesting lol. I basically have two CANBUS connected to the car at same time to be able to write/decode/ready the CANBUS messages: Tactrix Openport 2.0 and CANduino (which is basically an arduino nano but with built in canbus Transceiver ). Tactrix plugged in to the obd 2. CANduino connects to the CANbus through the unused CANbus plug (close at the firewall) behind the radio system. incase you are interested: https://www.tindie.com/products/mass...-with-can-bus/ |
#30 |
So At this moment I'm gonna be using the gut of an extra keyfob to bypass the immobilizer. Of course it's going to be hidden away somewhere deep in the car and since the fob will be powered directly by the arduino it will only be instantiated in a [split] second just to start the car and then powered back down.
#31 |
Drives: 86 GT
Any updates so far on the project?
DIY stuff at Compelica Works
#32 |
I'm still trying to querying through the canbus message to find message that would check for valid key fob. It seems like right now it can only be triggered when the door is opened.
As soon as a fob is detected, the car doesn't and won't periodically check until the car is shut down or an opened door is triggered to alarm the occupant/driver. As soon as I can get the "trigger message" , then I will continue with it. I've already written most of the functionality in Arduino - being a software developer and my experience with Arduino that part was pretty easy. If I'm unable to find it then the only thing I can do (at the moment just like most of the OEM remote starter out there) I will have to immediately shut off the car as soon as any of the doors are opened. I am trying to avoid that |
#33 | |
Drives: 86 GT
Also - if you have the canbus command to turn off the car (not fuel cut) - would you be able to share it with me? Been trying to but to no avail.
#34 | |
At this point I gave up on trying to manually trigger for "keyfob check" and let the vechicle actually handles that. Before remote start, I will just have to check for door status - meaning door has to be closed before remote start can be activated - I will probably roll up all windows too (as a bonus). If a remote start was initiated and any of the was opened, the car would automatically check for valid key fob. If the driver gets in and decides to start driving, as soon as they pressed on the brake pedal I will check the broadcast message if they have valid key. If driver does have valid keyfob, then [initiate the takeover procedure] and drive as normal. if driver does NOT have valid key fob, the engine shuts off completely. ![]() I was really overthinking it this whole time lol. Now regarding your question regarding remote COMPLETE shutoff, unfortunately I don't have the canbus message for that. I can also COMPLETELY shut off the CAR only if the car was initially started as a canbus start - AKA remote start. But if the car was initially started via the normal sequence the only option is the fuel cut - at the moment. |
#35 | |
Drives: 86 GT
On remote starts, as I'm aware of - they are merely used to warm/cool the car cabin and possibly the engine as well (though the average driver may not care). For certain VWs you can hold down the lock/unlock button on the keyfob to remotely bring down the windows to reach for something if the door isn't accessible or let air out of the cabin; very useful in hot climates. Would you mind sharing the commands for the remote starts (ACC, IGN1, IGN2, ACC+IGN1+IGN2) and rolling up/down the windows? May come in handy for certain situations I'm thinking of...
#36 | |
Yea..I tried not to go that route of actually completely turning off the engine as soon as the door is opened. I will only shut it off if the user attempts to drive the car and no valid key fob is available (which would be triggered as soon as the door state changes from closed to open). Remote start is merely convenient to set the car to a nice/modest room temp based on the outside temp usually. I live on the east coast, so this comes in very handy during the winter season and also during those summer heat waves. Having to step into the car, wait a few minutes to warm up while freezing your nuts off or the during the summer in which sometimes i basically have to quickly turn on the car, set AC (if it wasn't previously set), crack open the window and quickly get out of the car because of how HOT the inside can be. That's my main reason for doing this. I mean i could have easily just go buy and install existing remote starters but what's the fun in that? Besides, those aren't exactly cheap and the ones with LTE remote start tend to be wonky and can sometimes take up to 15 seconds to send the command..among other things. At least I can control everything including my own server implementation. Anyway, enough rant. Now Be warned, For the Ignition 1, Ignition 2, and ACC commands needs to be sent one at a time. Meaning if you are CONTINUOUSLY sending IGN1 message, you can't send IGN2, and ACC CONTINUOUSLY at same time. You will have to stop sending the other message before you send another. This only applies to the ignition states. IF you don't HEED, then you will potentially soft lock your vehicle from starting UNTIL you clear 'engine code'. Yea I learned my lesson. Even though the Check engine doesn't come up in the dash, the canbus is still internally confused when you send those messages simultaneously. Make sure you have an OBD adapter to perform the reset. Disconnecting the battery should also do the same (I think - not sure). I believe it's call "Cancel Code". Good news though is that the canbus can trigger both IGN1 and IGN2, and even ACC at same time as long as you send the right code. You just can't manually send both together as explained above - I can't reiterate that enough). here are the commands: Ignition ACC ----------------------------------------------------- //CanBus ID ID: 0x750 //CanBus DATA bits ACC: 0xE9 0x04 0x30 0x01 0x00 0x10 0x00 0x00 IGN1: 0xE9 0x04 0x30 0x01 0x00 0x20 0x00 0x00 IGN2: 0xE9 0x04 0x30 0x01 0x00 0x40 0x00 0x00 //WARNING: DO NOT USE IGN2. IT WILL SOFTLOCK THE STARTER IGN1_IGN2: 0xE9 0x04 0x30 0x01 0x00 0x60 0x00 0x00 ACC_IGN1_IGN2: 0xE9 0x04 0x30 0x01 0x00 0x70 0x00 0x00 Toyobaru decides to use a nicely sequential representation here [5th bit] (How nice of them. lol) If you only send the message once, the action is triggered and I believe it takes about 15 to 45 secs before the car system automatically deactivates (turn offs) the action. You can continue to send the message at least once per 15 seconds to keep the action alive. Fuel Cut ------------------------------------------------------ //CanBus ID ID: 0x7E0 //CanBus DATA bits All Cylinder Fuel Cut: 0x06 0x30 0x1C 0x05 0x0F 0xA5 0x00 0x00 Windows ------------------------------------------------------ //CanBus ID ID: 0x750 // //CanBus DATA bits Driver Full Up: 0xEC 0x04 0x30 0x01 0x01 0x80 0x00 0x00 Driver Full Down: 0xEC 0x04 0x30 0x01 0x01 0x40 0x00 0x00 Pass Full Up: 0xEC 0x04 0x30 0x01 0x01 0x20 0x00 0x00 Pass Full Down: 0xEC 0x04 0x30 0x01 0x01 0x10 0x00 0x00 One caveat regarding the windows ( I believe it applies to HVAC too) is that the car needs to have its Ignition state active prior to performing the window actions. So basically you send the IGN1 which will power up the module for the window control system (At this point is when I realize why we have two ignition states - anyway moving on), then you can send the window commands as desired. You only have to send the command once, and the car would perform the action. Now regarding the windows there are also some variations like roll up (or down) 1/3 or 2/3 or even at any point, but that is slightly more involved. You have to send a preliminary message first that would trigger that state. I'm gonna assume you only care about full up or full down anyway. Aaaand, there ya go! For each of any of the commands the canbus will return a confirmation message. I am not going to include them since you will probably get them anyway as soon as you send these commands but I did include the receiving CanBus ID you should be listening to below: Sending at 0x750 , returns confirmation at 0x758 Sending at 0x7E0 , returns confirmation at 0x7E8 Cheers! MAJOR Correction : Do not use the IGN2 ... Really the only (since it will soft lock your car (from starting). I'm not going to remove it but leave it here as a reference. but you've been warned! Last edited by ojuniour; 03-02-2024 at 03:34 AM. Reason: Warning about IGn2 |
| The Following User Says Thank You to ojuniour For This Useful Post: | Compelica (02-28-2024) |
#37 | |
Drives: MR2, Sliver BRZ
Always looking to tinker with something..
#38 | |
Drives: 86 GT
As expected it works on my 86 as well, albeit with slightly different behavior. For example, ACC+IGN1+IGN2 only lasts for about 5 seconds before shutting off, and the window control commands have to be fired multiple times until it fully opens/closes. And in my logger (had to dig out the other stuff) - SSM4 is doing the same thing unlike yours which the entire window goes up/down with the command is only issued once. Also, running ACC+IGN1+IGN2 when the car alarm is armed, triggers the alarm. My fuel cut command is slightly different from yours, but it works all the same. It was captured from Techstream though. Since ACC+IGN1+IGN2 is initiated by the BIU (with header 750), the turn off command should be coming from there as well. I can probably use the ELM327 to monitor and find that command somehow.
#39 | |
I have a dummy keyfob that I removed from its case (and just the bare PCB). It will be powered by Arduino as i send a ground pin to it momentarily to kick off the sequence. as soon as the car starts, i can then deenergize the key. The car will still continue to run and would still think there is a valid key because it doesn't periodically check until one of the doors is opened ( and closed). The car will still continue to run until you stop sending the command or somehow the arduino was removed/disconnected. In my case, as soon as the door is opened and stayed open, and you don't have a valid keyfob and you initiated the takeover sequence (by holding the push start and brake at same time), the car would shut off. Period. |
#40 | |
#41 | |
#42 | |
| Possible vehicle coding? BMW Guy | gskv | Software Tuning | 2 | 11-24-2016 03:01 PM |
| Canbus solution | Zer0 | Engine Swaps | 71 | 09-30-2016 06:18 AM |
| Odb2/canbus flexibility | Futaba | Electronics | Audio | NAV | Infotainment | 1 | 08-25-2015 04:00 PM |
| CanBus Triple | xjohnx | Electronics | Audio | NAV | Infotainment | 8 | 01-31-2015 12:39 PM |
| CANBus | pseudo | Electronics | Audio | NAV | Infotainment | 4 | 09-03-2014 02:11 PM |
