Drives: 13 Scion Frs
Headunit needs 'filler' behind it, what can I use?
Bought a new headunit, fits flush in its placement, but the stock brackets/bracket it came with won't help/fit.
What can I do that's a simple diy to the unit stay in place? 1st pic you can see in the top right, how there's extra space 2nd pic is with the unit pulled forward, but obviously even touching it causes it to fall back, since it's basically just temporarily balanced there Also if you have any idea what I'm supposed to do w this red cord that's attached to the fan, that'd be helpful. edit: was just missing the brackets, im an idiot. lmao Last edited by Alfrz; 01-31-2024 at 08:26 PM. |
#2 |
Make sure you can't adjust the brackets foward, which will move the unit back. If that doesn't work you should be able to fabricate some fairly easily.
NOTE: I can't tell for sure from the photos but I'm assuming the HU is sticking out to far. If it's recessed too far, just reverse what I said.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
#3 | |
Nah I should've explained the pics a little more. The first 2 pics, if you look in the top right corner where the trim meets the unit, (straight above the right knob) you can see what's going on. The unit can't stay *forward* enough*. Not at my car rn, but are you saying the stock brackets may be movable? |
| The Following User Says Thank You to Alfrz For This Useful Post: | Dadhawk (01-31-2024) |
#4 | |
Master Collaborator
| The Following User Says Thank You to FR-S2GT86 For This Useful Post: | Dadhawk (01-31-2024) |
#5 | |
#6 |
Drives: 22 BRZ limited
Did you wire up the fan and attach what appears to be a loose ground?
#7 | |
#8 | |
Master Collaborator
I'm also guessing that the fan power supply should have been plugged into one of the receptacles on the back of the unit. |
#9 |
It is definitely more art than science if you want it "just right". I need to replace the aftermarket bracket in our Suburban because the one that came with the kit tends to slip in one corner for some reason, and the unit is always lower on the left corner. Probably a 15 minute fix but the unit works and I don't think about it unless i'm driving it somewhere.
#10 |
#11 |
Master Collaborator
If you don't connect it to a power source, your head unit will probably overheat. I suspect it is there to cool the internal amplifier. Did that head unit not come with an owner's/operator's or installation manual? In the very last picture, I can see on the label that your unit is possibly designed for use in a Corolla. Perhaps in the Corolla there is a specific receptacle already in the dash that it needs to plug into.
If you could supply us with some more information, it would help us to help you. Brand and model of unit, used or new, oftentimes when you pick up something second-hand the manuals don't get transferred with it in the process.
#12 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
To me, the fan appears to have previously been plugged into the 4 pin slot pointed at by the red lines on the fan housing.
Mostly because of the existing bends in the loose wires. Then again, those two arrays also look like monolithic plugs with locking arrangements. Would be a good thing to find the manual to go with the head unit though before depending on random internet advice.
"I gotta rock." -- Charley Brown |
| Oil filler cap came off - oil all over - help | indio22 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 13 | 09-15-2021 04:42 PM |
| BRZ headunit problem USB sticks & headunit reset..school me. | Photonic | Electronics | Audio | NAV | Infotainment | 2 | 03-12-2014 07:06 PM |
| Grimmspeed Oil Filler Cap | SilentMike | Engine, Exhaust, Bolt-Ons | 3 | 10-07-2013 11:37 AM |
| For Sale: TRD Oil Filler cap | Panman | Australia Classifieds | 4 | 04-13-2013 08:22 PM |
| Fuel Filler is on the Right!! | Guaruja | Scion FR-S / Toyota 86 GT86 General Forum | 43 | 04-01-2012 06:55 PM |
