Old 01-25-2024, 12:53 AM   #1
IsaiahW
IsaiahW's Avatar
Drives: 2013 Subaru brz limited
Magnus launch control device
I have a twin disk comp clutch w/cd009 and tilton hydro bearing. It’s essentially an on/off switch from hell! So I’ve been on the market for a clutch flow control system like clutch master or tilton. The drawback with those is I don’t want to be slipping my clutch in every gear. So I came across a solenoid type control system which only activates via ecu or micro switch only in first gear. I have a stock ecu and have no plans of a standalone ecu so i need to make some sort of switch. A more convenient option that i want is one close to the shifter itself. When in first gear the shifter is pressed against it activating the solenoid and deactivates out of first like a clutch switch but smaller. Anyone know something that can make that happen.
IsaiahW is offline   Reply With Quote
Old 01-25-2024, 05:45 PM   #2
RedReplicant
Drives: None
Another route you might consider is handling this with a dev board with a CAN transceiver built in like a Adafruit Feather RP2040.
RPM, speed, calculated gear, and clutch position are available over CAN.
RedReplicant is offline   Reply With Quote
Old 01-25-2024, 06:18 PM   #3
IsaiahW
IsaiahW's Avatar
I wish i was as smart as you honestly lol I get completely lost with that stuff it sounds like a pain.
Old 01-30-2024, 05:53 PM   #4
Use a smaller diameter master cylinder. That will give you less travel on the TOB.
Help on Launch control disable speed to control wheel spin during launching j.boy Software Tuning 8 02-01-2016 05:58 AM
Best RPM to set OFT Launch Control to? Aztec Software Tuning 12 03-23-2015 09:56 PM
