Old 01-07-2024, 08:02 PM   #1
GrandSport
GrandSport's Avatar
Drives: 13 Viper; 14 BRZ; 90 Miata; 18 AMG
Diagnose these issues- separate or same
So timeline:
Car is track only. After running hard it will hard start. But it always started so nbd.
Engine rebuilt. No issues
Later starts having battery drain. Fast. 3 hours and it's too low to start. One time I swore I heard an electrical humming on the lift, but I couldn't investigate much as I was in a rush. I didn't really care much because I was about to install a kill switch.
2 weeks ago, while idling in hot pits, it dies wont start. Seemed like battery was low, but then even with a jump box, it wouldn't start. Definitely felt like no fuel and got Code P0087. 1/3 tank of gas (and based on normal usage, I definitely had more left in the tank). Tow to garage. Add 1 gallon of gas and starts right up! Weird. Go to fill it up and it only takes 8 gallons. Weird. No problems all day.
Next week, go back to the track. Starts right up (on battery tender). Back up, about to let it warm up and it stalls again. Wont start up again. UGh. Run a different car all day, come back and the battery is super low as expected. Gets to one "click". Push it in the garage and notice clicking coming from fuse box under the hood. Remove key and it stops.
I ordered a new fuel pump (it has an aftermarket one in there)
Engine wise, it's stock aside from CAI/Exhausts/Headers/Tune. No power adders or anything. I unplugged everything aftermarket I can think of (which is really just data loggers).
Fuel pump + unrelated battery draw?
Cam position sensor + unrelated battery draw?
Other? All 3?
2014 BRZ: WRL Build (GP2) MCS, AP, Motec, race wiring harness, blah blah blah
2014 FRS: Similar WRL Build. Back up / parts / practice race car.
2013 Viper GTS : Tractive Coilovers, ACR sway bars, aero, carbon, exhaust, etc.
1999 NB Spec Miata: 1.8 w/ all the goodies.
2022 CT5 Blackwing: Stock.
GrandSport is offline   Reply With Quote
Old 01-07-2024, 09:56 PM   #2
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Originally Posted by GrandSport View Post
So timeline:
Other? All 3?
You have not mentioned anything about voltage readings. It's very difficult to diagnose vehicle electric systems without the proper tools. Have you been taking any voltage readings with your multimeter? What are the voltages at the lead battery posts and then at the clamps connected to each post while you are experiencing the problems described?
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
Old 01-08-2024, 06:41 AM   #3
Lantanafrs2
Drives: 2013 frs red
I would start with alternator and battery. Motor rebuilt? Maybe there's a ground hanging off somewhere? If there's a draw, get a voltmeter on it and start pulling fuses.
Lantanafrs2 is offline   Reply With Quote
Old 01-08-2024, 11:21 AM   #4
GrandSport
GrandSport's Avatar
I didn't see any loose grounds, but i'll look for them. I'll also get a voltage reading next time I go up the track.
Is there a diagram/schematic of all the grounds?
Old 01-08-2024, 09:42 PM   #5
Grady
Grady's Avatar
As with anything electrical get a volt meter and start checking where you are losing voltage.
Trying to diagnose a noise from the rear Stephen02 Issues | Warranty | Recalls / TSB 12 08-20-2023 11:25 PM
Automatic trans problem need help to diagnose please Theodorable Issues | Warranty | Recalls / TSB 6 04-08-2023 03:37 AM
Can anyone diagnose why I went into limp mode here? George Rosebush Tracking / Autocross / HPDE / Drifting 5 01-12-2020 05:58 PM
Please help me diagnose a shifting problem Pat Engine, Exhaust, Transmission 22 08-05-2019 04:30 PM
Diagnose my Civic no start Ashikabi Other Vehicles & General Automotive Discussions 30 04-21-2019 09:45 AM
