Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 12-20-2023, 11:25 AM   #1
Shub Deetle
Large Member
Shub Deetle's Avatar
Drives: 2022 Subaru BRZ
2024 ts trim
Do you think the new BRZts will drive noticeably different than the Limited version? Or maybe just on the track when you’re pushing it?
“The key mechanical changes include Brembo brakes front and rear, different 18-inch wheels, and an "STI-tuned" suspension setup with Hitachi dampers. These brakes are the same larger rotors and upgraded pads found in the Toyota GR86's new Performance package for 2024.”
Baby, you can drive my car
Shub Deetle is offline   Reply With Quote
Old 12-20-2023, 11:52 AM   #2
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
No.
The Following User Says Thank You to x808drifter For This Useful Post:
DriveDriftDogfight86 (12-21-2023)
Old 12-20-2023, 02:21 PM   #3
Shub Deetle
Large Member
Thank you for your unambiguous, succinct answer.
The Following User Says Thank You to Shub Deetle For This Useful Post:
x808drifter (12-22-2023)
Old 12-20-2023, 04:38 PM   #4
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
Not really.
For the street, you're not going to feel anything substantial. I have the performance pack Brembos (2017) on mine and they're not that much different than the stock brakes in terms of feel compared to the 1st or 2nd gens.
For suspension, the ride is likely going to be slightly firmer, but not much. The Sachs dampers on the PP actually feel more "crashy" than anything. Spring rates will be slightly upped with some pink STI springs. Likely 10% and maybe 10-20mm ride height difference.
It's basically a performance pack for the 2nd gen, not even a "true" tS version like the 1st gens had. The Brembos are cool, but aren't really needed at all for the street and even autocross. Track days... eh, maybe for the heat capacity.
Subaru's been doing this a lot with their performance cars. Slap on some bigger brake kit and slightly up some other things that are barely noticeable and call it a new trim level. Look at the WRX TR that just was announced.
cmiovino is offline   Reply With Quote
Old 12-20-2023, 07:04 PM   #5
OldBiker
Drives: 2023 Gray BRZ
The blue stripe on the tS seats will be slower than the red ones on the Limited :-) All kidding aside, I would definitely stick with the two lower trim levels... save the $$ for your own stuff (or a new engine... see below).... then again, I AM old.
PS:
OldBiker is offline   Reply With Quote
Old 12-20-2023, 07:29 PM   #6
wbradley
Sarcastic SOB
wbradley's Avatar
Hitachi trumps Sachs.
Old 12-21-2023, 10:37 AM   #7
Desertnate
Spelling Impaired
Drives: 2022 BRZ Limited WR Blue
That's disappointing to hear. If I had one complaint I have with the car, it's brake feel. I prefer a more firm linear brake feel with more bite early on and the BRZ feels mushy at first with feel the farther you get into it. Plenty of stopping power, just not a great feel.
According to Road and Track, it's the same springs we have in our cars now.
https://www.roadandtrack.com/reviews...of-the-greats/
I noticed Car and Driver mentions the new struts up front and nothing about springs, which seems to confirm this simply because they don't mention it as a change.
https://www.caranddriver.com/reviews...-brz-ts-drive/
This was my take too. I'm quite happy with the current suspension set up and don't see how the changes would make a big enough difference to put any "daylight" between the TS and a lower trim. Based on your comments regarding the brakes, it's not a big deal either. It seems you could make significantly better improvements with aftermarket parts.
Desertnate is offline   Reply With Quote
Old 12-21-2023, 11:09 AM   #8
Shub Deetle
Large Member
So I guess it boils down to whether you like blue or red inserts on your seats. Tough call!
Old 12-21-2023, 11:37 AM   #9
cmiovino
cmiovino's Avatar
This is interesting. You think they could at least toss a fancy looking spring on the car that's a different color, ha.
To go further on the brakes, I never felt the pedal feel was a problem on the twins. Now my 2004 WRX and other Subarus - yes, for sure. It's soft and spongy feeling. Adding a master cylinder brace helped and of course different pads, but it's still a longshot from the OEM Brembos on my BRZ.
I've driven a few first gen twins at autocross setup in the STX and SSC (modified) classes. All had upgraded brake pads. I never felt the brakes feeling like my other Subarus did being soft and spongy.
I'm not 100% certain, but the 2nd gens I've driven I'm pretty sure all had upgraded pads at least. Again, those did not feel soft/spongy at all.
Point is, I think a lot of the feel comes down to the pad compound you choose. Even on the Brembos, the stock (Jurid) pads are more like an on/off switch vs the Ferodo DS2500 pads I have now that are way more progressive feeling.
I like the fancy look of the Brembos, but you could achieve the same feel for the street and lighter track days with pads and a master cylinder brace. Even if you really wanted to go hardcore, you get get aftermarket fixed calipers like the AP Racing sprint kit for less than the tS trim level is going to cost you.
The Following User Says Thank You to cmiovino For This Useful Post:
Desertnate (12-21-2023)
Old 12-22-2023, 12:04 PM   #10
x808drifter
LMGTFY
Your welcome.
Old 12-24-2023, 02:56 PM   #11
Lantanafrs2
Drives: 2013 frs red
They're making it more reliable with an aftermarket stroker kit
Lantanafrs2 is offline   Reply With Quote
Old 12-25-2023, 08:41 AM   #12
vindiesel
vindiesel's Avatar
Drives: 2023 brz limited 6mt red
4.88 or 5.1 final drive would have been a spicy option
2023 brz red limited 6mt 10k miles ish
2009 Chrysler 5.7l hemi eagle 300c heritage edition 205k miles
vindiesel is offline   Reply With Quote
Old 12-25-2023, 05:28 PM   #13
OldBiker
You mean HKS? But how does a longer stroke make the engine more reliable when it has lubrication problems (we think)... and so far there has not been a definitive diagnosis of the problem(s)?
Also not sure how that would play in the Republic of Kalifornia where they won't even let you tune the engine for better throttle response... sigh.
Old 12-25-2023, 06:45 PM   #14
Lantanafrs2
I was being sarcastic lol
The Following 2 Users Say Thank You to Lantanafrs2 For This Useful Post:
OldBiker (12-26-2023), x808drifter (12-26-2023)
PRICING ON 2024 BRZ ruturaj001 BRZ Second-Gen (2022+) — General Topics 12 11-16-2023 01:23 AM
2024 BRZ tS Releaved Rainy BRZ Second-Gen (2022+) — General Topics 55 08-12-2023 05:20 AM
2024 model year changes? If any? dhutty BRZ Second-Gen (2022+) — General Topics 33 06-07-2023 07:30 PM
Interior trim trim clips (Dash Trim Panel) ubersoph Cosmetic Modification (Interior/Exterior/Lighting) 4 08-11-2022 08:47 AM
WTB: oem shifter trim, steering wheel trim, and door handle trim frs_caskey Want-To-Buy Requests 3 03-28-2017 06:38 PM
