Old 10-30-2023, 06:44 AM   #1
Theodorable
Drives: 2015 Scion Frs
Auto Transmission problem (ASAP)
So today I got off work and when I got into my car and put it in drive something just felt off. I didn’t realize until right when I got into the freeway. So what is happening is my car is like stuck in 3rd gear. It won’t shift up or down. I go into manual mode and nothing shows up. Floor shifter and paddles don’t work. I gassed it to see if it would change like it should but it doesn’t. I was cruising home for like 20 min at 70-75mph at like 4000k+ rpms 10mpg cause who knows why the gears are bein this way. No light comes up I hear my motor gasping for air. When at a full stop the car won’t move forward till I put a lot of gas into it and it starts moving but the thing is, it never switched gears I believe. It was always in the same gear. So I don’t know what the problem is I need help and insight Thank you!
Note (I had 2nd gear slip before but I redid the fluid and tipped it off and never had a problem since this was 8 months back) so I know the fluid is brand new and you never really need to change it anyways unless for reasons like slippage so I assume that’s not the problem (trans fluid) that is. But I could be wrong so all help is needed and appreciated!
Theodorable is offline   Reply With Quote
Old 10-30-2023, 11:19 PM   #2
pope
has a funny hat
Drives: 2014 BRZ Limited
If these were classic automatics, I’d say it’s low on fluid or has a plugged valve body, but being electronically controlled, it could be a controller issue, solenoid failure, corroded wiring connection, etc, or just incorrect fluid fill.
Check for codes? Find someone local with techstream that can run it through a full diagnostics check?
pope is offline   Reply With Quote
Old 11-02-2023, 04:31 PM   #3
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
That could be electric/controller related. Seems too long from it being the fluid change.
How many miles on the car? Any hard driving?
Old 12-18-2023, 02:44 PM   #4
Theodorable
Problem ended up being solenoid s3 decided to not work and they don’t have any replacements in any dealer ships around the country. So I just decided to manual swap my car
The Following User Says Thank You to Theodorable For This Useful Post:
finch1750 (12-20-2023)
Old 12-18-2023, 08:17 PM   #5
pope
has a funny hat
It’d be cheaper, easier, and faster to just buy a replacement transmission from a salvage yard.
The Following User Says Thank You to pope For This Useful Post:
whataboutbob (12-19-2023)
Old 12-19-2023, 03:21 AM   #6
Theodorable
Not really bout just getting it fixed. I also missed and wanted to experience this car in manual. So this was a great opportunity to do so!
Yet Another Transmission Problem zberz Engine, Exhaust, Transmission 11 07-13-2021 11:39 PM
Change your manual transmission fluid ASAP!!! Kostamojen Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 383 12-12-2016 10:29 AM
Transmission Problem frosty86 Issues | Warranty | Recalls / TSB 36 10-21-2015 10:17 AM
Possible Transmission Problem...Input Please wawawoowee Issues | Warranty | Recalls / TSB 11 05-24-2015 02:11 PM
Transmission Problem! johnnylai Issues | Warranty | Recalls / TSB 6 02-07-2014 03:54 PM
