#631 | |
Drives: Q5 + BRZ + M796
| The Following User Says Thank You to Irace86.2.0 For This Useful Post: | Dadhawk (12-07-2023) |
#632 |
That is clearly a reflection of light hiding the side of the rotated microphone that you can clearly see it is in front of him. The angle is all wrong, but I don't get why you think they had to CGI the microphone in his hand? I mean the camera quality is crap here. Bigfoot could have walked through the frame, and it would look like a brown rug is drifting by.
#633 |
I found this video of IFT2. It was shorter than the long format video posted prior. Still amazing feat.
#634 |
Drives: '23 BRZ
I'd call the 1st launch an abject failure, mainly due to someone not believing massive amounts of water is *required* to reduce acoustic energy into the bottom of the ship along with a dozen or so other considerations, and also thinking it'd be cute to launch on "4/20".
2nd launch I'd agree *mostly* successful, but still, failure of booster and failure of Starship. If it works, it works, but I still have my doubts that it can be made reliable enough to launch 20 times in a short enough time to fully tank a lunar lander. It's just a hideously inelegant solution, stark contrast to Apollo. I do have to think there must be a *much* better way... Another thing is I think that they expanded mission scope vs. Apollo too much. It's a BIG step from setting 2 people down on the moon for a day or so and bringing them straight back. Anyway, we shall see... |
#635 |
@Irace86.2.0 post above....
I hadn't noticed before what appeared to be issues with the reignition of the booster engines after separation (based on the engine graphic on the left).That definitely explains the self-destruct, particularly given the issue seems to have been primarily with the steering engines in the center, the outer ring being non-steerable. It also looks like Starship reached it's suborbital altitude, something else I hadn't noticed before. It just didn't stick the landing at the end. I have to admit it was "this close".
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
| The Following User Says Thank You to Dadhawk For This Useful Post: | Irace86.2.0 (12-08-2023) |
#636 | |
Drives: '13 BRZ Limited
Thought that was the point of starship? Using it as a lunar lander is kind of like hammering a square peg into a round hole. Sure you can make it fit, but the result won't be pretty. |
#637 | |
I agree that it isn't elegant and seems overcomplicated, but only in relation to Apollo. In light of what they plan to do for Mars, it seems entirely necessary. We basically need an ISS around the moon like we do earth. I agree too. We will have to wait and see.
| The Following User Says Thank You to Irace86.2.0 For This Useful Post: | Dadhawk (12-08-2023) |
#638 | |
Firing up the engines is not an easy process. Musk was basically saying it is a delicate orchestra of pressure, temperature and timing in a sequence that needs to play out like a ballet. Convo starts at 9:20. I guess we will have to wait for the findings when they get released. People can say what they want about Musk, but the dude is an engineer at heart. You can tell that. He knows more about the specifics of the rockets, cars, batteries, etc. than most CEOs.
#639 |
That is what photographers call a reflection. Hard to tell with the grainy image if it is a reflection of the image of the station off the lens of the window from a display screen inside the ship, or if it is reflection of the ISS overhead refracting off the lens of the window.
Spend a few bucks and rent some time with a powerful telescope and video/see the ISS yourself. It is right up there, plain as day. I've seen it. Check for yourself.
#640 | |
In the meantime, the fuel needed to go to Mars isn't as signifiant as you may think. The velocity needed to go to the moon could be maintained to go to Mars. It just takes a lot longer like months instead of days. It only takes fuel to accelerate and decelerate and break the pull of gravity. The first missions to Mars will probably be complex to get to a refueling point, but they will likely be similar to Apollo missions where we go, we orbit, we land, and we pull out, and sling shot back--no staging. It would be nice to be accelerating the whole time, which is the fastest way to get there, but that would be miserable for the crew. If we had the fuel to do that then the trip would be shorter, but half the time would be positive acceleration and then half the time with negative acceleration (deceleration). Imagine pulling g's or having a steady acceleration for weeks just to shorten the trip from six months to days or weeks. It would be terrible.
#641 | |
Drives: '23 BRZ
![]() You don't know much about him, do you. He is an idiot. His code was too terrible to be usable for PayPal, he mucked up the original Tesla Roadster, and the people who really run SpaceX are only able to do so by controlling Musk to keep his terrible judgement from derailing progress. He is a grifter at heart. He is almost always WRONG. He is not an engineer. He is not a scientist. He is a grifter. |
| The Following User Says Thank You to ZDan For This Useful Post: | pope (12-08-2023) |
#642 |
Slow it down to 0.25 and watch again. The ribbon twists and stops reflecting light. It is gray and dark on the "dark side" of his head, and you can see the ribbon resting against the side of his head.
Again, your bad, pixelated, low bitrate, old videos showing camera/ligting optical illusions is evidence of 90's CGI? Stop bro.
#643 | |
Watch him talking about the engines and rockets for hours while giving a tour of the facilities to Everyday Astronaut. You can start here. Lots of videos of him talking and talking and talking about intricate systems and components. Again, doesn't make him a good or great or an engineer at all. It seems to me he is an engineer at heart who understands the principles, knows how to learn quickly from engineers who teach him what they are doing, and he understands it and is involved enough to comprehend the process and can discuss it in great detail. I can't recall a CEO who had product-manager-level-knowledge of the products and systems being used.
#644 |
Drives: '23 BRZ
He has a bachelor of *arts* in "physics". I.e., he ain't any kind of physicist. And he's certainly not an engineer either. I am an aerospace engineer and I have *some* knowledge of materials and IMO he isn't any kind of expert there either. What he is great at is exploiting others to advance himself. He is also a tyrant and it is well known that he has handlers to keep him from interacting with the people actually doing the hard work because he might fire them for disagreeing with his idiotic "ideas".
| Which Space Saver will fit? | Andrew666 | AUSTRALIA | 25 | 06-18-2020 10:07 AM |
| Cockpit Space | Chad86 | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 03-15-2014 04:24 PM |
| First run 86's (Space Saver question) | DriftEightSix | AUSTRALIA | 11 | 01-10-2013 08:25 AM |
| FR-S space saver | sierra | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 11-29-2012 01:18 AM |
| Trunk space? | tranzformer | Scion FR-S / Toyota 86 GT86 General Forum | 34 | 04-13-2011 01:29 PM |
