Old 07-27-2022, 03:39 PM   #57
Code Monkey
Drives: Subaru BRZ
I have these lines too.
You can slide them in the grommet (yes, with some effort), and I do slide them out of the way when I need to access the upper camber bolt on my MCS's.
Code Monkey is offline   Reply With Quote
Old 07-30-2022, 02:13 PM   #58
Will_
Drives: '23 GR86 Neptune PMT
A note about pad swaps - CSG confirmed for me today that yes, you do have to remove the caliper for pad swaps. Maybe some people have figured out a way to not do it, but at least it is not designed to have pads loaded from the top.
Will_ is offline   Reply With Quote
The Following 2 Users Say Thank You to Will_ For This Useful Post:
Lynxis (07-30-2022), MrSkubi (08-01-2022)
Old 01-05-2023, 04:26 PM   #59
kobebryant339@yahoo.com
Drives: gr86
GR86
Do you have more pictures with wheels on of the calipers thinking of going this route looks fantastic
kobebryant339@yahoo.com is offline   Reply With Quote
Old 01-06-2023, 12:12 AM   #60
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Here's a few more:
And here's an OEM 18" wheel with a 10 mm Eibach spacer (needs extended studs and open/extra deep lug nuts):
Follow the build thread for my GR86!
Old 07-30-2023, 05:35 PM   #61
J1Avs
Drives: 2018 BRZ tS
Anyone have a torque spec on hand for the 2 main caliper bolts?
J1Avs is offline   Reply With Quote
Old 09-04-2023, 06:34 PM   #62
Wangspeed
Wangspeed's Avatar
Drives: 2022 BRZ
I use Tarett Porsche caliper studs instead of bolts. This allows me to just remove a nut on top. This is how the caliper was designed. Brembo cheaper out on their street kits, IMO.
I’m low on engaged threads but at least past the minimum. Tarrett doesn’t have quite the ideal length on the top, unfortunately. Longer studs increase both the bottom and top lengths, and I would run the risk of hitting the wheel. Been running this setup all year without problems.
Wangspeed is offline   Reply With Quote
Old 09-04-2023, 10:26 PM   #63
CSG Mike
CSG Mike's Avatar
Attachment 222243
How many events/hours would you say are on those pads? Are you still running CP only or is that the C1?
Old 09-05-2023, 11:04 AM   #64
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
@timurrrr what brand are those temperature measuring indicator stickers ? Looking to get a set
Thanks
autoracer86 is offline   Reply With Quote
Old 09-08-2023, 06:15 PM   #65
Wangspeed
Wangspeed's Avatar
Drives: 2022 BRZ
C1. I think I’m at 6 days
The Following User Says Thank You to Wangspeed For This Useful Post:
CSG Mike (09-09-2023)
Old 11-03-2023, 04:17 PM   #66
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
The temperature stickers are from AP Racing.
They were useless on B-M4s as the calipers never got hot enough to cross the minimal temperature on the sticker.
Well, or one could say they were useful to confirm that the caliper doesn't get hot
Another way to tell that the calipers don't get hot is to just look at the color of the caliper.
They're still bright yellow after 10+ track days, didn't turn brown like I would expect such a banana looking thing to do.
The Following User Says Thank You to timurrrr For This Useful Post:
autoracer86 (11-04-2023)
Old 11-04-2023, 09:38 PM   #67
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
Originally Posted by Dylans47 View Post
Any update as to if the caliper must be removed? I can't imagine that is the case, but that would be a deal breaker.
I have purchased the CSG kit with this caliper.
I can confirm that you have to remove the entire caliper to swap pads.
Swapping pads in this kit involves removing the top retention bracket which is the same as whats on the normal GT kit, but there is the bridge on top which you can see in pictures which is in the way. Not a big problem but it is a bit annoying. Then you punch out the pins which will release the pad. Then you remove the caliper bolts and lift the caliper off. Now you can change your pads. You CAN remove the caliper bolts first, lift the caliper with the pads attached off the rotor and then do all the work to swap the pads, but I find having the caliper mounted while you do all of this is easier. YMMV.
For me personally, I'm attending up to ~8 events per year and I'm reaching an age where even just wheel swaps are getting arduous so I'm not keen on swapping pads every event as well. Thankfully, the CSG CP pads that I got with this kit have held up to my stock power car on RT660s at my local track for 20 minute sessions without any fade. This setup is superior to using the XP10s on stock calipers on an otherwise similar car and track. The pads are pretty dusty but they are quiet and stop me fine at freezing temperatures so they just stay in and that's it.
For those of us with the original OEM space saver spare tire, you'll need ~55mm of spacer to fit the wheel over the caliper but at least I think it will work in a pinch, just take it easy when turning against the side the spare is on. I just keep the spacers in my toolbag that lives in my trunk.
Lynxis is offline   Reply With Quote
The Following User Says Thank You to Lynxis For This Useful Post:
autoracer86 (12-04-2023)
Old 12-04-2023, 07:51 AM   #68
teppey
teppey's Avatar
Drives: BRZ (in near future)
Anyone have info regarding the size of the brake pads or replacement code?
teppey is offline   Reply With Quote
Old 12-04-2023, 08:56 AM   #69
autoracer86
Drives: Toyota GT86
Originally Posted by Lynxis View Post
For me personally, I'm attending up to ~8 events per year and I'm reaching an age where even just wheel swaps are getting arduous so I'm not keen on swapping pads every event as well. Thankfully, the CSG C21 pads that I got with this kit have held up to my stock power car on RT660s at my local track for 20 minute sessions without any fade. This setup is superior to using the XP10s on stock calipers on an otherwise similar car and track. The pads are pretty dusty but they are quiet and stop me fine at freezing temperatures so they just stay in and that's it.
Very helpful. What pads are you running in the rear ?
The Following User Says Thank You to autoracer86 For This Useful Post:
Lynxis (12-05-2023)
Old 12-04-2023, 02:42 PM   #70
CSG Mike
CSG Mike's Avatar
Same shape as OEM PP pads.
GRB Brembo caliper on BRZ RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 66 11-15-2016 02:50 PM
WTB: Rear Brembo STI caliper. grostoine Want-To-Buy Requests 2 07-16-2014 05:26 PM
STI Brembo caliper mounting bolts... SkAsphalt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 05-13-2014 07:24 PM
The price of one Brembo Caliper. chuttney1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 01-18-2013 04:32 PM
