#57 |
Drives: Subaru BRZ
I have these lines too.
You can slide them in the grommet (yes, with some effort), and I do slide them out of the way when I need to access the upper camber bolt on my MCS's. |
#58 |
Drives: '23 GR86 Neptune PMT
A note about pad swaps - CSG confirmed for me today that yes, you do have to remove the caliper for pad swaps. Maybe some people have figured out a way to not do it, but at least it is not designed to have pads loaded from the top.
#59 |
Drives: gr86
GR86
Do you have more pictures with wheels on of the calipers thinking of going this route looks fantastic
#60 | |
Drives: 2022 GR86
![]() ![]() And here's an OEM 18" wheel with a 10 mm Eibach spacer (needs extended studs and open/extra deep lug nuts): ![]()
Follow the build thread for my GR86!
#61 |
Drives: 2018 BRZ tS
Anyone have a torque spec on hand for the 2 main caliper bolts?
#62 |
Drives: 2022 BRZ
I use Tarett Porsche caliper studs instead of bolts. This allows me to just remove a nut on top. This is how the caliper was designed. Brembo cheaper out on their street kits, IMO.
I’m low on engaged threads but at least past the minimum. Tarrett doesn’t have quite the ideal length on the top, unfortunately. Longer studs increase both the bottom and top lengths, and I would run the risk of hitting the wheel. Been running this setup all year without problems.
#63 | |
#64 |
Drives: Toyota GT86
@timurrrr what brand are those temperature measuring indicator stickers ? Looking to get a set
Thanks
SpareRoomRacing Youtube: https://www.youtube.com/@spareroomracing3168/featured Build Thread: https://www.ft86club.com/forums/showthread.php?t=153004
#65 |
Drives: 2022 BRZ
C1. I think I’m at 6 days
#66 | |
Drives: 2022 GR86
They were useless on B-M4s as the calipers never got hot enough to cross the minimal temperature on the sticker. Well, or one could say they were useful to confirm that the caliper doesn't get hot ![]() Another way to tell that the calipers don't get hot is to just look at the color of the caliper. They're still bright yellow after 10+ track days, didn't turn brown like I would expect such a banana looking thing to do.
#67 | |
Drives: 2013 WRB BRZ 6MT
![]() ![]() I can confirm that you have to remove the entire caliper to swap pads. Swapping pads in this kit involves removing the top retention bracket which is the same as whats on the normal GT kit, but there is the bridge on top which you can see in pictures which is in the way. Not a big problem but it is a bit annoying. Then you punch out the pins which will release the pad. Then you remove the caliper bolts and lift the caliper off. Now you can change your pads. You CAN remove the caliper bolts first, lift the caliper with the pads attached off the rotor and then do all the work to swap the pads, but I find having the caliper mounted while you do all of this is easier. YMMV. For me personally, I'm attending up to ~8 events per year and I'm reaching an age where even just wheel swaps are getting arduous so I'm not keen on swapping pads every event as well. Thankfully, the CSG CP pads that I got with this kit have held up to my stock power car on RT660s at my local track for 20 minute sessions without any fade. This setup is superior to using the XP10s on stock calipers on an otherwise similar car and track. The pads are pretty dusty but they are quiet and stop me fine at freezing temperatures so they just stay in and that's it. For those of us with the original OEM space saver spare tire, you'll need ~55mm of spacer to fit the wheel over the caliper but at least I think it will work in a pinch, just take it easy when turning against the side the spare is on. I just keep the spacers in my toolbag that lives in my trunk. ![]() ![]()
#68 |
Drives: BRZ (in near future)
Anyone have info regarding the size of the brake pads or replacement code?
#69 | |
Drives: Toyota GT86
#70 |
| GRB Brembo caliper on BRZ | RavSpec | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 66 | 11-15-2016 02:50 PM |
| WTB: Rear Brembo STI caliper. | grostoine | Want-To-Buy Requests | 2 | 07-16-2014 05:26 PM |
| STI Brembo caliper mounting bolts... | SkAsphalt | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 05-13-2014 07:24 PM |
| The price of one Brembo Caliper. | chuttney1 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 01-18-2013 04:32 PM |
