Old 09-15-2023, 08:07 AM   #29
Ohio Enthusiast
Drives: 2018 BRZ
Originally Posted by blsfrs View Post
Everybody "knows" you have to have a racing radiator
Joking aside, coolant radiator is more than adequate for track driving, at least while keeping NA. Not sure if FI needs extra cooling.
The Following 3 Users Say Thank You to Ohio Enthusiast For This Useful Post:
autoracer86 (09-15-2023), blsfrs (09-15-2023), ZDan (09-15-2023)
Old 10-23-2023, 09:12 PM   #30
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Another oil question.
Last weekend I ran at VIR. Ambient temps in the 70's. At 200*, I have 12-15psi/1000rpm. When my oil temperature was 220*-230*, my pressure stayed around 10psi/1000 rpm. 230* to 245* the pressure dropped to 6-8psi/1000. When temperatures bumped 250*, I had 40psi at 7000 rpm. I pulled into the paddock after that. I run Mobil 1 10w30.
My oil temperature is measured at the spacer below the sandwich plate. Oil pressure is taken at the galley on top of the engine.
Next event, I'm thinking of running Motul 5w40. Is there a better choice?
Old 10-24-2023, 06:10 AM   #31
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
Keep temps under 250 problem solved. I had more or less the same finding for temps under 240. Unfortunately my first track day with the oil pressure setup was wet. Even after 5 laps the temps were only 235.
but yeah 55psi at 7k and near 70psi at normal street temps.
Based off your data I would be getting myself a oil cooler but I think based off my location and normally only doing 5 Laps before pitting I can just keep the temps under 250F so no need in my situation.
If you already have an oil cooler then IDK... YOLO it lol
autoracer86 is offline   Reply With Quote
The Following User Says Thank You to autoracer86 For This Useful Post:
DannyFRS (12-06-2023)
Old 10-24-2023, 08:43 AM   #32
blsfrs
blsfrs's Avatar
Thanks, I just installed a Setrab cooler before going to the track. My temps should never have been that high, IF the cooler is operating correctly. Now that I've thought it over, I need to check that the thermostatic plate is actually working.
Old 10-24-2023, 08:52 AM   #33
Tokay444
Yes.
The Following User Says Thank You to Tokay444 For This Useful Post:
blsfrs (10-24-2023)
Old 10-24-2023, 09:15 AM   #34
autoracer86
Drives: Toyota GT86
oh damn hope everything is good in the end. I would think under 250f would no problem for an NA car.
How big is the core compared to say the JR racing one ? Also do you have a shroud
blsfrs (10-24-2023)
Old 10-24-2023, 10:03 AM   #35
blsfrs
blsfrs's Avatar
The cooler is the Setrab series 1-34 row. It should be slightly oversize for my application. With the ambient temps in the 70's, I shouldn't have been over 212*ish.
No shroud. It mounts to the back of the bash bar so it's only a couple of inches behind the grill.
The Following User Says Thank You to blsfrs For This Useful Post:
autoracer86 (10-24-2023)
Old 10-24-2023, 10:28 PM   #36
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I'd look into shrouding the cooler. I dropped temp a bit just by repositioning mine up a couple inches since it was sitting behind the "chin" of the front bumper a bit.
blsfrs (10-25-2023)
Old 10-27-2023, 10:16 AM   #37
blsfrs
blsfrs's Avatar
The Setrab cooler is about 10" tall so most of the core is in good air flow. If you squint, you can see the cooler core behind the wire.
I checked that the thermostat closes at 180*.
So far, I can't figure out why my oil temps were so high.
The Following 2 Users Say Thank You to blsfrs For This Useful Post:
NoHaveMSG (10-28-2023), Ultramaroon (10-27-2023)
Old 10-27-2023, 04:12 PM   #38
It can be tricky to get proper airflow. Cross flow between the coolers can actually kill the pressure differential needed to force air through. Might be as simple as walling off the area between the oil cooler and AC condenser. Try some cardboard and tape for science.
NoHaveMSG (10-28-2023), Spuds (10-27-2023)
Old 10-27-2023, 08:30 PM   #39
blsfrs
blsfrs's Avatar
Good thought. I also left out the foam spacer in front of the bash bar, which someone before speculated might influence air flow.
The temperature problem only manifests on the track. In 2 weeks, I'm going to Summit Point. I'll wall off the open area and see what happens.
Ultramaroon (10-28-2023)
Old 10-28-2023, 01:55 AM   #40
wait... was that me? haha...
blsfrs (10-28-2023)
Old 10-28-2023, 03:09 AM   #41
makinen
makinen's Avatar
Drives: Toyota 86
It'll be helpful to get air guide panels.
/* Custom underbody panels and diffuser
Custom electric water pump and PWM controller
makinen is offline   Reply With Quote
The Following 2 Users Say Thank You to makinen For This Useful Post:
blsfrs (10-28-2023), NoHaveMSG (10-28-2023)
Old 10-29-2023, 07:30 PM   #42
blsfrs
blsfrs's Avatar
Project Shroud
Fun weekend project. I hope this works. And yes @Ultramaroon, I put the danged foam piece behind the bumper.
The Following 4 Users Say Thank You to blsfrs For This Useful Post:
autoracer86 (10-31-2023), NoHaveMSG (10-29-2023), Ultramaroon (10-29-2023), x808drifter (10-30-2023)
haha
Full Race external oil cooler kit duqx Engine, Exhaust, Bolt-Ons 1 01-20-2019 08:41 PM
External mic placement Shark_Bait88 Tracking / Autocross / HPDE / Drifting 22 06-13-2016 06:39 PM
Anyone have info on the BRZ OEM external oil cooler (Japan only)? mav1178 Engine, Exhaust, Transmission 5 04-22-2016 12:20 AM
External Wastegate Question TurboBRZ Forced Induction 23 07-22-2015 12:38 PM
