Old 10-20-2023, 07:17 PM   #1
Loganp98
Drives: White Subaru brz
Hey guys I need help with a code
My 15 BRZ has code P2109. I can’t figure out why. I tried a test throttle body and a test PCM. The code won’t clear with my OFT and the battery disconnected. It popped up after I had reinstalled the intake manifold. I’ve checked no wires are pinched. Thanks
Loganp98 is offline   Reply With Quote
The Following User Says Thank You to Loganp98 For This Useful Post:
humfrz (10-22-2023)
Old 10-22-2023, 02:41 AM   #2
I checked with Bubba and he says to disconnect the negative battery terminal, have a beer, after about 5 minutes reconnect the battery.
Maybe it will reset -
https://studentlesson.com/how-to-res...sition-sensor/
Old 10-22-2023, 05:07 PM   #3
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Instead of trying parts, try a scan tool to read live data. You need to know the throttle plate position.
One of the following conditions is met (1 trip detection logic):
The throttle position sensor opening angle when learning the fully-closed position is less than -4.02% or more than 4.02%.
When the throttle actuator current is off, the difference between the actual throttle position and the fully-closed position is less than 0.93%.
The Following 2 Users Say Thank You to RZNT4R For This Useful Post:
Opie (10-25-2023)
Old 10-25-2023, 11:52 AM   #4
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
Factory diagnostic steps below, is P2109 the only code set?
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
Old 10-30-2023, 05:52 PM   #5
Loganp98
Yeah only one on is P2109. Throttle % on my scan tool is stuck at 5%
Old 10-31-2023, 04:22 PM   #6
Opie
Opie's Avatar
And you said you've tried a known good throttle body against the one currently in the car? If so, It's got to be damage on the engine harness somewhere.
Old 10-31-2023, 10:44 PM   #7
Loganp98
Can’t 100% confirm if it is good considering i bought it used. I hate to spend the money on a brand new one considering I bought a grams throttle body for this thing not too long ago. But I won’t know for sure until I buy a new one 😕
Opie (11-01-2023)
Old 11-01-2023, 09:07 AM   #8
Opie
Opie's Avatar
Have you looked at the pins on the throttle body harness connector, make sure none are bent or missing?
DIY - Color Code of ID plate and code of part (SUBARU) - SB18-091 Trap63 DIY (Do-It-Yourself) Guides 0 06-14-2018 05:52 AM
p0462 fuel level sensor code. anyone else ran into this code georgiafrsguy Engine, Exhaust, Transmission 1 02-28-2017 09:28 PM
Lean Code and 02 Code diagnostics. Kiske Engine, Exhaust, Transmission 12 04-28-2016 11:19 PM
CEL code ChandlerSwyng Issues | Warranty | Recalls / TSB 2 04-08-2014 02:27 AM
BC Coilover settings you guys guys ride on g0lden Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 04-06-2014 07:56 PM
