Old 09-11-2023, 09:49 PM   #29
new2subaru
Weight Weenie
Drives: 15 FR-S
Agree.
Ferodo DS2500 are a good "aggressive" street/canyon/autox pad that feels pretty good, dusts a lot, and can take a little heat. I still wouldn't track them on 200tw tires. There are slightly cheaper, slightly more street oriented pads that would probably do the trick, but if you're set on the Ferodos that's okay
I just finished off a set of DS2500's The fronts anyways. I was doing well at first but by the end of day one they declined. I've been sanding them between track days and babying them on track days. I did better with Hawk DTC 30 and 60. I just had a set of DS3.12 arrive today. I don't know what DS2500 they would be like on AutoX
Day 1
The Following 2 Users Say Thank You to new2subaru For This Useful Post:
Racecomp Engineering (09-12-2023), Spuds (09-12-2023)
Old 09-12-2023, 06:40 PM   #30
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
Take Toyota’s service manual requirements with a ‘grain of salt’. They play it safe and replace many items which may not be at end of life. That’s why dealer serviced Toyotas last forever.
Regarding pads, consider Stoptech Sports for a great DD and occasional track day solution. I cannot comment on there autocross capabilities but do use them for DD-Lapping and am very satisfied. They last, don’t destroy rotors and they’re cheap!
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS-V/EvoX Brembos
Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms
235F/245R Conti ECS on TRD/Enkei wheels (street),
245/40 sq. ECF on 17x8 720Form GTF2 wheels (track)
Muskoka800 is offline   Reply With Quote
The Following User Says Thank You to Muskoka800 For This Useful Post:
Spuds (09-12-2023)
Old 09-12-2023, 10:52 PM   #31
ruturaj001
Drives: BRZ 2023
I use ferodo DS 2500 on track, I got mine on Amazon for pretty cheap. They do the job and have lasted 20 mins sessions for me. I am new to the track, first year, so my needs were not demanding, I am also on factory PS4 tires. I am not getting 200tw any soon though, may be 4S (or S5).
I am planning to get CSG CP pads next though, to compare the life, road and track performance etc. As per as I ahve heard they last longer (twice) even if they cost double and also perform better. So seems like it saves the job of changing them once.
For fluid I use Castrol SRF, it lasts longer (2x) and costs more (3-4x). I hate the bleeding job more than pad changes.
ruturaj001 is offline   Reply With Quote
Old 09-13-2023, 04:45 PM   #32
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Ordering OEM brake parts is a PITA apparently because all the sites seem to think there are 3 different parts that will fit unless you have a Subaru VIN and even then my guess is they are confused. Nobody seems to have mapped out what part numbers go to the US spec rotors, and the descriptions don't say anything about size, so I decided to order Centric instead.
As for the brake lines, there are apparently 3 options for 2013. Knowing build date seems to help, but then there are 2 options for rear lines on the same date. Took a chance on what seemed most likely based on similarity to the front PN. Idk it's $30.
I'll report on the PNs if it works I guess.
Also: "Build Thread"
The Following User Says Thank You to Spuds For This Useful Post:
soundman98 (09-13-2023)
Old 09-13-2023, 08:06 PM   #33
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Maybe go to a store?
Spuds (09-13-2023)
Old 09-13-2023, 08:09 PM   #34
The Following 4 Users Say Thank You to Ultramaroon For This Useful Post:
new2subaru (09-13-2023), soundman98 (09-13-2023), Spuds (09-13-2023), strat61caster (09-15-2023)
Old 09-13-2023, 08:35 PM   #35
Spuds
The Dictater
Spuds's Avatar
That is something I did not try. I didn't think AutoZone or NAPA would stock or order OEM Subaru/Toyota parts, it was my understanding that they would get an "equivalent" part, but usually at much greater cost than online distributors. Is my understanding incorrect?
This is specifically a problem with the Subaru/Toyota parts because they do not have good descriptions in some cases. If I wanted something "equivalent" I'd just hit up Rockauto or Amazon, which I did with the rotors. MSRP at a local dealership parts counter is way higher than what it costs online so I'd rather not go there if I don't need the part right away.
Old 09-14-2023, 06:37 AM   #36
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
The oem pads kinda suck anyway. I found them to be pretty difficult to remove when pad swapping at the track and they can be noises at times. I did see others having the same issue on a Facebook thread awhile back.
I will be switching to a oem + pad for street usage at some stage
autoracer86 is offline   Reply With Quote
Old 09-15-2023, 04:39 PM   #37
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
I've got a Toyota dealer that I like to buy parts from, if there's confusion on which part calling up one of their employees on the phone can help sort out the problem since they have more information then gets put on the generic website.
Ordering oem online and picking up at the dealer on the way home from work or over to work on the car has been aces. Prices have been completely in-line with buying non-oem parts online + shipping. Like, I might spend less then 5% more vs. say exedy or bosch or ngk.
I hate interacting with people too, but dealership parts counter people aren't working on commission, they've got access to a regional warehouse and whatever profit the owner targets and that's that.
They're geeks too, guy was excited to hand truck out my shortblock lol.
I learned this about 10 years ago buying Nissan parts when they had weird stuff in stock nobody else could get and were cheaper too. A couple dealers slap insane markups on their parts and I had one or two Subaru dealers require a Subaru VIN which I didn't have so I just went down the block to Toyota.
ineedyourdiddly
Spuds (09-15-2023)
Old 09-16-2023, 04:17 PM   #38
Muskoka800
Here in Ontario Canada I have found Toyota parts are about 60% of what the Subaru dealers ask, for the same part. That said, the Subi dealer has some items in inventory (likely due to parts crossing between Subi models) while Toyota dealers rely on overnight supply from the Toronto Parts Distribution Ctr.
Old 09-16-2023, 10:09 PM   #39
new2subaru
Weight Weenie
Drives: 15 FR-S
I've had the Toyota dealership have to fly stuff in from CA more than once.
Old 09-16-2023, 11:02 PM   #40
My Toyota dealership always has everything I need.
Old 09-17-2023, 11:25 AM   #41
Muskoka800
Yes, over the past year or so Toyota Canada had a major parts inventory issue and many parts had to come from Cali. I’m told they were changing computer programs/system which led to stock shortfalls. I imagine those who required urgent repairs were pissed at the wait for parts.
Old 09-18-2023, 06:50 AM   #42
new2subaru
Weight Weenie
Drives: 15 FR-S
I haven't ordeerd in a long while. 4-5 years? I was ordering things like spare caliper bolts, wheel studs, etc and they had nothing in stock at my local. I can only imagine how it is now with the parts shortages.
Is your car ready for track yet? The break it done?
Spring shopping list Ignore Your Doctor Want-To-Buy Requests 0 04-07-2019 12:56 PM
FRS Engine Upgrade Shopping List PapaJ Engine, Exhaust, Transmission 19 02-07-2019 11:35 PM
Christmas shopping list Ignore Your Doctor Want-To-Buy Requests 1 01-01-2019 10:11 PM
Forged internals - shopping list help ChrisD Engine, Exhaust, Transmission 22 07-19-2015 11:12 PM
Shopping List : building a faster car! Philly CANADA 8 06-28-2012 08:58 PM
