Old 07-24-2020, 08:01 PM   #379
DJ_JAZZY_DJENT
j@ckoffofalltrades
DJ_JAZZY_DJENT's Avatar
Dirty Dealer Fingers
Added:
NHTSA Campaign Number: 18V772000
Manufacturer Subaru of America, Inc.
Components ENGINE AND ENGINE COOLING
Potential Number of Units Affected 165,534
Engine Valve Spring Failure may cause Engine Stall
Can someone tell me if this valve spring recall mandatory
I assume its the reason the dmv is not letting me re-register my car.
Ive gotten 2 registration tickets already.
so monday 2020/07/20 I dropped it off at normreevestoyotasandiego.com and was running PERFECTLY.
(As a side note I put my clutch and flywheel in this after replacing the melted throw-out bearing in about 3 hrs on jack-stands. Worked on RX7's dirt bikes etc since i was young. I know what time it is)Also replaced two plugs so far. so as soon as i mentioned that the service goons at Toyota try to pump up their chest and condescendingly state "that thing uses very specific plugs are you sure you installed the uranium ones?" Hand to god that is his exact quote I almost ran my head through the window. Then I answered, if you mean IRIDIUM plugs, yeah, they were I dont think anyone even makes an 86 plug that is not iridium. After he badgers me about tires and plugs I said yeah how much for plugs, and after a LONG back and forth with his guy on the phone, he comes back with $160.00 !!!!! I said !@#$ no, you can keep my old ones in there. Now my reciept mentions "Customer declines service recommendations" but it doesnt state the $160.00 quote on there as proof that they tried to pull one over on the customer. What a scam, how can these goons get away w this? Better yet, Who can I file a complaint with.
DJ_JAZZY_DJENT is offline   Reply With Quote
Old 07-24-2020, 08:37 PM   #380
It is but only in California.
Old 07-24-2020, 11:20 PM   #381
The cost to change the plugs in these is around $400 normally so $160 is a deal.
Oh and you sound like an arrogant **** so have fun with your complaints.
Old 07-25-2020, 03:26 AM   #382
gravitylover (07-29-2020)
Old 07-25-2020, 03:38 AM   #383
DJ_JAZZY_DJENT
j@ckoffofalltrades
160 for plugs and labor WOULD BE a great deal; except, the service tech made it very clear that because they already have to pull the motor, they "WILL NOT CHARGE ME FOR LABOR." so then I was waiting for a price of roughly 20-30$ each, which was obv fantasy. As for your slight towards my personality, whatever you say. Enjoy your trolling.
The Following User Says Thank You to DJ_JAZZY_DJENT For This Useful Post:
humfrz (07-25-2020)
Old 07-25-2020, 03:40 AM   #384
DJ_JAZZY_DJENT
j@ckoffofalltrades
Thanks much.
Old 07-25-2020, 04:29 AM   #385
Well, DJ_JAZZY_DJENT, it sounds like you are in between a rock (DMV) and a hard spot (dealer to do the work).
Yep, $160 does sound like a lot for the plugs, but I have found that sometimes it's just easier to "pay up" than fight it.
You may try to "bring your own plugs" to the party, that may save you a few dollars.
In light of the entire recall process, that $40 - $80 price difference for the plugs may be minor. You may want to save your ammo for a bigger battle.
Dadhawk (07-25-2020)
Old 07-25-2020, 12:45 PM   #386
So. They are not charging you labour to pull the engine but just for the parts and about half an hour of shop rate to change the plugs. You expect them to change the plugs just for the parts price? You understand it is still extra work right? Do you volunteer your time for free at work? It is how they earn their living and they are not demons because they want to make at least a little money.
humfrz (07-25-2020)
Old 12-02-2020, 07:10 PM   #387
gcmak
gcmak's Avatar
Drives: GR86
Originally Posted by immortal_suby View Post
Manufacturer: Subaru of America, Inc.
Components: suspension mounts
Number: 05-61-16
I didn't see this TSB in here. I am having this problem of popping noise from the strut mount and searched the forum but did not see anything from subaru about it. There are several threads on suspension noise that point to the top mounts but no mention of a TSB.
I was very close to buying the parts and doing it myself based on the how-to's I've seen here for suspension and then stumbled upon the TSB.
Maybe I'm the only one over 60k still running the stock suspension....
@ichitaka05
Today, brought my 2020 BRZ w/2,000 miles to service for an interior issue and have been hearing this noise when i park. They inspected it and said my car would be covered under some TSB around the strut noise (assuming it's this one). Seems like my car shouldn't be part of this TSB...but thanks for sharing it.
gcmak is offline   Reply With Quote
Old 12-03-2020, 07:57 AM   #388
Ragin Gti
Drives: '15 Subaru BRZ
You are correct, that TSB applies to ‘13-‘16 BRZ.
Ragin Gti is offline   Reply With Quote
The Following User Says Thank You to Ragin Gti For This Useful Post:
gcmak (12-05-2020)
Old 03-24-2021, 09:29 PM   #389
ClevelandFRS
ClevelandFRS's Avatar
Drives: Scion FRS 2013
My 2013 FRS had a total engine replacement, I have just over 4000 miles on it. The Chirping is just horrendous. I actually got a noise complaint about it as I was sitting parked in a parking lot at night. So...now I need to really try to get this looked at.
I've been researching this for a year now and I've tried every fuel type imaginable with no positive results. Nonethanl 0%, every possible gas station in the area. Chrips non stop and sounds like a UFO rolling down the road, its a legit embarassment as its loud enough to be heard with the windows up and some music on.
However, I love my FRS and dont want to sell it. I do want the chirp gone. So what does Toyota and Surbaru say about this that can be done to fix it? I worry about having the fuel pump changed and risking them damaging or causing more problems for my car. I've not had a single problem with my car, its in immaculate condition.
but, I was referred to this thread to try to see if some type fo newer part replacement exists now in 2021, or if anyone has any actual fixes for it.
After this noise complaint, I can no longer sit parked where I usually do at night. :\
ClevelandFRS is offline   Reply With Quote
Old 04-03-2021, 12:10 PM   #390
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
@ichitaka05 The following link attachment is broken.
11-184-18 : DIG P119F and P219A ECM Reprogramming
Old 09-11-2023, 01:24 PM   #391
Recall for 2022 BRZ/GT86 (Rear Lighting)
Here's the Link
Makes/Models/Model Years:
SUBARU/BRZ/2022
TOYOTA/GR86/2022
Mfr's Report Date: August 31, 2023
NHTSA Campaign Number: 23V-609
Components:
EXTERIOR LIGHTING:TURN SIGNAL
Potential Number of Units Affected: 8,915
Problem Description:
Subaru of America, Inc. (Subaru) is recalling certain 2022 BRZ and Toyota GR86 vehicles. The rear turn signals may intermittently
become inoperative.
Consequence:
Inoperative rear turn signals may not notify other drivers of a turning vehicle, increasing the risk of a crash.
Remedy:
Dealers will replace both rear combination lamp assemblies, free of charge. Interim letters notifying owners of the safety risk are
expected to be mailed October 29, 2023. Second letters will be sent once the remedy is available.
chirping, high pressure fuel pump
Recall I think so!!!! RWD-boxer Issues | Warranty | Recalls / TSB 16 10-07-2012 11:39 AM
FRS recall? totally Issues | Warranty | Recalls / TSB 8 08-30-2012 01:01 AM
Recall! already earthsscum BRZ First-Gen (2012+) — General Topics 1 06-07-2012 08:00 PM
Owners Manual Recall Opie BRZ First-Gen (2012+) — General Topics 8 06-05-2012 11:09 PM
Did anyone get a call from toyota about a recall yet? AustinTCLN Scion FR-S / Toyota 86 GT86 General Forum 2 06-05-2012 12:45 AM
