| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Drives: 2013 BRZ HKS Turbo
Oil Pan Seal Rings
Pulled my pan to weld on turbo oil drain, installed it and don't seem to have any problems. However, another thread in here made me check the factory service manual, and I found this
![]() I did not install these 2 "oil pan seal rings". What are they for, and do I need to pull the pan again?
IG: @terboboost | Twitter: @terboboost | youtube.com/@terboboost | D-corp.co
#2 |
Drives: Crapcan
I believe you are fine.
| The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | DocWalt (04-19-2023), Ultramaroon (07-13-2023) |
#3 |
Drives: 2016 Scion FRS Release Series 2#439
I re-used mine since they were not included in the OEM’s re-build gasket kit.
After all, any oil leaking past them just ends up in the oil pan, where it is destined anyway.
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS-V/EvoX Brembos Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms 235F/245R Conti ECS on TRD/Enkei wheels (street), 245/40 sq. ECF on 17x8 720Form GTF2 wheels (track) |
#4 |
Don't underestimate the siphoning action at work. That's the whole point of those drain tubes. They cost money to make and should not be neglected.
#5 |
Drives: 2017 BRZ w/PP
#6 | |
Nothing is added without good reason. When the purpose of a part, or subsystem in this case, isn't clear to the owner, the correct decision is to assume that it's important.
| Driver's side window seal/door seal | KAB-FRS | Issues | Warranty | Recalls / TSB | 255 | 01-01-2021 07:09 PM |
| Hubcentric Rings | ry_zillafrs | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 10-31-2016 12:09 AM |
| AEM gauge rings | Mike&Ike | Want-To-Buy Requests | 0 | 12-03-2014 12:18 AM |
| HUB Rings - Aluminum 73.1 - 56.1 | Jay2420 | Canada Classifieds | 0 | 10-16-2014 06:52 PM |
