Drives: GR86
Race seats install - Airbag codes
I removed all stock seats and installed a driver and passenger race seats.
I’m getting an Airbag error on the dashboard. Besides the annoying warning, I won’t pass the State safety inspection if I don’t sort it out. The rear seems to be ok. I removed the wiring harness and sensor from the seat belt as well as the occupancy sensors from the rear seats, and plugged them all in the back. It does not appear as though I’m getting any codes in the rear. I’m getting five codes in the front. Here’s my setup: Driver side: used a Brad’s Hack dongle for the yellow airbag plug, and connected the seat belt connector into the beige plug. I kept the stock seat belt which chimes when not buckled, so I’m guessing it’s working ok. Passenger side: used Brad’s Hack dongle for the yellow airbag plug. Removed the occupancy sensor and seatbelt wiring harness (with the sensors) from the stock seat and plugged them into the gray plug. I zip tied the sensors together to the seat rail. What am I missing/doing wrong? |
#2 | |
Drives: 2018 Subaru BRZ
I believe there is a Kevin Vo veido on Youtube where he talks about race seats installation on the 2nd Gen vehicles. I would recommend checking it out?
#3 |
The computer is looking for a certain resistance/value to verify all sensors are functioning. Every component you removed will need some type of resistor or such to trick the computer int believing it is there and functioning. As stated above start YouTube mechanicing, I am sure someone has figured it out.
| Base model BRZ - What do you need to bypass airbag light errors with race seats? | X25 | BRZ Second-Gen (2022+) — General Topics | 16 | 09-10-2023 04:21 AM |
| BRZ seats installed into FRS... Airbag Light | Wpomp | Cosmetic Modification (Interior/Exterior/Lighting) | 39 | 03-27-2021 04:07 PM |
| Airbag codes B1800 and B1810 | Skylinehead | Electronics | Audio | NAV | Infotainment | 2 | 09-07-2018 02:42 AM |
| Bucket seats - airbag issue | smudge | Cosmetic Modification (Interior/Exterior/Lighting) | 18 | 03-04-2017 11:45 PM |
| No Race Track Seats in Race Car Drivers Every Day Cars..!! | JohnnyNight | Cosmetic Modification (Interior/Exterior/Lighting) | 24 | 10-16-2012 05:42 PM |
