New clutch creaking noise
I just got a new clutch installed. Exedy clutch kit with new TOB. I also got verus fork and pivot installed. After a couple days, clutch starts making this noise when pressing it down slowly all the way. The noise is quieter in the cabin and louder near the slave cylinder area by the engine. I’m thinking I need to lubricate the pivot joint with grease. Any ideas? Thanks.
https://www.youtube.com/shorts/hQnkycC_6fQ |
#2 | |
Proud of BOXER
Drives: Subaru Boxer
DIY or shop install?
#3 |
Professional Mechanic
Drives: 2017 86 6MT Oceanic
My stock clutch fork does that, I need to get around to it.
Put a dab of EP grease on the end of the slave rod, if that doesn't fix it, transmission needs to get pulled off and grease applied to the pivot ball. |
| The Following User Says Thank You to RZNT4R For This Useful Post: | soundman98 (07-08-2023) |
#4 |
#5 | |
Proud of BOXER
Which shop? What did they say if/when you asked about this?
#6 |
#7 |
I applied Lucas Oil Products Red N Tacky Grease to the top of the pivot ball and the slave cylinder linkage. So far it's quieter but the noise is still there. There is no audible noise when the engine is on and It shifts fine so I am assuming its not a big problem to worry about... I will reapply again in a couple of days and keep observing for any changes
#8 |
Some local independent shop near my area. Since I brought my own parts they won't honor shop warranty. If my problem persists I'll give them a call out of curiosity.
Last edited by swiftskii; 07-07-2023 at 10:10 PM. Reason: Forgot to quote a response |
| Popping, Crunching and Creaking Noise | MyEvilMonkeys | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 22 | 07-22-2020 01:50 PM |
| Creaking noise while turning | WRITEX | Issues | Warranty | Recalls / TSB | 20 | 01-26-2020 06:25 PM |
| Creaking noise coming from the rear | alex87f | Issues | Warranty | Recalls / TSB | 9 | 10-08-2018 12:47 PM |
| Creaking noise from overpipe | sydious | Engine, Exhaust, Transmission | 4 | 06-27-2018 03:13 AM |
| Clutch creaking noise (not the clutch fork one...) | treminaor | Issues | Warranty | Recalls / TSB | 59 | 10-23-2017 02:53 AM |
