Old 08-07-2021, 02:50 AM   #1
Ryūkotsusei
Junior Junior Member
Drives: 2014, Aquamarine
Clicking from Behind Glove Box
2014 Monogram, auto.
Easy fix? This is above and to the left of the cabin filter.
Lengthier description for any future
Since purchasing the FRS, there was this sound as though a vent door was opening/closing behind the glove box roughly 30 seconds after turning off the engine. It got rougher with time as though whatever controls it started to fail. Eventually, I heard a clicking sound with the engine off. Now it's happening even when the engine is running.
Ryūkotsusei is offline   Reply With Quote
Old 08-07-2021, 04:39 AM   #2
I have no idea what's going on -
Let me ring up ol @Tcoat for you, he is good with mystery sounds.
Old 08-07-2021, 09:43 AM   #3
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Easy fix? Depends on if it's the actuator's that's skipping, or if the door is binding inside the air distribution unit.
Actuator fail often and they're usually easy to replace unless the engineer that designed the system decided to mount it behind the AC unit like I've seen done on cars from GM, Chrysler and Ford. If it's the air door, it's a dash removal.
Feel which actuator is skipping by touch, remove it, move the air door end to end with your fingers, if it doesn't bind, replace the actuator.
Old 08-07-2021, 12:26 PM   #4
sato
sato's Avatar
Drives: Dodge Patitas
Subscribed: I believe I've been recently hearing something similar from my 2014 Monogram (manual) also. Starting to think it could be related to the automatic A/C controls (what the BRZ limited has). However, my car is said/similar making noises like it was.on steroids... It has approx. 144k miles.
Looks like we have some work to do, and something that a dealer would simply just charge you $2000 to replace the whole system instead of finding what's wrong.
Sent from my Pixel 3 using Tapatalk
sato is offline   Reply With Quote
Old 08-07-2021, 01:14 PM   #5
RZNT4R
Nah, I have a low opinion of dealer techs, but this isn't the thing to make money on. Small jobs with many small parts pay more than big jobs with few parts. Any service manager should know that it's more profitable to lose a tech for an hour on an actuator replacement than to lose him for 8 on a dashboard removal.
Old 07-05-2023, 06:03 PM   #6
Kauf
Drives: 2014 SSM BRZ
Anyone have the fix for this? I have this same sound going on.
Kauf is offline   Reply With Quote
Old 07-11-2023, 09:41 PM   #7
It's the crickets - it's mating season -
Old 07-22-2023, 11:51 AM   #8
Ryūkotsusei
Thank you!
I saw your notification. I actually ended up replacing SU003-02044 to fix this. RZNT4R's advice helped.
Also, correct. The dealership here quoted me $1,700. They wanted to remove the entire dash so who knows what else they'd mess up.
Found this from another thread for additional context:
Originally Posted by Chaetagnath View Post
The one with the metal bracket (part number SU00302044) controls the direction of the airflow. It also requires this plastic piece, which should also come with it:
Incidentally, The inside of the plastic housing if you take it off looks like this:
As you can see, each servo moves a little door independently which mixes heat/cold air. I don't know exactly what it looks like in the manual version, but somehow those two shafts must be connected, unless it is a single piece.
Old 07-22-2023, 05:16 PM   #9
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Crickets and gremlins from my experience!
Old 10-22-2024, 09:20 PM   #10
nick.cfrancis
Drives: 2017 Subaru BRZ Limited Performance
Thank you!
@Ryūkotsusei did you need to pull the dash to replace the actuator SU003-02044 / 72131CA030 ?
nick.cfrancis is offline   Reply With Quote
Old 12-14-2024, 10:46 AM   #11
Ryūkotsusei
Unfortunately, I ended up doing so!
WTB Glove Box TheDetailer718 Want-To-Buy Requests 1 05-23-2017 12:29 AM
Glove box USB Eman Electronics | Audio | NAV | Infotainment 2 01-15-2017 09:34 PM
Glove box keypad Yalsaket Scion FR-S / Toyota 86 GT86 General Forum 11 03-20-2015 01:59 PM
glove box 12v light? lbroskee Cosmetic Modification (Interior/Exterior/Lighting) 3 03-11-2013 10:44 PM
Loose Glove Box Spd229 Cosmetic Modification (Interior/Exterior/Lighting) 0 12-06-2012 01:53 PM
