GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86 |
06-25-2023, 04:16 PM | #29 | |
ProCrastinationConsultant
but why/where did people learn of the 86 heritage? i never knew of intial d or wangan midnight until well after i had decided to purchase the car and started looking into it further. at that point, manga's/anime were the same thing, and were only for the cheeto-covered comic book lurkers. but without even searching, i can tell you about marty mcfly's obsession was with a 1985 black sr5 xtracab that was a single year option with the old-style solid front axle, but the new style body. that set of roll bars has sent me down rabbit holes that i'm almost too ashamed to even admit to... https://silodrome.com/back-to-the-future-toyota-hilux/ toyota even did a promo 2016 tacoma re-make. it was a 1-off-wonder though. they never sold parts for it, and most was custom-fabbed https://www.motortrend.com/news/back...-back-to-1985/ i've tried finding a source for the light bar-- it doesn't exist anywhere, i've got ideas to build my own. it's the only reason i've priced out hydraulic tubing benders.
06-25-2023, 11:58 PM | #30 |
Drives: Toyota
06-26-2023, 10:26 AM | #31 | |
Drives: '23 BRZ Limited
So that's not any deficiency of the stock brakes. I'd bet the "Performance Pack" cars with Brembo's are using the exact same fluid as the non-Brembo cars.
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
06-26-2023, 12:28 PM | #32 | |
Drives: 2022 Toyota GR86 Premium 6MT
And I say this as somebody who blew money on a BBK. And then put akebono ceramics on them just like the stock pads lol. |
06-26-2023, 12:50 PM | #33 | |
"I want to do X" "Ok, why do you want to do X? What behavior are you trying to correct?" *crickets* Hell, I want to do a BBK just because it would look awesome behind my wheels and I have no intention of tracking mine.
The Following 2 Users Say Thank You to OkieSnuffBox For This Useful Post: | fredzy (06-26-2023), soundman98 (06-26-2023) |
06-26-2023, 12:57 PM | #34 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
Want my wheels more horizontal to the local grav gradient and make the car hover.
Simples, right?
"I gotta rock." -- Charley Brown |
06-30-2023, 11:43 AM | #36 |
Drives: GR86
The Brembos are red. That's about it.
The stock brakes will engage the ABS, which means they're more than capable of applying the maximum braking force the tires can grip under. If you want to stop better/faster, you need grippier tires, not bigger brakes. As others have said, the conditions matter more than anything else - on a track you're going to heat your brakes to the point where you start to boil the stock brake fluid. THAT is going to immediately tank your braking ability just like if you didn't bleed the lines and left air in there. So that's why "better" brake fluid is basically required for track days (it has a higher boiling point at the cost of being more hydroscopic, meaning it'll yank water out of the air faster and go bad sooner. It's also more expensive.) Pads for the same overall reason - stock pads are built for road use: low noise, low dust. But at high temps they wear faster to the point that on a track you'll burn them up super fast - like the first day probably. I mean, the Brembos do look cool with the white lettering on the red, but there is a LOT you can do to make the brakes "better" for a tenth the cost, then get some high-temp red paint and make the stock calipers pretty. |
The Following User Says Thank You to Spektyr For This Useful Post: | OkieSnuffBox (06-30-2023) |
06-30-2023, 11:49 AM | #37 | |
Guilt free parts vulture!
Drives: 2013 FR-S - Asphalt 6MT
More details...
https://www.caranddriver.com/reviews...package-drive/
According to this article, the brake upgrade is more than the calipers... larger rotors and pads are part of it too. As the linked article states: not a huge difference in bite... and a fluid change is recommended. I imagine the larger rotors, coupled with good fluid and pads will make this a nice upgrade for the occasional HPDE user.
The Following User Says Thank You to nextcar For This Useful Post: | Sport-Tech (06-30-2023) |
06-30-2023, 11:54 AM | #38 | |
Drives: '23 BRZ
06-30-2023, 12:08 PM | #39 | |
Drives: GR86
It's just not tough enough for track use. |
06-30-2023, 01:10 PM | #40 | ||
Then I'll the AP Sprint kit which is a better setup for tracking than the OEM Brembo setup..........and it knocks 20lbs off the nose of the car.
06-30-2023, 01:42 PM | #41 | ||
Drives: Q5 + BRZ + M796
The Following User Says Thank You to Irace86.2.0 For This Useful Post: | soundman98 (06-30-2023) |
06-30-2023, 01:43 PM | #42 | ||
Just upgraded tires, fluids, pads, and -2 degrees are all I want/need/use.
Similar Threads | ||||
Trueno Blue GR86 Thread | VoltsFRS2013 | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 63 | 07-12-2023 01:56 AM |
Dan's Trueno Blue Street GR86 Build | VoltsFRS2013 | Member's Car Journals | 1 | 11-15-2022 05:27 PM |
Toyota Celebrates the Pure Sports Car with 2023 GR86 Special Edition | Sport-Tech | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 69 | 06-19-2022 02:35 PM |
2nd gen BRZ/GR86 Performance Stats | Dirty Harry | BRZ Second-Gen (2022+) -- General Topics | 0 | 04-13-2022 08:54 PM |
Modern Automotive Performance (MAP) Turbo kit experience | SmsAlSuwaidi | User/Vendor/Sponsor Reviews, Feedback, Comments | 4 | 04-02-2016 03:29 AM |
