Old 05-26-2023, 05:18 PM   #1
Lifton
Drives: car
Cam Sprockets 2017+ vs 2013-2016
Hi all,
Wondering if anyone knows if 2017+ cam sprockets will fit a 2013-2016 FT86?
They do have different part numbers. Does anyone know what the differences are? Can't seem to find any information regarding this.
Thanks in advance!
Lifton is offline   Reply With Quote
Old 05-26-2023, 05:42 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
No, the little reluctor wheel on the cam sprocket that the cam position sensor picks up is different. 13'16' are innies, 17'+ are outies.
Ultramaroon (05-27-2023)
Old 05-26-2023, 06:11 PM   #3
Lifton
Drives: car
Ah I see that now, thank you for the information. I called some dealers and they said it would work but I'm not so sure. Looks like I'll err on the side of no for now.
Old 05-26-2023, 07:02 PM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Potentially it may work. The cam position sensor is basically just a hall effect sensor and the ECU is just looking for a change in signal to indicate cam position so theoretically it could learn it. There was a thread a while back with someone running different cam sprockets for the year of his car. It was fine for a while but I believe he eventually ended up with a code. I'd have to look for it. @Ultramaroon you remember that one?
Old 05-26-2023, 10:01 PM   #5
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Hi all,
Thanks in advance!
IIRC from my limited research, the ECU from a 2013-2016 won't know what to do with the sprocket/sensors from a 2017+ . The part numbers are unique between the 2013-2016 and 2017+ engine series.
EndlessAzure is offline   Reply With Quote
The Following User Says Thank You to EndlessAzure For This Useful Post:
T-Steve (05-27-2023)
Old 05-26-2023, 11:30 PM   #6
I do! I forget which way the ECU can compensate but it's a one-way trip. I don't remember if the original reluctors can stay with the car if the rest of the engine is swapped. I've always assumed so, but...
Replacing 2013-2016 BRZ Wheel For 2017? demariners Electronics | Audio | NAV | Infotainment 57 03-08-2022 09:26 AM
HEATSHIELD Front Windshield Sunshade - 2013-2016 FR-S/2017+ 86 burgeralert Interior Parts (Incl. Lighting) 12 04-01-2021 09:50 PM
HKS Legamax Premium Series Catback Exhaust - 2013-2016 FR-S/2017+ 86/2013+ BRZ burgeralert Engine, Exhaust, Bolt-Ons 2 11-15-2020 11:08 AM
2013-2016 vs 2017 front pipe Var Engine, Exhaust, Transmission 2 10-09-2018 04:19 PM
2017 Tails on 2013-2016? djsyndrome Cosmetic Modification (Interior/Exterior/Lighting) 2 09-04-2016 06:51 PM
