Drives: '15 FR-S '85 4WD Tercel '95 Trooper
2nd Flywheel ring gear immenent failure
I have the same 2015 FRS and it previously had, circa 2019, its ring gear slowly loosen, wander and eventually start spinning on the flywheel. Something I was unaware could even happen. Well its happening again. Im in the early stages this time, with only minor but obvious wear on the tip of the starter pinion and the same metallic metal on metal noise that goes away with slight pressure on clutch pedal. This flywheel was a factory brand new take off from a zero mile car.
This is blowing my mind. This flywheel variant was also used on wrxs and likely other subarus if i am not mistaken. I still cant find any info anywhere about others having this issue. Has anyone else suffered a flywheel ring gear loosening? The only guess I have at this point is either statistically terrible luck with 2 lemon OEM flywheels, or possibly flywheel overheating. The first and latter 20k (52k total) where not driven by me and I know for a fact that in the latter 20k the car had a wildly burned out clutch I replaced (flywheel was turned) and in the prior I suspect the transmission was replaced likely under warranty (i believe the sticker had a 2016 build date which seemed odd on a 2015..) Anyone else have this issue? |
#2 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
I'd begin to suspect alignment of the starter motor and Bendix gear or the mounting flange in the block for it.
At least some extra scrutiny along those lines.
"I gotta rock." -- Charley Brown |
| The Following 3 Users Say Thank You to bcj For This Useful Post: |
#3 |
Agreed I have very much considered! I will say this (which has prevented me considering further at the moment): there is no engagement issues (always engages and spins without drama), no visible to me unusual wear on starter pinion/bendix gear drive surface (just the wear marks on the tip where its touches the running spinning flywheel). Starter is quiet and identical in noise to my first FRS. The wear pattern on both the flywheel and bendix gear appear to be even and consistent with what I imagine is healthy good engagement (ill get a better look at flywheel when it comes off). No damage to either mating surface and no unusual rocking or movement in the 2 machined surfaces of the starter or the tranmission when installing the starter. The trans install itself is about as challenging as any trans install is on the garage floor of a small townhouse 1 car garage
It is of course not unreasonable to consider the possibility that the bellhousing or block may have a misalignement but that a pricey and challenging to verify I think..But I will keep this in mind as I pull it apart again and check the flywheel closely for signs of uneven or angled engagement and maybe run a straight edge over the bellhousing surface. I am going to try purchasing the exedy aftermarket oem equivalent flywheel, it looks like a quality piece (and about $150 less). If this one develops ring gear problems, then it will be time to consider warpage in the big cast parts! I have decided to go with at this point ring gear stretching due to overheating of the cast iron portion of the flywheel as the culprit for time being. I do know for a fact this flywheel got hot enough to give a torched patina too much of the flywheel. Im pretty a sure the ring gear is probably a hardened steel of sorts so it may not like being stretched and there is likely a heat propogation delay considering the poor heat transmittance characteristics of iron and steel. I also doubt its that often that people torch clutches to that extent (the clutch got so hot it literally disintegrated into carbon dust and fibreglass, and yes I had a long conversation with the current owner about wether her knee could handle this anymore and proper slipping RPM). I shouldnt have reused the flywheel but it looked great after turning.. sorry for the novel! |
| The Following User Says Thank You to mhansen146 For This Useful Post: | bcj (05-20-2023) |
| GR86 4 gear SYNCHRONIZER ring in GT86? | Ruben_86_ | Engine, Exhaust, Transmission | 5 | 04-11-2023 06:58 PM |
| Nitro Gear Ring & Pinion | DIE1000DEATHS | Engine, Exhaust, Transmission | 2 | 06-25-2019 06:42 PM |
| CV Joint Failure and Differential Failure | AreteAuto | Issues | Warranty | Recalls / TSB | 26 | 06-16-2015 06:18 PM |
| Stock clutch+flywheel+pressure plate+ ACT lightweight flywheel & pressure plate | PineappleFriedRice | Transmission and Driveline | 0 | 11-08-2013 05:54 PM |
| 3.9 final gear - ring and pinion | PantsDants | Engine, Exhaust, Bolt-Ons | 5 | 11-08-2013 04:06 AM |
