Old 12-22-2022, 04:29 PM   #15
Racecomp Engineering
Originally Posted by Plastic Robot View Post
I'm curious about the maximum ride height. I'd like to run these higher than the recommended 25mm drop. Ideally closer to 10mm drop from stock height. Wondering that's feasible and if there are any differences in max ride height between SS1 and SS2?
Can you also comment any more on ride quality? With the stiffer springs I'm guessing it's not quite as comfortable on the street as the SS1, but wondering how much of a difference there is.
Originally Posted by marco_mc22 View Post
If those shocks are exactly the same as Kw/St (which I think they are) max ride height is -5 from stock using stock top hats and -20 using lowering mounts as SS2 use. This is because those camber plates and rear mounts roughly add 15mm of bump travel so at -20 your bump/droop ratio is the same as -5 with oem rubber hats.
^That's about right. I ran my SS1s a little higher than -20 and it was OKAY but not ideal (not enough droop travel).
As for ride quality, yes a smidge firmer than SS1 but still pretty good overall especially on small to medium bumps. If ride quality is a bigger concern, get SS1s, but SS2s are still daily driveable for most people.
- Andrew
Plastic Robot (12-22-2022)
Old 12-24-2022, 02:02 AM   #16
botbs
botbs's Avatar
Drives: 18 BRZ tS, 27 GRMN 86
Any reason why the Tarmac series doesn't come up KW top hat like the SS2?
botbs is offline   Reply With Quote
Old 12-27-2022, 10:19 AM   #17
Since we started the T2s way back for GD Impreza platform, we always wanted the option of using OEM or Group N rubber top mounts. Keeping top mounts optional is important to us for that product. We've thought about having the KW type tophat as an option but right now it's just not possible. Perhaps someday in the future.
- Andrew
botbs (12-27-2022), finch1750 (12-27-2022)
Old 12-27-2022, 02:50 PM   #18
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
We wanted the same "easy button" type of coilover as our SS1, but for someone that finds themselves at the track or autocrossing more often. No complicated set up, no annoying day to day compromises, and all the usual RCE after-sale support.
You can think of these as sort of a simplified RCE Tarmac 2 for those who don't necessarily need 2 way damping adjustability, but with the benefit of camber plates and rear top mounts included. Our T2s are still a great solution for those that do want 2 way damping adjustability or the option to run OEM style mounts.
Happy to answer any questions you may have.
- Andrew
How would you compare the SS2 and the T2 in terms of daily driving? 2 ways are more difficult to set up but I feel like it can help when adjusting between road and track.
botbs (12-30-2022)
Old 01-17-2023, 09:26 AM   #19
The T2s have a little more flexibility with the 2 way adjustability which can help with adjusting more for the street, but they're still a little more aggressive in terms of the range on compression damping. The difference isn't too large though.
- Andrew
finch1750 (01-18-2023), x808drifter (01-18-2023)
Old 04-01-2023, 09:01 PM   #20
BlueWhelan
BlueWhelan's Avatar
Drives: 2013 Blue Subaru BRZ. 6 Spd manual
Totally worth the price for the rear bump travel!
Say I wanted to get this but with the more mild springs of the SS1...would that be possible?
Or perhaps the SS1 with an upcharge for the rear mounts?
BlueWhelan is offline   Reply With Quote
Old 05-15-2023, 10:10 AM   #21
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
I know these are listed for the 2022+ technically, but can you confirm exact fitment for the 2013-2027 first gens?
Edit: Answered my own question - different links/pages for the 2013-2017!
cmiovino is offline   Reply With Quote
The Following User Says Thank You to cmiovino For This Useful Post:
Racecomp Engineering (05-15-2023)
Old 07-11-2024, 02:52 PM   #22
Just FYI, both SS1 and SS2 are back in stock. We've been really happy with the feedback on the SS2s...they add just a little bit of edge to SS1s and that extra performance potential works nicely with some of the stickier tires out there.
- Andrew
Old 07-12-2024, 05:25 PM   #23
ZDan
ZDan's Avatar
Drives: '23 BRZ
Won my time trial class with COMSCC last year on SS2. Sweeet... I did run 9k rear springs due to paranoia about understeer I had with the gen-1 BRZ, but honestly I think that was more to do with running that car on way too soft springs (4.5kF/5.4kR, or something like that)
Racecomp Engineering (07-13-2024)
Racecomp Engineering Superstreet-1 Coilovers Chrisz5z Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 11-27-2023 12:35 PM
Racecomp Engineering Superstreet-1 Lynxis Suspension | Chassis | Brakes -- Sponsored by 949 Racing 41 08-16-2022 01:33 AM
FS: Racecomp Engineering Tarmac 2 Coilovers USDM TOYOBARU Brakes, Suspension, Chassis 4 06-16-2020 05:25 PM
Racecomp Engineering Tarmac 2 coilovers. $1,500 Pat Brakes, Suspension, Chassis 16 07-22-2018 10:23 AM
RaceComp Engineering Tarmac Zero coilovers jack43 Brakes, Suspension, Chassis 5 10-03-2014 04:17 PM
