| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: Frs
Power Steering Noise
So I went to look at a 2013 scion fr-s today and anytime you would crank the wheel all the way to one way it would draw power and idle would drop. Is this normal for these cars or is something wrong with the power steering pump?
Also when throwing in a blue driver obd2 code reader it wouldn’t register or pop up at all, any reason for this as well? Thank you in advance. |
#2 |
Drives: None
1. The power steering in these cars is column mounted electric, if you go all the way to lock and try to keep turning / hold it forced to lock EPS will turn off. Idle dropping sounds somewhat strange, but we'd need a video to further diagnose.
2. Sometimes the OBD port pins get pushed back out of the connector and need to be pushed back in to their seats.
#3 | |
Drives: Frs
#4 |
"Dropping" to 750 RPM sounds to me like it was still cold. 650 is normal idle speed.
| Suspension or steering noise? | alex87f | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 17 | 11-30-2021 02:26 PM |
| Electric power steering and steering column part info | raspec | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 10-12-2021 06:27 PM |
| cranking noise when steering? | dad&sonFRS | Issues | Warranty | Recalls / TSB | 27 | 06-10-2019 09:04 PM |
| Squeaking noise from the steering | ScionFR-S | Issues | Warranty | Recalls / TSB | 22 | 02-09-2018 06:37 PM |
| Clunk noise no power | Antuono | Issues | Warranty | Recalls / TSB | 15 | 09-04-2017 01:58 AM |
