Old 05-03-2023, 01:25 AM   #1
Maplemoose
Drives: 2023 BRZ MT Sport Tech Black
2023 New BRZ, 1st Oil Change, No Crush Washer
Just did my 2023 BRZ's first 1K Mile, 1600 KM, oil change. However, I couldn't find the original crush washer. It is definitely not on the oil pan drain valve. And I asked three people to examine the drain bolt and they all said the crush washer couldn't be on the drain bolt.
I checked the old oil in the my oil pan and it's not there. I poured the old oil into a jug and poured it back to my oil pan, used my hand to feel around and it's not in the old oil.
I'm now afraid I have double crush washer the oil drain bolt now. Is it a big deal to double crush washer it if I torque it to spec?
I will get a new oil drain bolt from dealer and do my next oil change before winter in 5 months. Should I wait that long if I double crush washer it? Thanks.
Maplemoose is offline   Reply With Quote
Old 05-03-2023, 02:55 AM   #2
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Not sure if it's the case for the 22-23 but the original twins came from the factory with the black paint OVER the top of the crush gasket. So when you removed the drain plug bolt the first time, the crush gasket stayed stuck to the outside of the pan. I've also seen it stay stuck to the drain bolt itself and have to be pried off of it. Again, due to the black paint getting on it.
It was necessary to gently pry it off there and then replace it when doing the initial change. Could've been what happened here as well.
Was the edge area around the pan's drain valve opening smooth to the touch? You would've been able to easily feel if the crush gasket was stuck to the pan.
I don't know enough about crush washers to say if having two of them on there will cause a slow leak or not. I'd say put some cardboard under the car and check for signs of leaks in a day or two.
Originally Posted by humfrz
I'm old and lazy
Boomerang (05-04-2023)
Old 05-03-2023, 09:59 AM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
to quote the great puddins fab shop, it'll either leak or it won't.
and if it does, we'll say it never should've!
Old 05-03-2023, 01:10 PM   #4
Maplemoose
Thanks for your reply. I redid the whole oil change this morning and this time I can see the original crush washer in black just like you said.
I put back the one day old oil in the BRZ. So I wasted 30 minutes and another crush washer but at least I can sleep better now.
The Following User Says Thank You to Maplemoose For This Useful Post:
Clipdat (05-03-2023)
Old 05-03-2023, 01:48 PM   #5
Clipdat
Proud of BOXER
Clipdat's Avatar
Attaboy! Glad you got it sorted. Now you can get back to enjoying your BRZ!
I'm old and lazy
Size of new crush washer for oil change? Interceptor777 BRZ Second-Gen (2022+) — General Topics 3 02-07-2022 12:32 AM
Crush Washer Sizes Eric1855 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 55 08-30-2021 03:21 AM
Crush Washer on Drain Plug? torql13 Scion FR-S / Toyota 86 GT86 General Forum 14 05-04-2021 08:27 AM
OEM Oil Drain Crush Washer Buying Tip radroach Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-20-2016 10:42 PM
Crush Washer for AT BRZ888 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 07-27-2014 11:06 PM
