Old 04-28-2023, 05:39 PM   #15
ag-brz
Drives: 2022 BRZ MT
Originally Posted by Grady View Post
Same issue does not equal the same problem. If what you are telling us of no mods and only been to Subaru, getting warranty on that would have been simple. There has to be more to the story? My guess is you have been an ass to the dealer/service center so they are not going to go out of their way to help you.
I meant both posts are about the same thing that happened on the same date. not 2 similar issues.
Their reason for not covering it is because "I broke it myself" even though it has never been touched by anyone other than the service center (except for now because I needed my car back)
ag-brz is offline   Reply With Quote
Old 04-28-2023, 05:44 PM   #16
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Originally Posted by humfrz
I'm old and lazy
RToyo86 (05-01-2023)
Old 04-28-2023, 05:56 PM   #17
ag-brz
Drives: 2022 BRZ MT
So what did the shop fix? You didn't get an itemized list? 130 is pretty close to hourly rate for most dealerships and close to hourly for independent shops. How fast were you going when it fell off? Which caliper bolts, slider pin or bracket to hub?
I attached the message from the receipt from subaru. Mavis did the work for $60 + $70 in parts (Disc Brake Caliper Bracket (Right, Front) and
Bolt and Washer. Bolt Housing M12 19.)
Old 04-28-2023, 06:40 PM   #18
Grady
Grady's Avatar
This is still not add up. There is no way to for you to break it if you never touched it. What you described is probably an under/over torque issue. With some negotiation of facts with Subaru this should have been taken care of. Did you start with threatening to sue?
The Following 3 Users Say Thank You to Grady For This Useful Post:
DarkSunrise (04-29-2023), Jdmjunkie (04-29-2023), NoHaveMSG (04-28-2023)
Old 04-28-2023, 06:56 PM   #19
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
And there it is.
Old 04-29-2023, 11:28 AM   #20
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Threads stripped, not a broken bolt, wheel bearing bolt heads partially rounded, damage to backside of wheel bearing, damage to both inside and outside wheel lips that would not be caused by the loose caliper. It's entirely reasonable to deny the warranty claim because it seems someone who doesn't know what they're doing got in there and tried to do something, or at least some major event outside of subaru's control unfolded.
The warranty's job is for material and workmanship defect on subaru's part. If you fucked something up, that's on you, if this is the result of an incident, then it's an insurance job.
The Following 2 Users Say Thank You to RZNT4R For This Useful Post:
DarkSunrise (04-29-2023), Wally86 (05-01-2023)
Old 04-29-2023, 01:47 PM   #21
DarkSunrise
DarkSunrise's Avatar
Agree this smells fishy. The past history of posts and the damage the tech found (stripped threads, rounded bolt heads, damage to wheel bearing) is really suspicious.
2022 BRZ Build
2013 FR-S Build
The Following 2 Users Say Thank You to DarkSunrise For This Useful Post:
Clipdat (04-29-2023), Jdmjunkie (04-29-2023)
Old 05-01-2023, 09:33 AM   #22
Tokay444
InB4ClassActionDeniedLikeWarranty
Old 05-01-2023, 11:49 AM   #23
It very much has to do, its the same issue. This is essentially a repost. My caliper came off and that's very dangerous. I never took the car to anywhere other than subaru service
Did you understand the answers in your other thread even one little bit? The other thread is completely and totally a different thing and your wheels do not attach the same as the recall anyway.
This whole "class action" is laughably stupid!
Brake caliper bracket bolt Pinoy_FRS Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 03-12-2019 03:38 PM
Need help finding a dual caliper bracket. Snarl Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 06-20-2016 09:39 AM
Dual Caliper custom bracket THA STI GUY Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 02-25-2015 06:41 PM
Class Action Lawsuit 8brz BRZ First-Gen (2012+) — General Topics 88 06-21-2012 06:45 PM
