Old 01-20-2016, 09:43 AM   #15
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Flooring the throttle before and during cranking triggers flood-clearing mode. Fuel is completely cut. No need to disconnect anything. Great feature. I use it for extra peace of mind after every oil change.
One of these days I'll get to installing my oil cooler. Gotta buy it first.
Yeah I did not know that either! Thanks
Old 01-20-2016, 12:11 PM   #16
My pleasure, guys! Good luck with your cooler, g0odspeed.
g0odspeed (01-20-2016)
Old 01-20-2016, 12:30 PM   #17
g0odspeed
Drives: 2013 Scion FR-S Asphault
Thanks man.. I finally did get it fully installed and leak free. If you want to see pics I posted a DIY about it. The coolant line setup is a little different since I went turbo. Had to design and customize the upper rad Hose and fill neck. But it's all in there and I'm pleased with the results. If you wanna see pics of that let me know. I like the oil cooler in the rad because there was less in the front grill. Only have the inner cooler there.. Check out the DIY if you want to..
g0odspeed is offline   Reply With Quote
The Following User Says Thank You to g0odspeed For This Useful Post:
Ultramaroon (01-20-2016)
Old 01-20-2016, 12:50 PM   #18
Oops! I mixed you up with @ryoma. Good luck with yours as well, OP.
Old 01-25-2016, 10:31 AM   #19
Mishimoto
Drives: 2013 Subaru BRZ
Originally Posted by ryoma View Post
after installation and starting up the car, how long should I expect for the oil cooler lines to fill up with oil (if the oil pressure and actual oil is not the same)? unless I am supposed to add in the extra .65 quart before the first start? if I add in the extra oil, would it cause the engine to be overfilled before the oil cooler is at full oil capacity? I know you mentioned that the cooler lines are closed off until it reaches 185F so would that affect how fast the cooler and lines fill up after installation?
The cooler should fill in seconds, I would be concerned about the engine running dry at startup. I would recommend adding the fluid prior to startup. Once the vehicle is up to temperature, you can check the fluid level once again to ensure it is properly filled. Oil is diverted from the the cooler when cold, but some fluid still routes through the lines (around 10%).
Add the extra oil before you fire it up, takes all of 10 seconds if that to fill the core and everything will be working is it should. Any good quality full synthetic oil can easily handle keeping the engine oiled while that is happening. I think you are over thinking this a little haha!
Thanks!
Murphy gets everyone. I dont care how careful I am to check everything, there is always something I miss. I don't have the mishimoto oil cooler but I ran into the same issues with the Skunk2 ultra. Oil went everywhere before I could get the car off. I didn't prime anything either. Just added the extra oil before cranking. If it is a real concern of your you can unhook the ecu and try to crank it. It will turn over and push oil through everything. Just a thought. I also looked at the video and you should have no problem. Mishimoto has some excellent install videos. I used them when I did my radiator. Anyways, have fun with it. The overthinking can stress you out.
Thanks for the kind words regarding our installation videos!
Great tip!
Thanks
-John
Mishimoto is offline   Reply With Quote
Old 04-12-2023, 08:46 AM   #20
NicFromTheNorth
Drives: Subaru BRZ 2016
Flood mode active without stock tune
Can anyone confirm that this mode is still active with OFT or WayneRom tunes? I don't see why not but I need extra peace of mind before doing this procedure after an oil pan replacement.
NicFromTheNorth is offline   Reply With Quote
Old 04-12-2023, 12:50 PM   #21
Just the oil pan? If you didn't tear apart the engine, it's no different than an oil change.
But it's a good question. I'm still on my stock tune. Cannot confirm.
Old 04-12-2023, 01:14 PM   #22
tomm.brz
Drives: brz 2017 hksv2
yes it is, they didn t mod it, needs to be at 100% to ihnibit fuel, if you do like 80% is still injecting some fuel and probably will turn on accelerating while cold and lean :P
I use it to start on the engine when cold, just floor pedal and let engine crank a couple seconds without fuel then abruptly release the accel pedal and it will start normally
Ultramaroon (04-12-2023)
Old 04-12-2023, 02:38 PM   #23
NicFromTheNorth
Thanks for the quick replies!
I am only replacing the oil pan, because I stripped the drain plug thread... The car has been on jacks for four days draining oil out.
I modified the pedal to throttle curve in the tune, but that shouldn't matter for the flood mode since it relies on the pedal position.
Old 04-12-2023, 03:09 PM   #24
tomm.brz
yes it will work
Oil Cooler Set Up – DIY? toraider Engine, Exhaust, Transmission 25 08-12-2015 06:59 AM
Oil Cooler Wyattkb Want-To-Buy Requests 0 02-22-2015 12:27 AM
Robispec Radiator/oil cooler NEW $800 or trade for NEW FB oil cooler kit. mike the snake Engine, Exhaust, Bolt-Ons 1 01-31-2014 05:46 PM
Best oil cooler whitefrs Engine, Exhaust, Transmission 4 02-21-2013 11:36 PM
