Old 03-29-2023, 03:45 PM   #1
jaiiwa
Drives:
Extreme vibration at certain RPM’s after transmission work
So a little over a month ago I brought my FRS into a shop to have my throw out bearing replaced after I noticed it started making weird noises and doing all the other telltale signs of a bad throw out bearing. When they pulled it apart they basically explained to me that the transmission had grenaded. Everything appeared to be burnt, warped, scratched, etc. they replaced numerous components but also resurfaced many, such as the flywheel. After about a month, I finally got my car back and noticed that it had a much rougher idle than before and around 3k rpm, the car vibrates like crazy, to the point where almost every part of my car now has a rattle. From my research this is due to the flywheel being resurfaced incorrectly. I plan on reaching back out to the shop and am trying to get the best guess as to what could be going on, so any information you guys could share would be extremely helpful. Thanks in advance.
jaiiwa is offline   Reply With Quote
Old 03-29-2023, 06:33 PM   #2
Turdinator
Señor Member
Turdinator's Avatar
Sounds like the clutch and/or flywheel are not balanced.
1974 TA22 Celica
2013 86 GT
Old 03-30-2023, 09:25 PM   #3
stacyu18
Drives: 2014 subaru brz
maybe the carrier bearing is put on up side down or night tighten
stacyu18 is offline   Reply With Quote
Help! Transmission mount to transmission bolt size Four_wheel_drifts Engine, Exhaust, Transmission 4 08-31-2020 03:55 PM
Transmission Synchro Warranty Work runfrodorun Issues | Warranty | Recalls / TSB 55 11-17-2017 09:23 PM
WORK Emotion Wheels ** Winter Promotion || Free WORK Lugs or WORK Caps ** RavSpec Wheels and Tires 18 12-10-2013 06:19 PM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 08:54 PM
