#169 |
Drives: 2014 GT86
Dr. BRZ: but have you tried to switch drivers? It's usually the nut behind the wheel, that makes most difference. I'm sure i'd drive twice slower on uber aftermarket upgraded one then eg. CSG Mike on stock.
#170 | |
Drives: '14 Monogram 6MT FR-S - Hot Lava
#171 | ||
Drives: 2016 BRZ
2 things I'll add.
| The Following User Says Thank You to Joon525 For This Useful Post: | johan (04-12-2017) |
#172 |
Drives: frs
Wonder how us fitment
https://www.velossatechdesign.com/pr...intake-snorkel |
#173 | |
| The Following User Says Thank You to Grady For This Useful Post: | PulsarBeeerz (03-23-2023) |
#174 |
Drives: 2017 BRZ PP
Aren’t all of the snorkel options more detrimental to the AFR and performance of the car if adding to a car with a stock or off the shelf tune? I thought this was something GrimmSpeed proved several years back.
For the people adding these snorkels, are you getting custom tunes to see the benefits or has anyone identified actual benefits with these to a car with an off the shelf tune (e.g., OFT stg2). |
#175 | |
Drives: JRSC BRZ SOLD
| The Following User Says Thank You to PulsarBeeerz For This Useful Post: | Teseo (03-23-2023) |
#176 | |
Drives: 2017 BRZ PP
“Well, not a whole lot different than expected, right? A nice little bump in power (4-5whp), but she's looking pretty lean. The modded snorkel appears to richen things up a bit but maintain the gain. The silicone elbow doesn't appear to have much of an affect on performance (1-2whp with the stock filter and less with the K&N). All in all, the K&N drop-in and modded snorkel are not a bad gain for such a small investment, but we're not wild about the change in AFR.” https://www.ft86club.com/forums/showthread.php?t=56341 |
#177 | |
Oh that one! An important thing to consider in their test is no aftermarket snorkel was used. They modded the stocker, they didn't use one that extended the entry point lower for better IATs. Also it has been reported many times that the filter element has an effect on AFR in the short term. Those same AFRs would stabilize after 60-100 miles of driving once the ECU learns and adjust. A few comments down someone has the exact setup they tested with AFRs in the high 11s which is perfectly fine. But they had been running that setup for a while. |
#178 |
Drives: 2017 BRZ PP
That is a very good point, that in their testing they never used an aftermarket snorkel. I may end up giving one a try to see what the results are.
#179 | |
Drives: Crapcan
#180 |
Drives: 17 BRZ
I can confirm running a Greddy Snorkel ran AFR on the richer side after installation. Nothing crazy but I did get another tune to correct it.
I also run the HKS carbon intake tube. |
#181 |
Interesting, mine ran slightly leaner, again nothing crazy (~.1-.2 AFR) or worth tuning for. But I was running an E85 tune at the time if that makes a difference.
#182 |
Drives: 2017 BRZ PP
While we have more people coming in and providing their experiences, did you notice any tangible benefits with using the Greddy snorkel espi?
| PERRIN Silicone Intake Duct Review | JoeBoxer | Engine, Exhaust, Transmission | 287 | 01-24-2018 11:01 PM |
| FRS bumper duct | VENOM~ | Cosmetic Modification (Interior/Exterior/Lighting) | 36 | 12-12-2015 01:15 PM |
| TF Brake Duct Cooling Kit | Touge Factory | Tracking / Autocross / HPDE / Drifting | 77 | 06-11-2015 08:01 AM |
| Maxracing dynamic intake duct | Mars2 | Engine, Exhaust, Transmission | 123 | 09-23-2014 09:39 PM |
| WTB: Stock Intake Air Duct | FR-S Matt | Want-To-Buy Requests | 4 | 08-12-2013 07:30 AM |
